Banana PI BPI-M2+ is the open source hardware platform, use Alliwnner H3 (option H2+ chip and H5 chip ) chip on board. and mini size only 65mm*65mm,
PBI-M2+ hardware: 1Ghz ARM7 quad-core processor, 1GB DDR3 SDRAM, 8G eMMC flash on board,and SDIO wifi&BT 4.0 module on board.1 Gigabit ethrnet.
BPI-M2+ series run Android,Debian linux,Ubuntu linux, Raspberry Pi image and others image. Banana PI,it can easily run with the game it support 1080P high definition video output and 4K support, the GPIO compatible with Raspberry Pi B+.
| Banana Pi BPI-M2+ not support sata port, so you need use USB for hardisk. |
Allwinner H618 design : Banana Pi BPI-M4 Berry Same size as Raspberry Pi 4B Allwinner H618 design : Banana Pi BPI-M4 Zero Same size as Raspberry Pi Zere W Allwinner A40i design Banana Pi BPI-M2 Berry SBC design Allwinner A40i design Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design Banana Pi BPI-6202 Industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with eMMC onboard Allwinner H3 design: Banana Pi BPI-M2 Zero same size as Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero for IoT design == Key Features |
Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
1GB DDR3
8GB eMMC onboard
HDMI out
WiFi and BT onboard
10/100/1000Mbps Ethernet Port
CSI camera interface
| HardWare Specification of Banana Pi M2+(Plus) | |
CPU |
H3 Quad-core Cortex-A7 H.265/HEVC 4K |
GPU |
Mali400MP2 GPU @600 MHz,Supports OpenGL ES 2.0 |
Memory |
1GB DDR3 (shared with GPU |
Flash |
8GB eMMC flash onboard |
Network |
10/100/1000 Ethernet |
WIFI&BT |
K016/SDIO AP6212 for Wifi &BT 4.0(option AP6181 AP6335) |
Video Input |
A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL, 3 Supports SM pixel camera sensor, 4 Supports video capture solution up to 1080p@30fps |
Video Outputs |
Supports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function, Integrated CVBS, Supports simultaneous output of HDMI and CVBS |
Audio Outputs |
HDMI |
Power |
5V/2A DC input can supply power, but USB OTG input don’t supply power |
USB 2.0 ports |
two USB 2.0 HOST, one USB 2.0 OTG |
GPIO |
40 Pins Header,compatible with Raspberry Pi B+ |
LED |
Power led & Status led |
IR |
IR input on board |
OS |
Android, Ubuntu, Debian, Raspberry Pi Image |
| 40 PIN GPIO of Banana pi BPI-M2+(Plus) | |||
GPIO Pin Name |
Default Function |
Function2:GPIO |
Function3 |
CON2-P01 |
VCC-3V3 |
CON2-P02 |
VCC-5V |
CON2-P03 |
TWI0-SDA |
PA12-EINT12 |
CON2-P04 |
VCC-5V |
CON2-P05 |
TWI0-SCK |
PA11-EINT11 |
CON2-P06 |
GND |
CON2-P07 |
PWM1 |
PA6-EINT6 |
CON2-P08 |
UART3-TX |
PA13-EINT13 |
SPI1-CS |
CON2-P09 |
GND |
CON2-P10 |
UART3-RX |
PA14-EINT14 |
SPI1-CLK |
CON2-P11 |
UART2-RX |
PA1-EINT1 |
CON2-P12 |
UART3-CTS |
PA16-EINT16 |
SPI1-MISO |
CON2-P13 |
UART2-TX |
PA0-EINT0 |
CON2-P14 |
GND |
CON2-P15 |
UART2-CTS |
PA3-EINT3 |
CON2-P16 |
UART3-RTS |
PA15-EINT15 |
SPI1-MOSI |
CON2-P17 |
VCC-3V3 |
CON2-P18 |
PC4 |
PC4 |
CON2-P19 |
SPI0-MOSI |
PC0 |
CON2-P20 |
GND |
CON2-P21 |
SPI0-MISO |
PC1 |
CON2-P22 |
UART2-RTS |
PA2-EINT2 |
CON2-P23 |
SPI0-CLK |
PC2 |
CON2-P24 |
SPI0-CS |
PC3 |
CON2-P25 |
GND |
CON2-P26 |
PC7 |
PC7 |
CON2-P27 |
TWI1-SDA |
PA19-EINT19 |
CON2-P28 |
TWI1-SCK |
PA18-EINT18 |
CON2-P29 |
PA7-EINT7 |
PA7-EINT7 |
CON2-P30 |
GND |
CON2-P31 |
PA8-EINT8 |
PA8-EINT8 |
CON2-P32 |
PL2-S-EINT2 |
PL2-S-EINT2 |
CON2-P33 |
PA9-EINT9 |
PA9-EINT9 |
CON2-P34 |
GND |
CON2-P35 |
PA10-EINT10 |
PA10-EINT10 |
CON2-P36 |
PL4-S-EINT4 |
PL4-S-EINT4 |
CON2-P37 |
PA17-EINT17 |
PA17-EINT17 |
SPDIF-OUT |
CON2-P38 |
PA21-EINT21 |
PA21-EINT21 |
CON2-P39 |
GND |
CON2-P40 |
PA20-EINT20 |
PA20-EINT20 |
| CSI Camera PIN of Banana pi BPI-M2+(Plus) | ||
CSI Pin Name |
Default Function |
