BananaPi BPI-CM4 new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support MIPI-DSI and MIPI-CSI interface ,HDMI output,1 Gigabit port ,4G RAM and 16 GB eMMC flash.
For A311D chip PIN limited ,just support 1 HDMI ,1 CSI and 1 DSI , Raspberry Pi support 2 HDMI ,2 CSI and 2 DSI , Other is Pin2Pin . you can use Raspberry Pi CM4 baseboard.
Amlogic A311D design : Banana Pi BPI-M2S single board computer Amlogic A311D design : Banana Pi BPI-CM4 computer module |
NPU for AI :Next generation, deep-neural-network applications, at 5.0 TOPS
4GB LPDDR4 RAM
16GB eMMC flash (Max 128G)
Support MIPI DSI Display interface
Support MIPI CSI Camera interface
Minipcie
HDMI output
2*100 PIN GPIO
Support Android and Linux system.
| Banana pi BPI-CM4 PIN Out define VS Raspberry PI CM4 | |||||
BPI-CM4 |
RPI CM4 |
PIN |
PIN |
RPI CM4 |
BPI-CM4 |
GND |
GND |
1 |
2 |
GND |
GND |
NAT0_MDI3p |
Ethernet_Pair3_P |
3 |
4 |
Ethernet_Pair1_P |
NAT0_MDI1p |
NAT0_MDI3n |
Ethernet_Pair3_N |
5 |
6 |
Ethernet_Pair1_N |
NAT0_MDI1n |
GND |
GND |
7 |
8 |
GND |
GND |
NAT0_MDI2n |
Ethernet_Pair2_N |
9 |
10 |
Ethernet_Pair0_N |
NAT0_MDI0n |
NAT0_MDI2p |
Ethernet_Pair2_P |
11 |
12 |
Ethernet_Pair0_P |
NAT0_MDI0p |
GND |
GND |
13 |
14 |
GND |
GND |
Ethernet_LED2/1G_Active |
Ethernet_nLED3_1G-Active |
15 |
16 |
Ethernet_SYNC_IN |
LINUX_Debug_RX |
Ethernet_LED1/Link |
Ethernet_nLED2_1G-Link |
17 |
18 |
Ethernet_SYNC_OUT |
LINUX_Debug_TX |
Ethernet_0_LED0/CFG_EXT |
Ethernet_nLED1_Y |
19 |
20 |
EEPROM_nWP |
NC |
SYS_LED2 |
Pi_nLED_Activity |
21 |
22 |
GND |
GND |
GND |
GND |
23 |
24 |
I2S_MCLK/GPIO26 |
GPIOA_0 |
GPIOA_3 |
GPIO21/I2S_DO |
25 |
26 |
I2S_LRCLK/GPIO19 |
GPIOA_2 |
GPIOA_4 |
GPIO20/I2S_DI |
27 |
28 |
GPIO13 |
GPIOA_7 |
GPIOAO_11 |
GPIO16 |
29 |
30 |
GPIO6 |
GPIOAO_10 |
GPIOH_5 |
GPIO12 |
31 |
32 |
GND |
GND |
GND |
GND |
33 |
34 |
GPO5 |
GPIOH_4 |
GPIOA_15 |
ID_SC |
35 |
36 |
ID_SD |
GPIOA_14 |
GPIOAO_5 |
GPIO7/SPI-CE1 |
37 |
38 |
SPI-CLK/GPIO11 |
GPIOX_11 |
GPIOX_10 |
GPIO8/SPI-CE0 |
39 |
40 |
SPI-MISO/GPIO9 |
GPIOX_9 |
GPIOA_11 |
GPIO25 |
41 |
42 |
GND |
GND |
GND |
GND |
43 |
44 |
SPI-MOSI/GPIO10 |
GPIOX_8 |
GPIOA_12 |
GPIO24/UART0-CTS |
45 |
46 |
GPIO22 |
GPIOA_5 |
GPIOA_13 |
GPIO23/UART0-RTS |
47 |
48 |
UART1-RXD/GPIO27 |
GPIOA_6 |
GPIOA_1 |
GPIO18/I2S_SCLK |
49 |
