The BPI-M4 Berry development board stands as a powerful Single Board Computer (SBC), harnessing the capabilities of the Allwinner H618 System-on-Chip (SoC) to provide developers with impressive performance and a wealth of features. Similar to the Raspberry Pi 4b, the BPI-M4 Berry boasts comparable CPU prowess, LPDDR4 memory support, integrated WiFi and Bluetooth functionalities, and a familiar 40-pin header layout, alongside 4 USB interfaces and a GbE RJ45 port.
Characterized by its robust performance, versatile features, and remarkable image processing capabilities, stands as an exemplary SBC development platform for professionals within the embedded and computing industries. Equipped with 8GB eMMC flash storage, high-performance decoding and encoding capabilities, and an array of interface options, it caters to a wide spectrum of application domains, including media processing, IoT, and entertainment. Whether catering to novices or seasoned developers, the BPI-M4 Berry development board offers an ideal toolset for realizing creative visions and project objectives.
Allwinner A733 design : Banana Pi BPI-M8 Same size as Raspberry Pi 5 Allwinner H618 design : Banana Pi BPI-M4 Berry Same size as Raspberry Pi 4B Allwinner H618 design : Banana Pi BPI-M4 Zero Same size as Raspberry Pi Zere W Allwinner A40i design Banana Pi BPI-M2 Berry SBC design Allwinner A40i design Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design Banana Pi BPI-6202 Industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with eMMC onboard Allwinner H3 design: Banana Pi BPI-M2 Zero same size as Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero for IoT design |
Allwinner H618, Quad-core ARM Cortex™-A53 processor
ARM Mali G31 GPU
WIFI & Bluetooth
2G LPDDR4 RAM
8G eMMC flash memory
1x USB2.0 Type-C OTG, 5V power supply
4x USB2.0 Type-A
1x HDMI 2.0a
1x 3.5mm Audio & TVE jack socket
1x GbE Ethernet port
| HardWare Specification of Banana Pi BPI-M4 Berry | |
CPU |
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz |
GPU |
ARM Mali G31 GPU |
Memory |
2 GB LPDDR4 |
Storage |
8G eMMC flash |
SD card |
MicroSD card slot |
Wireless |
2.4G/5G WiFi and Bluetooth 4.2 |
Ethernet |
1x GbE Ethernet port(supports PoE with add-on PoE HAT) |
HDMI |
1x full-size HDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output |
Audio |
1x 3.5mm Audio & TVE jack socket |
IR |
1x CIR |
USB |
4x USB2.0 Type-A HOST, 1x USB2.0 Type-C OTG |
GPIO |
40-pin header, 28 pins GPIO and Power (+5V, +3.3V and GND) |
UART, SPI, TWI/I²C, PWM, PCM/I²S |
Buttons |
Reset, FEL and User |
LED |
Power Status and Activity status |
Power |
5V@3A via USB Type-C |
Size |
88x58 mm (Including the interface on the board) PCB size:85mm*56mm |
Weight |
60g |
| module | Raspberry Pi 4B | Banana Pi BPI-M4 Berry |
CPU |
1.5GHz Quad-Core BroadcomBCM2711(Cortex A72) |
H618,64 Bit Cortex™-A53 Quad-Core |
GPU |
500 MHz VideoCore Vl |