Function2:GPIO |
CN3-P01 |
NC |
CN3-P02 |
GND |
CN3-P03 |
CSI0-SDA |
PE13 |
CN3-P04 |
CSI0-AVDD |
CN3-P05 |
CSI0-SCK |
PE12 |
CN3-P06 |
CSI0-Reset |
PE14 |
CN3-P07 |
CSI0-VSYNC |
PE3 |
CN3-P08 |
CSI0-PWDN |
PE15 |
CN3-P09 |
CSI0-HSYNC |
PE2 |
CN3-P10 |
CSI0-DVDD |
CN3-P11 |
CSI0-DOVDD |
CN3-P12 |
CSI0-D7 |
PE11 |
CN3-P13 |
CSI0-MCLK |
PE1 |
CN3-P14 |
CSI0-D6 |
PE10 |
CN3-P15 |
GND |
CN3-P16 |
CSI0-D5 |
PE9 |
CN3-P17 |
CSI0-PCLK |
PE0 |
CN3-P18 |
CSI0-D4 |
PE8 |
CN3-P19 |
CSI0-D0 |
PE4 |
CN3-P20 |
CSI0-D3 |
PE7 |
CN3-P21 |
CSI0-D1 |
PE5 |
CN3-P22 |
CSI0-D2 |
PE6 |
CN3-P23 |
GND |
CN3-P24 |
CSI0-DOVDD |
CON3 P03 |
UART0-TXD |
PA4 |
CON3 P02 |
UART0-RXD |
PA5 |
CON3 P01 |
GND |
BPi-M2+ V1.2 modification
PL0 Instead the drop-down 10K,As a hardware version identification(V1.1 is pull up)
PL1 Change to voltage regulation GPIO
| Linux kernel 4.4 on github : https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4 |
| Linux kernel 3.4 on github : https://github.com/BPI-SINOVOIP/BPI-M2P-bsp |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| How To Change The Boot Logo: http://forum.banana-pi.org/t/how-to-change-the-boot-logo/7660 |
| BPI-M2+ V1.2 schematic diagram: |
Google drive: google driver
Baidu cloud : https://pan.baidu.com/s/1vjBURLzFF2LYCe8CBcs9Mg
| BPI-M2+ V1.1 schematic diagram: https://drive.google.com/file/d/0B4PAo2nW2KfnMW5sVkxWSW9qa28/view?usp=sharing |
| DXF file google download link :BPI-M2+ DXF file |
| 3D design file google download link: BPI-M2+ 3D design |
| BPI-M2+ BT Lab test :BPI-M2+ BT Lab test report |
| BPI-M2+ WIFI Lab test :BPI-M2+ WIFI Lab test report |
| Validation test :BPI-M2+ validation test report |
| CE FCC RoHS : BPI-M2+ CE,FCC,RoHS |
| Allwinner documents: |
Allwinner H3 chip doc baidu link: https://pan.baidu.com/s/1qTULll2CR02d0Hw9itq1rw
Allwinner H2+ chip doc baidu link: https://pan.baidu.com/s/1TGMYr3rhizfhlg5hl6hLyg
| Banana Pi M2 Plus - Unboxing e apresentacao da placa.: https://www.youtube.com/watch?v=_87uHfyMIUA&feature=youtu.be |
| Sinovoip Banana Pi M2+ - linux-sunxi.org wiki : http://linux-sunxi.org/Sinovoip_Banana_Pi_M2%2B |
| 2018-10-20 android 7.0 share by https://www.facebook.com/vitor1104 |
Image download link : http://setordigital.blogspot.com/2018/10/android-70-nougat-para-banana-pi-m2.html
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2-new-image-android-7-0-nougat-2018-10-20/7082
| 2018-06-30 update HDMI-Version |
Baidu Drive : https://pan.baidu.com/s/1ETpbauIezp1228n7kdWo4A
Forum thread: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-image-android7-0-release-2018-6-30/6147
How to Google registration: https://www.google.com/android/uncertified/ Android7.0 needs to register devices by youself
| H3Droid 1.3.5 version image download: https://h3droid.com/download |
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim2plus_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/19xg6YfySrUR6jclXYrzdOg?pwd=qfys PIN code: qfys
| Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10 |
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-new-image-ubuntu-16-04-with-allwinner-bsp-use-mpv-play-1080p-video/13272
| 2020-04-23 update, Ubuntu 16.04 Mate Desktop, Ubuntu 16.04 Server, kernel 4.4 |
Baidu cloud: https://pan.baidu.com/s/1Tay4F7nJJV1MzI_aO4NjHw PIN code: ih9p
| 2018-11-09 update ,Ubuntu 16.04,kernel 4.4. |
Baidu Drive : https://pan.baidu.com/s/1RHZ-b7PcY9ybeiy95C_VIg
Md5 : 59f2cc29ce045c15e51fac20ff6924aa
Forum pthread: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-demo-images-release-with-kernel-4-4-2018-11-09/7210
| 2018-5-17 update : Ubuntu 16.04 V1.1 new eMMC and PMU support, base on kernel 3.4 |
Baidu cloud : https://pan.baidu.com/s/1Jf-AZF6a4jZugqqx2QXH3Q