50 |
UART1-TXD/GPIO17 |
GPIOA_9 |
GPIOX_7 |
GPIO15/UART0-RXD |
51 |
52 |
GND |
GND |
GND |
GND |
53 |
54 |
PWM/GPIO4 |
GPIOA_10 |
GPIOX_6 |
GPIO14/UART0-TXD |
55 |
56 |
SCL/GPIO3 |
GPIOX_18 |
SD_CLK_B |
SD_CLK |
57 |
58 |
SDA/GPIO2 |
GPIOX_17 |
GND |
GND |
59 |
60 |
GND |
GND |
SD_D3_B |
SD_DAT3 |
61 |
62 |
SD_CMD |
SD_CMD_B |
SD_D0_B |
SD_DAT0 |
63 |
64 |
SD_DAT5 |
NC |
GND |
GND |
65 |
66 |
GND |
GND |
SD_D1_B |
SD_DAT1 |
67 |
68 |
SD_DAT4 |
NC |
SD_D2_B |
SD_DAT2 |
69 |
70 |
SD_DAT7 |
NC |
GND |
GND |
71 |
72 |
SD_DAT6 |
NC |
NC |
SD_VDD_Override |
73 |
74 |
GND |
GND |
TF_VDD_EN |
SD_PWR_ON |
75 |
76 |
Reserved/SD_DET |
CARD_DET |
+5V_Input |
+5V_Input |
77 |
78 |
GPIO_VREF |
NC |
+5V_Input |
+5V_Input |
79 |
80 |
SCL0_Camera_3V3 |
GPIOH_7 |
+5V_Input |
+5V_Input |
81 |
82 |
SDA0_Camera_3V3 |
GPIOH_6 |
+5V_Input |
+5V_Input |
83 |
84 |
CM4_3V3_OUTPUT |
CM4_3V3_OUTPUT |
+5V_Input |
+5V_Input |
85 |
86 |
CM4_3V3_OUTPUT |
CM4_3V3_OUTPUT |
+5V_Input |
+5V_Input |
87 |
88 |
CM4_1V8_OUTPUT |
CM4_1V8_OUTPUT |
NC |
WL_nDisable_3V3 |
89 |
90 |
CM4_1V8_OUTPUT |
CM4_1V8_OUTPUT |
NC |
BT_nDisable_3V3 |
91 |
92 |
RUN_PG/Reset_3V3 |
CPU_RST |
NC |
nRPIBOOT_3V3 |
93 |
94 |
AnalogIP1/USBC_CC2 |
SARADC_CH3 |
SYS_LED |
PI_LED_nPWR |
95 |
96 |
AnalogIP0/USBC_CC1 |
ADC_KEY |
NC |
Camera_PWD_GPIO |
97 |
98 |
GND |
GND |
NC |
GLOBAL_EN_5V |
99 |
100 |
nEXTRST |
GPIOH_8 |
USBOTG_B_ID |
USB_OTG_ID_3V3 |
101 |
102 |
PCIe_CLK_nREQ_3V3 |
PCIECK_REQN |
USBOTG_B_DM |
USB_N |
103 |
104 |
Reserved |
USB_A_DP |
USBOTG_B_DP |
USB_P |
105 |
106 |
Reserved |
USB_A_DM |
GND |
GND |
107 |
108 |
GND |
GND |
PERST0_N |
PCIe_nRST_3V3 |
109 |
110 |
PCIe_CLK_P |
PCIE_CLKP |
NC |
VDAC_COMP_TV |
111 |
112 |
PCIe_CLK_N |
PCIE_CLKN |
GND |
GND |
113 |
114 |
GND |
GND |
MIPI_CSI_D0N |
CAM1_D0_N |
115 |
116 |
PCIe_RX_P |
PCIE_SOC_RXP |
MIPI_CSI_D0P |
CAM1_D0_P |
117 |
118 |
PCIe_RX_N |
PCIE_SOC_RXN |
GND |
GND |
119 |
120 |
GND |
GND |
MIPI_CSI_D1N |
CAM1_D1_N |
121 |
122 |
PCIe_TX_P |
PCIE_TX0_P |
MIPI_CSI_D1P |
CAM1_D1_P |
123 |
124 |
PCIe_TX_N |
PCIE_TX0_N |
GND |
GND |
125 |
126 |
GND |
GND |
MIPI_CSI_CLKAN |
CAM1_C_N |
127 |
128 |
CAM0_D0_N |
NC |
MIPI_CSI_CLKAP |
CAM1_C_P |
129 |
130 |
CAM0_D0_P |
NC |
GND |
GND |
131 |
132 |
GND |
GND |
MIPI_CSI_D2N |
CAM1_D2_N |
133 |
134 |
