BananaPi BPI-M2S new design with Amlogic A311D, Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port, 4G RAM and 16 GB eMMC flash.
Amlogic A311D design : Banana Pi BPI-M2S single board compuer Amlogic A311D design : Banana Pi BPI-CM4 computer module |
| Amlogic S922X variant BPI-M2S board is 2G ram, 16G eMMC, NOT support npu, mipi panel and mipi camera. |
YouTube viode: https://youtu.be/0s3seudNXdE
Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU
NPU for AI :Next generation, deep-neural-network applications, at 5.0 TOPS
4GB LPDDR4 RAM
16GB eMMC flash (Max 128G)
Support MIPI-DSI Dispaly Serial interface
Support MIPI-CSI Camera Serial interface
2 Gigabit ethernet port
HDMI output
40 PIN GPIO
Support Android and Linux system
| HardWare Specification of Banana Pi M2 Super | |
SoC |
Amlogic A311D hexa-core processor with 4x Arm Cortex-A73 cores, 2x Arm Cortex-A53 cores, Arm Mali-G52 MP4 (6EE) GPU with OpenGL ES 3.2, Vulkan 1.0 and OpenCL 2.0 support, 5 TOPS NPU |
System Memory |
4GB LPDDR4 |
Storage |
16GB eMMC flash (option up to 128GB), MicroSD card slot |
Video interfaces |
HDMI 2.1 output up to 4Kp60 MIPI DSI connector for display MIPI CSI connector for camera |
Networking |
2x Gigabit Ethernet ports one via RTL8211F GbE transceiver, the other through RTL8111H PCIe to Gigabit Ethernet transceiver |
USB |
1x USB 2.0 Type-A port, 1x USB Type-C port |
Expansion |
40-pin GPIO header |
Debugging |
3-pin header for serial console |
Misc |
3x buttons |
Power Supply |
Via USB-C port or pin header |
Dimensions |
65 x 65mm |
| 40 PIN GPIO of Banana pi BPI-M2 Super | |||
GPIO Pin Name |
Default :GPIO |
Function2 |
Function3 |
CON2-P01 |
VCC-3V3 |
CON2-P02 |
DCIN |
CON2-P03 |
GPIOX_17 |
I2C_EE_M2_SDA |
BT_EN |
CON2-P04 |
DCIN |
CON2-P05 |
GPIOX_18 |
I2C_EE_M2_SCL |
BT_WAKE_HOST |
CON2-P06 |
GND |
CON2-P07 |
GPIOX_5 |
PWM_C |
WIFI_SD_CMD |
CON2-P08 |
GPIOX_12 |
UART_EE_A_TX |
CON2-P09 |
GND |
CON2-P10 |
GPIOX_13 |
UART_EE_A_RX |
CON2-P11 |
GPIOX_3 |
WIFI_SD_D3 |
CON2-P12 |
GPIOA_1 |
I2SB_SCLK |
CON2-P13 |
GPIOX_4 |
WIFI_SD_CLK |
CON2-P14 |
GND |
CON2-P15 |
GPIOX_7 |
WIFI_WAKE_HOST |
CON2-P16 |
GPIOX_0 |
WIFI_SD_D0 |
CON2-P17 |
VCC-3V3 |
CON2-P18 |
GPIOX_1 |
WIFI_SD_D1 |
CON2-P19 |
GPIOX_8 |
SPI_A_MOSI |
BTPCM_DIN |
CON2-P20 |
GND |
CON2-P21 |
GPIOX_9 |
SPI_A_MISO |
BTPCM_DOUT |
CON2-P22 |
GPIOX_2 |
WIFI_SD_D2 |
CON2-P23 |
GPIOX_11 |
SPI_A_CLK |
BTPCM_CLK |
CON2-P24 |
GPIOX_10 |
SPI_A_CS |
BTPCM_SYNC |
CON2-P25 |
GND |
CON2-P26 |
GPIOX_16 |
BT_32K |
CON2-P27 |
GPIOH_5 |
CON2-P28 |
GPIOH_4 |
CON2-P29 |
GPIOX_14 |
BTUART_A_CTS_N |
CON2-P30 |
GND |
CON2-P31 |
GPIOX_15 |
BTUART_A_RTS_N |
CON2-P32 |
GPIOX_19 |
HOST_WAKE_BT |
CON2-P33 |
GPIOX_6 |
WIFI_PWREN |
