| More Infomation: Banana Pi BPI-M2_Super |
Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug.
Prepare a SDcard at least 8GB for linux development, android only support emmc boot.
The SOC rom first boot media is emmc, so board can’t bootup from SDcard if the emmc is bootable with any image flashed, more info please refer to board boot sequence.
Only A311D variant board have camera, mipi panel and npu support.
Download and install the AML Usb Burning Tool for android image download via type-c, only support windows.
Download the latest android image, and confirm that the md5 checksum is correct.
Open USB_Burning_Tool.exe, select menu File→Import image, choose the android image file aml_upgrade_package.img.
Press and hold USB button on the board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, release the button, the board will be identified correctly.
Click the Start button of the download tool and wait for upgrade complete.
After Burning successfull, Unplug the type-c usb and connect to power supply adaptor to startup.
Click the Stop button to cancel the upgrade process and close the USB Buring Tool.
Aml-flash-tool is a linux platform opensource image flash util for Amlogic android.
Get Android 9.0 source code
git clone https://github.com/BPI-SINOVOIP/BPI-A311D-Android9
Build the Android 9.0 Source code
Bananapi M2S DTBO idx value table, default idx value is 0 in release image.
| Bananapi M2S DTBO idx value table | ||
idx value |
device tree overlay |
description |
0 |
android_p_overlay |
default dtbo, no use |
1 |
wifi_bt_rtl8822cs |
enable bpi rtl8822cs wifi/bt module |
2 |
i2c1 |
enable i2c 1 |
3 |
i2c2 |
enable i2c 2 |
4 |
sdio |
enable sdio |
5 |
uart1 |
enable 2 pins uart 1 |
6 |
uart1_cts_rts |
enable 4 pins uart 1 |
7 |
uart2 |
enable 2 pins uart 2 |
8 |
hifi_pcm5122 |
enable i2s pcm5122 HiFi DAC |
How to apply a new dtbo
ADB command via sysfs
restarting adbd as root
remount succeeded
bananapi_m2s:/ # reboot
Uart console command via sysfs
console:/ $
console:/ $ su
[ 115.702781@0] unifykey: name_store() 1302, name dtbo, 4
[ 115.702856@0] unifykey: name_store() 1311
console:/ #
[ 129.262659@0] unifykey: write_store() is a string
[ 129.262733@0] unifykey: dtbo, 1, 1
[ 129.265312@0] unifykey: amlkey_write 393
[ 129.292347@1] emmc_key_write:149, write ok
console:/ #
console:/ # reboot
Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Default build-in overlays are defined in device/bananapi/bananapi_m2s/Kernel.mk, you can add a new overlay dtbo here.
Default apply DTBO idx is defined in device/bananapi/bananapi_m2s/BoardConfig.mk, you can change the idx value to set which overlay dtbo will be applied default.
DTS files are in common/arch/arm64/boot/dts/amlogic/overlay/bananapi_m2s/
Download install package from OpenGapps, Android release image is arm/android 9.0 variant.
Download device_id.apk.
Copy the OpenGapp package to a udisk or sdcard root directory.
Create a txt file named factory_update_param.aml in udisk or sdcard root directory with the following android recovery parameter content, and replace the file name with the actual downloaded package.
udisk:
--wipe_cache
sdcard:
--wipe_cache
Plugin the udisk or sdcard to the board and poweron.
OpenGapps install and certify.
YouTube Video: https://youtu.be/fXOKmWfpqF8
You can also watch this video on bilibili
The default android release image only support one mipi panel because hw has no detect logic for different panel at boot, so [800x1280 bpi panel] enabled as default, but you can change to [1200x1920 bpi panel] as defualt in Settings→Panel Output
UI Rotation in Settings→Display→Screen rotation
SurfaceFlinger rotation, need modify android source code and build
index 1f51703..d592a44 100644
else
ro.sf.lcd_density=213 \
endif
index 4a698b0..3d41b63 100755
@@ -876,8 +876,8 @@
reg = <0x5d>;
Compress the bmp file to boot-logo.bmp.gz
Download m2s_android_bootlogo_tool.zip
Extract this tool
$ ls -l logo/
Copy the boot-logo.bmp.gz
Create target logo.img with img pack tool, the binary and related libs of m2s_android_bootlogo_tool are copy from <android-source-dir>/out/host/linux-x86
Flash boot logo with fastboot
$ adb root
$ adb remount
$ adb reboot fastboot
$ fastboot device
1234567890 fastboot
$ fastboot reboot
Linux image support SDcard or EMMC bootup.
It’s recommended to use A1 rated cards, 8GB at least.
Make sure bootable EMMC is formatted if you want bootup from SDcard
Make sure SDcard is formatted without Linux image flashed if you want bootup from EMMC and use Sdcard as storage.
Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can’t access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ apt-get install pv
Download Linux latest Linux Image, and confirm that the md5 checksum is correct.