CAM0_D1_N |
NC |
MIPI_CSI_D2P |
CAM1_D2_P |
135 |
136 |
CAM0_D1_P |
NC |
GND |
GND |
137 |
138 |
GND |
GND |
MIPI_CSI_D3N |
CAM1_D3_N |
139 |
140 |
CAM0_C_N |
MIPI_CSI_CLKBN |
MIPI_CSI_D3P |
CAM1_D3_P |
141 |
142 |
CAM0_C_P |
MIPI_CSI_CLKBP |
NC |
HDMI1_HOTPLUG_5V |
143 |
144 |
GND |
GND |
NC |
HDMI1_SDA_5V |
145 |
146 |
HDMI1_TX2_P |
NC |
NC |
HDMI1_SCL_5V |
147 |
148 |
HDMI1_TX2_N |
NC |
NC |
HDMI1_CEC_5V |
149 |
150 |
GND |
GND |
HDMI_TXCEC |
HDMI0_CEC_5V |
151 |
152 |
HDMI1_TX1_P |
NC |
HDMI_HPDC |
HDMI0_HOTPLUG_5V |
153 |
154 |
HDMI1_TX1_N |
NC |
GND |
GND |
155 |
156 |
GND |
GND |
NC |
DSI0_D0_N |
157 |
158 |
HDMI1_TX0_P |
NC |
NC |
DSI0_D0_P |
159 |
160 |
HDMI1_TX0_N |
NC |
GND |
GND |
161 |
162 |
GND |
GND |
NC |
DSI0_D1_N |
163 |
164 |
HDMI1_CLK_P |
NC |
NC |
DSI0_D1_P |
165 |
166 |
HDMI1_CLK_N |
NC |
GND |
GND |
167 |
168 |
GND |
GND |
NC |
DSI0_C_N |
169 |
170 |
HDMI0_TX2_P |
HDMI_TX2P |
NC |
DSI0_C_P |
171 |
172 |
HDMI0_TX2_N |
HDMI_TX2N |
GND |
GND |
173 |
174 |
GNF |
GND |
MIPI_D0_N |
DSI1_D0_N |
175 |
176 |
HDMI0_TX1_P |
HDMI_TX1P |
MIPI_D0_P |
DSI1_D0_P |
177 |
178 |
HDMI0_TX1_N |
HDMI_TX1N |
GND |
GND |
179 |
180 |
GND |
GND |
MIPI_D1_N |
DSI1_D1_N |
181 |
182 |
HDMI0_TX0_P |
HDMI_TX0P |
MIPI_D1_P |
DSI1_D1_P |
183 |
184 |
HDMI0_TX0_N |
HDMI_TX0N |
GND |
GND |
185 |
186 |
GND |
GND |
MIPI_CLK_N |
DSI1_C_N |
187 |
188 |
HDMI0_CLK_P |
HDMI_TXCP |
MIPI_CLK_P |
DSI1_C_P |
189 |
190 |
HDMI0_CLK_N |
HDMI_TXCN |
GND |
GND |
191 |
192 |
GND |
GND |
MIPI_D2_N |
DSI1_D2_N |
193 |
194 |
DSI1_D3_N |
MIPI_D3_N |
MIPI_D2_P |
DSI1_D2_P |
195 |
196 |
DSI1_D3_P |
MIPI_D3_P |
GND |
GND |
197 |
198 |
GND |
GND |
HDMI_SDA |
HDMI0_SDA_5V |
199 |
200 |
HDMI0_SCL_5V |
HDMI_SCL |
SoC – Amlogic A311D hexa-core processor with 4x Arm Cortex-A73 cores, 2x Arm Cortex-A53 cores, Arm Mali-G52 MP4 (6EE) GPU with OpenGL ES 3.2, Vulkan 1.0 and OpenCL 2.0 support, 5 TOPS NPU
System Memory – 4GB LPDDR4
Storage – 16GB eMMC flash (option up to 128GB), MicroSD card slot
Video interfaces
HDMI 2.1 output up to 4Kp60
MIPI CSI connector for camera
Networking – 1x Gigabit Ethernet ports one via RTL8211F GbE transceiver
USB – 2x USB 2.0 Type-A port, 1x USB Type-C port
Expansion – 26-pin GPIO header
Debugging – 3-pin header for serial console
Misc – 2x buttons.