CON2-P34 |
GND |
CON2-P35 |
GPIOA_2 |
I2SB_LRCLK |
CON2-P36 |
GPIOAO_5 |
IR_IN |
CON2-P37 |
GPIOA_0 |
I2S_MCLK_0 |
CON2-P38 |
GPIOA_4 |
I2SB_DOUT_DIN_1 |
CON2-P39 |
GND |
CON2-P40 |
GPIOA_3 |
I2SB_DOUT_DIN_0 |
CON2-P1 |
GND |
CON2-P2 |
UART0-RX |
CON2-P3 |
UART0-TX |
CSI Pin Name |
Default Function |
Function2:GPIO |
CN10-P01 |
GND |
CN10-P02 |
MIPI_CSI_D3N |
CN10-P03 |
MIPI_CSI_D3P |
CN10-P04 |
GND |
CN10-P05 |
MIPI_CSI_D2N |
CN10-P06 |
MIPI_CSI_D2P |
CN10-P07 |
GND |
CN10-P08 |
MIPI_CSI_CLKBN |
CN10-P09 |
MIPI_CSI_CLKBP |
CN10-P10 |
GND |
CN10-P11 |
MIPI_CSI_D1N |
CN10-P12 |
MIPI_CSI_D1P |
CN10-P13 |
GND |
CN10-P14 |
MIPI_CSI_D0N |
CN10-P15 |
MIPI_CSI_D0P |
CN10-P16 |
GND |
CN10-P17 |
MIPI_CSI_CLKAN |
CN10-P18 |
MIPI_CSI_CLKAP |
CN10-P19 |
NC |
CN10-P20 |
CAM0_MCLK |
CN10-P21 |
CAM0_IRCUT |
CN10-P22 |
CAM0_SCL |
CN10-P23 |
CAM0_SDA |
CN10-P24 |
CAM0_RESET |
CN10-P25 |
VCC1V8_DOVDD |
CN10-P26 |
GND |
CN10-P27 |
GND |
CN10-P28 |
VCC33 |
CN10-P29 |
VCC33 |
CN10-P30 |
VCC33 |
DSI Pin Name |
Default Function |
Function2:GPIO |
CN9-P01 |
MIPI_D0_N |
CN9-P02 |
MIPI_D0_P |
CN9-P03 |
MIPI_D1_N |
CN9-P04 |
MIPI_D1_P |
CN9-P05 |
MIPI_CLK_N |
CN9-P06 |
MIPI_CLK_P |
CN9-P07 |
MIPI_D2_N |
CN9-P08 |
MIPI_D2_P |
CN9-P09 |
MIPI_D3_N |
CN9-P10 |
MIPI_D3_P |
CN9-P11 |
TP_INT_3V3 |
CN9-P12 |
TP_RST_3V3 |
CN9-P13 |
I2C_M3_SCL_3V3 |
CN9-P14 |
I2C_M3_SDA_3V3 |
CN9-P15 |
LCD_BL_EN_3V3 |
CN9-P16 |
LCD_PWM_3V3 |
CN9-P17 |
GND |
CN9-P18 |
GND |
CN9-P19 |
VLCD_5V |
CN9-P20 |
VLCD_5V |
PoE support RT9600-5V PoE module
| Linux BSP source code : https://github.com/BPI-SINOVOIP/BPI-M2S-bsp |
| BPI-M2S/CM4 Android9 Source Code |
Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 PIN code: 8888
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| Banana PI BPI-M2S Amlogic A311D / S922X : https://www.youtube.com/watch?v=9eFXiOtzFl0 |
| BPI-M2S DXF file |
Baidu Cloud: https://pan.baidu.com/s/1eKLdicH0v_XBkUyX9aVRhw?pwd=ikme PIN code: ikme
| BPI-M2S Schematic diagram |
Baidu Cloud: https://pan.baidu.com/s/1i6VMpHsCEL6Nwxu282epLA?pwd=8888 PIN code: 8888
| Amlogic A311D datasheet: https://drive.google.com/file/d/1SRAY_RDxKhw819uyo9H13zNN2wlG6LDq/view?usp=sharing |
| 2024-04-29-bpi-m2s-cm4-android9.img |
Baidu cloud: https://pan.baidu.com/s/10_vRDmzVobR4grjUbuDbeA?pwd=8888 (pincode:8888)
| 2023-01-12-bpi-m2s-cm4-android9.img |
Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 PIN code: 8888
| 2022-06-20-ubuntu-20.04-mate-desktop-bpi-m2s-aarch64-sd-emmc.img.zip |
Baidu Cloud: https://pan.baidu.com/s/1kRukI-H-xliNqIqVacXWRw?pwd=8888 PIN code: 8888
MD5: 2945f225eadba1b350cd49f47817c0cd
| 2022-06-20-ubuntu-20.04-server-bpi-m2s-aarch64-sd-emmc.img.zip |