Default login: pi/bananapi or root/bananapi
The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
Install Image with Balena Etcher on Windows, Linux and MacOS.
Click on "Flash from file" to select image. Click on "Select target" to select USB device. Click on "Flash!" Start burning.
Install Image with Balena Cli on Windows, Linux and MacOS.
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 --yes
Install Image with dd command on Linux
Mount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
$ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install image with bpi-tools on Linux
Plug SDcard to Linux PC and run
Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
Copy Linux image to udisk, plug the udisk to board and mount it.
There are two ways to install the linux image to board.
Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
$ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
Install the linux image in udisk with bpi-tools command
After download complete, power off safely and eject the SDcard.
Get the Linux bsp source code
Build the bsp source code
If you want build uboot and kernel separately, please download the u-boot the kernel only, get the toolchains, boot script and other configuration files from BPI-M2S-bsp
DTB overlay is used for 40pin gpios multi-function configuration and install in vfat boot partition, you can check the mount point with mount command.
custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo
ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo
hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo
hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo
i2c1.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo
i2c2.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo
pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Update the overlays env in vfat /boot/env.txt to enable what you want.
# Device Tree Overlays
# uart1 -- Enable UART1 (uart_A, GPIO Header PIN8 & PIN10)
# pwm_c -- Enable PWM_C (GPIO Header PIN7)
# i2c2 -- Enable i2c2 (GPIO Header PIN3 & PIN5)
# spi0 -- Enable SPI0 (GPIO Header PIN19 & PIN21 & PIN23 & PIN24)
overlays="i2c2 spi0 uart1"
Must be restart the board for overlay dtb loaded.
The linux release image is camera disabled default, according to the following configuration, it can be enabled by yourself.
Update the dtb overlays env in /boot/env.txt to enable camera dtbo.
overlays="os08a10"
Add camera modules to /etc/modules
iv009_isp_iq
iv009_isp_lens
iv009_isp_sensor
iv009_isp
Create and add camera modules options to /etc/modprobe.d/os08a10.conf
#choose isp register sequence
Enable camera isp systemd service
# Mipi panel type
# Symbol | Resolution
# "lcd_0" | 10" 800x1280 panel
# "lcd_1" | 10" 1200x1920 panel
panel_type=lcd_0
| Note: Dual display is not work on linux, so disconnect hdmi cable when mipi used. |
Section "Device"
# Rotate off
# Option "Rotate" "off"
Option "Rotate" "CW"
# Option "Rotate" "UD"
# Option "Rotate" "CCW"
EndSection
Section "InputClass"
MatchIsTouchscreen "on"
MatchProduct "goodix-ts"
MatchDriver "libinput"
EndSection
Sysfs dynamically change.
echo 0 > /sys/class/graphics/fbcon/rotate //origin 0 degree
echo 1 > /sys/class/graphics/fbcon/rotate //90 degree
echo 2 > /sys/class/graphics/fbcon/rotate //180 degree
echo 3 > /sys/class/graphics/fbcon/rotate //270 degree
Boot Configuration change.
# Framebuffer Rotate
# 0 - origin 0 degree
# 1 - 90 degree
# 2 - 180 degree
# 3 - 270 degree
fb_rotate=0
| Note: This WiringPi only support set 40pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, …, you must enable dtb overlay in boot.ini |
Build and install wiringPi, for debian, you must install sudo before build
$ sudo apt-get update
$ cd amlogic-wiringPi
$ chmod a+x build
$ sudo ./build
Run gpio readall to show all 40pins status.
BPI GPIO Extend board and examples in amlogic-wiringPi/examples
$ cd RPi.GPIO-Amlogic
Create and install wheel package
Install from git source directly without development
If the package is already installed, it should be uninstalled before installing the new one, or installing the new one with --force-reinstall option.
$ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git
$ cd WiringPi2-Python-Amlogic
Luma.examples use GPIO.BCM gpio mode default, so you should map 40pin header pins to bcm gpio number and connect the hardware correctly.
build and install RPi.GPIO build bananapi m2s RPi.GPIO with python3 instead of python because luma uses python3.
you can change the bcmledpin variable in test/led.py to your hardware backlight gpio and run it to check RPi.GPIO works well.
$ sudo python3 test/led.py
hardware backlight will repeat on and off
luma.examples libs install
if group does not exist, the following command will create it:
$ sudo groupadd --system xxx
$ cd luma.examples
install luma.core, luma.emulator, luma.lcd, luma.le-matrix, luma.oled pip libs, make sure this step without error or downloading interrupted, try again if get errors
$ sudo -H pip install -e .
or
$ sudo -H pip3 install -e .
for debian buster(python 3.7) which does not include /usr/bin/pip in package python3-pip, and will get the following errors when install luma packages with pip3
Using UNIX configuration...
install sdl2 related packages to fix this issue, then install luma libs again with pip3
check installed luma pip libs
$ pip3 list | grep luma
luma.core 2.4.0
luma.emulator 1.4.0
luma.lcd 2.10.0
luma.led-matrix 1.7.0
luma.oled 3.11.0
examples test
$ cd examples
| Bananapi M2 Super Tested HDMI LCD | |
panel |
/boot/boot.ini |
setenv display_autodetect "false" |
Backlight control : https://github.com/Dangku/Waveshare-USB-Brightness
copy the target file to /boot/firmware/ or /boot/ directory.