Forum thread: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
| 2018-01-02 update : Ubuntu image, base on Kernel 4.4 |
| 2017-07-14 update : ubuntu-16.04-mate-desktop, base on kernel 3.4 |
Baidu cloud : http://pan.baidu.com/s/1dEX2TDR
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim2plus_bullseye_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1prE9mlVuErHidWNJFynKzA?pwd=8ikd PIN code: 8ikd
| 2019-09-18 update,Banana Pi BPI-M2+ boot debian 10 with grub (u-boot-2019.07 + kernel 5.1.1) |
| 2018-11-09 update ,Debian 9, kernel 4.4. |
Baidu Drive : https://pan.baidu.com/s/1h3TSAzY8ootahOjxkoTG1Q
Md5 : f979f1a68d759e804e0a90654f4577f1
| 2018-11-09 update ,Raspbian 9, kernel 4.4. |
Baidu Drive : https://pan.baidu.com/s/1g5Suk-Ybd3jdhdX82llBwg
Md5 : 53ec3986ec3df84fa2548d0742f700fa
Fourm pthread : http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-demo-images-release-with-kernel-4-4-2018-11-09/7210
| 2018-5-22 update : Raspbian jessie 8.0 kernel 3.4 |
Baidu cloud : https://pan.baidu.com/s/16KJbtwjT_PBCZJkYV79_ag
Forum thread: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-raspbian-jessie-8-0-2018-5-22/5788
| 2018-5-22 update : Raspbian 8.0 V1.1 new eMMC and PMU |
| Armbain have support BPI-M2+,Armbian Bionic and Armbian Stretch version |
Image download : https://www.armbian.com/banana-pi-m2-plus/
| Armbian Xenial and Armbian Jessie |
Armbin image download: https://www.armbian.com/banana-pi-m2-plus/
| Image from Banana Pi team, released on 2023-07, Armbian_23.02.0 |
Baidu Cloud: https://pan.baidu.com/s/1v0JVs50LCqLuioi9I7fGpw?pwd=8888 PIN code: 8888
| Image from Banana Pi team, released on 2023-07, Armbian_23.08.0 |
Baidu Cloud: https://pan.baidu.com/s/1UMfEkiWdsnV4Lun0wbu17A?pwd=8888 PIN code: 8888
| 23.02.0 update,bullseye_current_5.15.93,bullseye_edge_6.0.10_xfce_desktop, jammy_edge_6.1.11_xfce_desktop.img |
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
| 2022-12-06 Armbian_22.11.0-trunk_Bananapim2plus_bullseye_edge_6.0.9.img.xz |
Baidu Cloud: https://pan.baidu.com/s/11z-4c1Gj74D7hrT7R-_xhg?pwd=8888 PIN code: 8888
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-plus-new-image-release-armbian-bullseye/14449
| Armbian 5.51 debin Bananapi-m2+ build by BPI 2018-07-12 |
Google download : https://drive.google.com/open?id=1H_KEVWTRwgSgal5gt8jKqBT-y4IqIX84
Baidu download : https://pan.baidu.com/s/1OaBRKHPGqjgat0mntHyYxg
| OpenSUSE have official support Banana Pi BPI-M2+ |
Image download : http://download.opensuse.org/ports/armv7hl/factory/images/
| Openelec Kodi 16.0 (xbmc) |
File name: http: OpenELEC-H3.arm-7.0-devel-20161026220508-r23113-g64b34b3-bpim2p.img.gz
Download link: http://down.nu/images/2016-10-26
Baidu cloud: http://pan.baidu.com/s/1mhMTEnI
| FreeBSD on Allwinner (sunxi) systems for banana pi |
Allwinner A20 (sun7i), a dual-core Cortex-A7 BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 BPI-M2
Allwinner A64 (sun50i), a quad-core Cortex-A53 BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 BPI-M2+/BPI-M2+ EDU/
Banana Pi M2+ with H3 chip
Banana Pi M3 with A83T chip
BPI-M1 and BPI-M1+ use A20 chip
| Dietpi have official support BPI-M2+ : http://forum.banana-pi.org/t/dietpi-have-official-support-bpi-m2/1882 |
| RetroPie for Banana Pi BPI-M2+/M2 Zero v.1.2.1 beta |
| Retrorangepi support BPI-M2+ BPI-M2 Zero : http://retrorangepi.download/download/index2.html |
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-m2.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Plus/1100417230_40000003593415.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Plus/1101951077_40000003585461.html |
| OEM&ODM, please contact: [email protected] |