Baidu Cloud: https://pan.baidu.com/s/1UoYR0k9YH9SE_A-MpqZ2fg?pwd=8888 PIN code: 8888
MD5: 9b17a00cbc17c46e414a906e659e7ca2
| 2022-06-20-debian-10-buster-bpi-m2s-aarch64-sd-emmc.img.zip |
Baidu Cloud: https://pan.baidu.com/s/1TTsdyy5I7HLWS_Tptg7r2w?pwd=8888 PIN code: 8888
MD5: 9d39558ad37e5da47d7d144c8afec45e
| Armbian official support for BPI-M2S: https://www.armbian.com/bananapi-m2s/ |
| Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_minimal.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1iEO_GcFa6Gy-cC0pnT4H3A?pwd=8888 PIN code: 8888
Google Drive: https://drive.google.com/drive/folders/1TDXuFliLZr4BY7NO5m_ijL4FxjsZNY8a?usp=share_link
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current-minimal/14635
| Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_cinnamon_desktop.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1aqvVJXy1MqSVUHL-DD5Rpw?pwd=8888 (pincode: 8888)
Googel Drive: https://drive.google.com/drive/folders/1MPxwSg38uu0hVllUgqqmxKGsEMpfm-lM?usp=share_link
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-cinnamon-desktop/14642
| Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1j0GVw3-ULFnWUFhwxr7muQ?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1Psku14DtTONHJD-73G58sD7CEoWfk4tT?usp=share_link
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current/14634
| Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_minimal.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1MevqHbBTX8S-fsXuy9SahA?pwd=8888 (pincode: 8888)
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-minimal/14639
| Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_xfce_desktop.img.xz |
Google Drive: https://drive.google.com/drive/folders/1ugybAUZ4W2ov2Xy0yMsc9aTrGIBXVomI?usp=share_link
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current-desktop/14636
| Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_gnome_desktop.img.xz |
Baidu Cloud: https://pan.baidu.com/s/107kO-hGlyWMJFD9vpvKA-g?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/19mLva4UQgON8exl5xuF2T9HD-Wy2eH94?usp=share_link
Discuss on the forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-jammy-current-gnome-desktop/14640
| 2023-01-6 Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14.img.xz |
| BANANAPI Official Shop: https://www.bpi-shop.com/products/bananapi-bpi-m2s-new-design-with-amlogic-a311d.html |
| Sinovoip Aliexpress shop: https://www.aliexpress.com/store/group/BPI-M2S/1100417230_40000003430398.html |
| Bipai Aliexpress shop : https://www.aliexpress.us/item/3256804873308120.html |
| Taobao shop : https://item.taobao.com/item.htm?spm=a1z10.3-c.w4002-5702805387.9.2c3c159aK33lv9&id=695345271372 |
| OEM&ODM, please contact: [email protected] |