Rom load bootloader from SDcard (Linux log example)
BL2 Built : 15:21:42, Mar 26 2020. g12a g486bc38 - gongwei.chen@droid11-sz
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 1
fw parse done
PIEI prepare done
fastboot data verify
result: 255
DDR4 probe
Rom load bootloader from EMMC(Android Log example)
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 1
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
00000000
Bootable EMMC with Android image flashed
Using usb burning tool, unplug the type-c usb cable while the download process at 7% formatting
Using Android Fastboot tool, make sure the adb/fastboot tools is work on your PC before doing this.
remount succeeded
1234567890 fastboot
OKAY [ 0.044s]
finished. total time: 0.044s
OKAY [ 0.047s]
finished. total time: 0.047s
erasing 'bootloader'...
OKAY [ 0.059s]
finished. total time: 0.059s
erasing 'bootloader-boot0'...
OKAY [ 0.036s]
finished. total time: 0.036s
erasing 'bootloader-boot1'...
OKAY [ 0.035s]
finished. total time: 0.035s
Using uboot command, connect a debug console cable and press ESC while power on to enter uboot command line
start = 0,end = 57343
start = 221184,end = 30535679
start = 0,end = 8191
bananapi_m2s_v1#reset
resetting ...
These two ways actually erase the bootloader part of EMMC android, After bootup from SDcard Linux, You’d better format the whole EMMC by dd command.
The simplest way is insert the SDcard with Linux image flashed before power on, the Android bootloader will check boot.ini file whether exist in SDcard vfat partition, so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command and then flash the Linux image to EMMC.
BPI: try boot from sdcard
reading boot.ini
Starting boot.ini...
reading env.txt
HDMI: Autodetect: 1080p60hz
reading Image.gz
reading bananapi_m2s.dtb
reading uInitrd
Bootable EMMC with Linux image flashed
Linux u-boot also check boot.ini file whether exist in SDcard vfat partition so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command or flash the Linux image directly to EMMC.
A extreme situation is bootloader or uboot corrupted, Rom load it from EMMC but hangup in u-boot or BL2, for example the boot process will hangup in BL2 of EMMC if dram init failed, The only way is format the EMMC with usb burning tool, or download the Android image completely and then try other ways to erase EMMC or flash Linux image to EMMC.
Rom will try to load bootloader from SDcard directly if EMMC is empty.
$ sync
Android test and support.
rtl8723bu wifi/bt(usb)
rtl8188eu wifi(usb)
rtl8821cu wifi/bt(usb)
rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
| Note: Android is not support that ethernet and wifi are both connected at the same time, Ethernet have a higher prioprity than wifi, it means wifi can’t connect network if ethernet already connected, and wifi will drop connection if ethernet cable plugin. |
Linux test and support.
rtl8188eu wifi(usb)
rtl8192eu wifi(usb)
rtl8811au wifi(usb)
rtl8812au wifi(usb)
rtl8812bu wifi(usb)
How to enable Linux Wifi
USB type: Plug-in the usb dongle to usb host port and driver will be loaded automatically. SDIO/UART type:
Connect the hardware module to 40pin header correctly.
Configure the dtb overlay
overlays="wifi_bt_rtl8822cs"
Add the wifi module name to /etc/modules for loaded automatically next boot.
88x2cs
How to enable Linux Bluetooth
Please download rtk-linux-bt-driver source code, build and install usb or uart rtk linux bluetooth drivers/firmwares to your image.
For USB type, plug-in the usb dongle to usb host port and driver will be loaded automatically.
For UART type, Configure the dtb overlay as the same as wifi before install the bluetooth drivers/firmwares. hci_uart driver will be loaded when rtk-hciuart.service start.
disable or remove cloud-init
or
$ sudo apt purge cloud-init
disable or remove snap
$ sudo apt purge snapd
[Unit]
After=network.target
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
RemainAfterExit=yes
GuessMainPID=no
[Install]
WantedBy=multi-user.target
Alias=rc-local.service
Create /etc/rc.local file.
sudo nano /etc/rc.local
#!/bin/sh
# rc.local
# value on error.
# bits.
exit 0
$ sudo chmod +x /etc/rc.local
$ sudo reboot
$ su root
Password:(enter bananapi)
# apt-get update
# apt-get install sudo
# adduser pi sudo
Set up the repository Update the apt package index and install packages to allow apt to use a repository over HTTPS:
Set up the stable repository
$ echo \
Verify the Docker Engine is installed correctly by running the hello-world image.
$ sudo docker run hello-world
