Banana Pi BPI-M4 Zero is the successor model of M2 Zero. It has a huge improvement in performance. The SOC is upgraded to H618 and the CPU frequency is increased by 25%. The memory is upgraded to DDR4, the capacity is eightfold, and 32G eMMC is added. It supports 5G WiFi(The WiFi chip of K016 does not support 5G WiFi), and the USB interface has also been upgraded to type-C.
It has same form factor and 40-pin connector as the Raspberry Pi Zero W, and it can fit most of the RPI Zero W cases and accessories.
Allwinner A733 design : Banana Pi BPI-M8 Same size as Raspberry Pi 5 Allwinner H618 design : Banana Pi BPI-M4 Berry Same size as Raspberry Pi 4B Allwinner H618 design : Banana Pi BPI-M4 Zero Same size as Raspberry Pi Zere W Allwinner A40i design Banana Pi BPI-M2 Berry SBC design Allwinner A40i design Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design Banana Pi BPI-6202 Industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with eMMC onboard Allwinner H3 design: Banana Pi BPI-M2 Zero same size as Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero for IoT design |
Allwinner H618, Quad-core ARM Cortex™-A53 processor
ARM Mali G31 GPU
2.4G/5G WIFI & Bluetooth 5.0(K019 module is wifi5, K016 module is wifi4.The WiFi chip of K016 does not support 5G WiFi.)
2G/4G LPDDR4 RAM
8G/32G eMMC flash memory
1x USB2.0 Type-C OTG, 5V power supply
1x USB2.0 Type-C
1x miniHDMI 2.0a
1x 24-pin FPC connector
1x USB2.0 (in FPC connector)
1x 100Mbps Ethernet (in FPC connector)
| Hardware Specification of Banana pi BPI-M4 Zero | |
CPU |
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz |
GPU |
ARM Mali G31 GPU |
Memory |
2G/4GB LPDDR4 |
Storage |
8G/32G eMMC flash |
SD card |
MicroSD card slot, SDIO3.0 |
Wireless |
2.4G/5G WiFi and Bluetooth 5.0(The WiFi chip of K016 does not support 5G WiFi) |
HDMI |
1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output |
USB |
1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG |
40-pin header |
28 pins GPIO and Power (+5V, +3.3V and GND) |
UART, SPI, TWI/I²C, PWM, PCM/I²S |
24-pin FPC |
0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet |
9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S |
Buttons |
Reset, FEL |
LED |
Power Status and Activity status |
Power |
5V@3A via USB Type-C |
Size |
65mm × 30mm |
Weight |
| 40 PIN GPIO of Banana pi BPI-M4 Zero | |||
Pin Num |
Pin Name |
1 |
3.3V |
2 |
5V |
3 |
TWI0_SDA |
PI6_ENT6 |
4 |
5V |
5 |
TWI0_SCL |
PI5_ENT5 |
6 |
GND |
7 |
PWM2 |
PI12_EINT12 |
8 |
UART4_TX |
PI13_EINT13 |
9 |
GND |
10 |
UART4_RX |
PI14_EINT14 |
11 |
PH2 |
UART5_TX |
12 |
H_IISO_BCLK |
PI1 |
DMIC_D0 |
13 |
PH3 |
UART5_RX |
14 |
GND |
15 |
PH11 |
16 |
UART4_RTS |
PI15_EINT15 |
17 |
3.3V |
18 |
UART4_CTS |