Power Supply – Via USB-C port or pin header
The BPI-CM4 computer module is exactly the same size as the raspberry PI CM4, and adopts the same interface,You can use the universal raspberry PI CM4 module expansion board.
| Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 PIN code: 8888 |
| BPI-CM4 Module Datasheet |
Baidu Cloud: https://pan.baidu.com/s/1NXBXwiowWbHVY7ciT1lw-Q?pwd=8888 PIN code:8888
| Banana PI BPI-M2S Amlogic A311D / S922X : https://www.youtube.com/watch?v=9eFXiOtzFl0 |
Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files
| All banana pi docement(SCH file,DXF file,and doc) |
| Amlogic A311D datasheet: https://drive.google.com/file/d/1SRAY_RDxKhw819uyo9H13zNN2wlG6LDq/view?usp=sharing |
| BPI-CM4 Schematic: https://drive.google.com/file/d/1IXXok1P2OLiW3p8tavkbfEPTGTrM3b-R/view?usp=sharing |
| BPI-CM4 DXF file: https://drive.google.com/file/d/1hTLNCwmYhCuzt9rL6fP0PjK4MTIE5dK6/view?usp=sharing |
| UglyScale Present - Banana Pi BPI-CM4 : https://www.youtube.com/watch?v=9qhAmpjdEfE |
| Banana Pi CM4 Review ( VS Compute Raspberrypi CM4) : https://bret.dk/banana-pi-cm4-review/ |
| BPI-CM4 MNT Reform with A311D Processor desktop performance captured over HDMI : https://www.youtube.com/watch?v=SULvVajiLvw |
| 2024-04-29-bpi-m2s-cm4-android9.img |
Baidu cloud: https://pan.baidu.com/s/10_vRDmzVobR4grjUbuDbeA?pwd=8888 (pincode:8888)
| 2023-01-12-bpi-m2s-cm4-android9.img |
Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 PIN code:8888
| 2023-07-10 Armbian_23.05.0-trunk_Bananapicm4io_bullseye_edge_6.2.12_gnome_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1aAMO-qKdowDakZ37JH6YBA?pwd=8888 PIN code:8888
| 2023-12-26-ubuntu-20.04-server-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/1sQxZ2EZ7YL6nVI_CjzaUrw?pwd=8888 PIN code:8888
| 2023-12-26-ubuntu-20.04-mate-desktop-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/11veH_09OJI1Pk1CG9J0MHw?pwd=8888 PIN code:8888
| 2023-01-12-ubuntu-20.04-mate-desktop-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/1rh55yoEjPWsHXIcna7xEhQ?pwd=8888 PIN code:8888
Google Drive: https://drive.google.com/drive/folders/1xd2HA4Vv_U69iREiAUkOftZmmVbjw7yF?usp=share_link
| 2023-01-12-ubuntu-20.04-server-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/17gu0ToxWmFi2i8VwuiqVDQ?pwd=8888 PIN code:8888
| 2023-12-26-debian-10-buster-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/1xhaAE0wqYi6NjpHwAeKh-g?pwd=8888 PIN code:8888
| 2023-12-26-debian-10-buster-xfce-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/1Q74ijyubqYBOZC7NX8YMSw?pwd=8888 PIN code:8888
| 2023-01-12-debian-10-buster-bpi-cm4-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/19aQB16fdo2Si-is76R9LOQ?pwd=8888 PIN code:8888
| BPI-CM4 is currently on platinum support from armbian. Download the latest images from here: https://www.armbian.com/bananapicm4io/ |
Armbian is a simple, light, and fast Linux operating system optimized for development boards, offering a user-friendly experience for newcomers and professionals.
The system is designed to minimize SD card wear. It can be accessed via serial, HDMI/VGA, or SSH, with optional special utilities available for further customization.
The system can also be built and customized via the armbian build utility.
| BPI-CM4 use vim3 rootfs image, you can run the npu demo from khadas wiki on this image |
Username/Password: khadas/khadas or root/khadas
Baidu Link: https://pan.baidu.com/s/1zLQJGf4YQ_45ZLKotKWhhw?pwd=xvvc PIN code:xvvc
| BANANAPI Official shop: https://www.bpi-shop.com/products/bananapi-bpi-cm4-new-design-with-amlogic-a311d.html |
| BPI Aliexpress shop: https://www.aliexpress.us/item/3256804929238485.html?spm=5261.promotion_single_index.table.1.7d6b4edfN3JCJM&gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US |
| SinoVoip Aliexpress shop : https://www.aliexpress.com/item/1005005115415086.html |
| Taobao shop : https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-24708246124.11.473c3550l3PVcF&id=696638614755 |
| OEM&ODM please contact : [email protected] |