PI16_EINT16 |
19 |
PH7 |
SPI_MOSI |
20 |
GND |
21 |
PH8 |
SPI_MISO |
22 |
3.3V |
23 |
PH6 |
SPI_CLK |
24 |
PH5 |
SPI_CS0 |
25 |
GND |
26 |
PH9 |
SPI_CS1 |
27 |
TWI1_SDA |
PI8_ENT8 |
28 |
TE1_SLC |
PI7_ENT7 |
29 |
PI10 |
30 |
GND |
31 |
PI9 |
32 |
SPDIF_OUT |
33 |
IR_RX |
34 |
GND |
35 |
H_IIS0_LRCLK |
PI2 |
DMIC_D1 |
36 |
3.3V |
37 |
H_IIS0_MCLK |
PI0 |
DMIC_CLK |
38 |
H_IIS0_DIN0 |
PI4 |
DMIC_D3 |
39 |
GND |
40 |
H_IIS0_DOUT0 |
PI3 |
DMIC_D2 |
| 24 PIN FPC define and GPIO Alternative Functions Assignments | |
Pin Num |
Pin Name |
1 |
AP_RESET |
2 |
GND |
3 |
EPHY_RXN |
4 |
EPHY_RXP |
5 |
EPHY_TXN |
6 |
EPHY_TXP |
7 |
GND |
8 |
1.8V |
9 |
1.8V |
10 |
1.8V |
11 |
1.8V |
12 |
GND |
13 |
HP_R |
14 |
HP_L |
15 |
GND |
16 |
TV_OUT |
17 |
GND |
18 |
USB_DP |
19 |
USB1_DM |
20 |
5V |
21 |
5V |
22 |
USB2_DP |
23 |
USB2_DM |
24 |
GND |
1 |
GND |
2 |
UART0_RX |
3 |
UART0_TX |
| Android source code https://github.com/BPI-SINOVOIP/BPI-H618-Android12 |
Bananapi Armbian build source code https://github.com/BPI-SINOVOIP/armbian-build/tree/bpi-v24.11.01
Upstream Armbian build source code https://github.com/armbian/build
WringPi source code https://github.com/Dangku/WiringPi
RPi.GPIO source code https://github.com/Dangku/RPi.GPIO
WiringPi-Python source code https://github.com/Dangku/WiringPi-Python
| BPI-M4 Zero Hardware introduction video: https://www.youtube.com/watch?v=23J_TfsB480 |
| BPI-M4 Zero DXF file |
Baidu cloud: https://pan.baidu.com/s/18T7dzArOhys3QVpyiKH7Og?pwd=8888 (pincode:8888)
| BPI-M4 ZERO Schematic diagram |
Baidu cloud: https://pan.baidu.com/s/1kceiTekfFvYFsXrLiQrxQA?pwd=8888 (pincode: 8888)
| BPI-M4 Zero SBC bench test |
| Allwinner H618 Datasheet |
Baidu Cloud: https://pan.baidu.com/s/10Rk4xLMOhIkk-gIoQx9DQw?pwd=8888 PIN code:8888
| Banana Pi BPi-M4 Zero recenzija: https://magazinmehatronika.com/banana-pi-bpi-m4-zero-recenzija/ |
| 2026-04-08-bananapi-m4zero-android12 |
baidu : https://pan.baidu.com/s/1zApiM3IrWN9S3QEGmRXxuA?pwd=8888 (pincode: 8888)
| 20241011-Bananapi-Armbian_24.8.2-trunk_Bpi-m4zero_Ubuntu22.04 |
Baidu cloud: https://pan.baidu.com/s/14d-s9O2cJco9fFsBUcUYoQ?pwd=8888 (pincode: 8888)
| 20241011-Bananapi-Armbian_24.8.2-trunk_Bpi-m4zero_Debian12 |
Baidu could: https://pan.baidu.com/s/1MFQE8zJVXeUKV9ZHeznWpA?pwd=8888 (pincode: 8888)
| 2026 Armbian Image |
| BANANAPI Official Shop: https://www.bpi-shop.com/products/anana-pi-bpi-m4-zero.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.us/item/1005006325178305.html |
| Bipai Aliexpress Shop: https://www.aliexpress.us/item/1005006325280213.html |
| Taobao Shop: https://item.taobao.com/item.htm?spm=a21dvs.23580594.0.0.4fee3d0dOP5VBH&ft=t&id=754939469582 |
| OEM&ODM, please contact: [email protected] |