ARM Mali G31 GPU |
Memory (SDRAM) |
1-4GB DDR4 |
2GB LPDDR4(up to 4G) |
Onboard Storage |
MicroSD (TF) card |
MicroSD (TF) card / MMC card slot ,eMMC 8GB |
Network |
10/100/1000 Ethernet |
Onboard WIFI &BT |
IEEE 802.11a/b/g/n/ac & BT5.0 |
IEEE 802.11a/b/g/n/ac & BT4.2 |
Display |
HDMI |
HDMI |
Camera |
N/A |
N/A |
Video Outputs |
2*Micro-HDMI |
HDMI 2.0a 4K@60fps |
Audio Output |
3.5 mm Jack and HDMI |
Audino In |
N/A |
N/A |
GPIO |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus |
Remote |
N/A |
IR reciever |
USB Ports |
2 * USB3.0+2 * USB2.0 |
2 * USB 2.0 1* USB Otg |
Buttons |
N/A |
Reset button, User button, Uboot button |
LED |
Power led Status led |
Power led Status led Wifi led |
Power |
DC 5V/3A |
DC 5V/3A |
Board Size |
88mmx58mm |
88mmx58mm |
| 40 PIN GPIO of Banana pi BPI-M4 Berry | |||||
Pin Num |
Pin Name |
ALT0 |
ALT1 |
ALT2 |
ALT3 |
1 |
3.3V |
2 |
5V |
3 |
PG16 |
UART2_RX |
TWI4_SDA |
4 |
5V |
5 |
PG15 |
UART2_TX |
TWI4_SCK |
6 |
GND |
7 |
PG19 |
PWM1 |
8 |
PG6 |
UART1_TX |
9 |
GND |
10 |
PG7 |
UART1_RX |
11 |
PH2 |
UART5_TX |
PWM2 |
12 |
PG11 |
H_I2S2_BCLK |
13 |
PH3 |
UART5_RX |
PWM1 |
14 |
GND |
15 |
PG2 |
16 |
PG8 |
UART1_RTS |
17 |
3.3V |
18 |
PG9 |
UART1_CTS |
19 |
PH7 |
UART2_RTS |
H_I2S3_LRCK |
SPI1_MOSI |
20 |
GND |
21 |
PH8 |
UART2_CTS |
H_I2S3_DOUT0 |
SPI1_MISO |
H_I2S3_DIN1 |
22 |
PG1 |
23 |
PH6 |
UART2_RX |
H_I2S3_BCLK |
SPI1_CLK |
24 |
PH5 |
UART2_TX |
H_I2S3_MCLK |
SPI1_CS0 |
25 |
GND |
26 |
PH9 |
H_I2S3_DIN0 |
SPI1_CS1 |
H_I2S3_DOUT1 |
27 |
PG18 |
UART2_CTS |
TWI3_SDA |
28 |
PG17 |
UART2_RTS |
TWI3_SCK |
29 |
PG3 |
30 |
GND |
31 |
PG4 |
32 |
PG0 |
33 |
PG5 |
34 |
GND |
35 |
PG12 |
H_I2S2_LRCK |
36 |
PH4 |
37 |
PG10 |
H_I2S2_MCLK |
38 |
PG14 |
H_I2S2_DIN0 |
H_I2S2_DOUT1 |
39 |
GND |
40 |
PG13 |
H_I2S2_DOUT0 |
H_I2S2_DIN1 |
1 |
GND |
2 |
UART0_RX |
3 |
UART0_TX |
| BPI-H618-Android12-Code |
Baidu Cloud: https://pan.baidu.com/s/1yMlLXauxZywujH8WkYqEcQ?pwd=8888 PIN code:8888
Android source code https://github.com/BPI-SINOVOIP/BPI-H618-Android12
Bananapi Armbian build source code https://github.com/BPI-SINOVOIP/armbian-build/tree/bpi-v24.11.01
Official Armbian Upstream build source code https://github.com/armbian/build
WringPi source code https://github.com/Dangku/WiringPi
RPi.GPIO source code https://github.com/Dangku/RPi.GPIO
WiringPi-Python source code https://github.com/Dangku/WiringPi-Python
| BPI-M4 Berry Allwinner H618 SBC burn Ubuntu desktop image, youtube video: https://www.youtube.com/watch?v=GAZsUDYL0DE |
| BPI-M4 Berry Schematic diagram |
Baidu cloud: https://pan.baidu.com/s/18jV5XOVoECraDpSWlYd1iA?pwd=8888 PIN code: 8888
| BPI-M4 Berry DXF file |
Baidu cloud: https://pan.baidu.com/s/1lgmPfwqR-B9Pg7ET7NavKw?pwd=8888 (pincode: 8888)
| BPI-M4 Berry SBC bench test: http://forum.banana-pi.org/t/bpi-m4-sbc-bench-test/9469 |
| Allwinner H618 Datasheet |
Baidu Cloud: https://pan.baidu.com/s/10Rk4xLMOhIkk-gIoQx9DQw?pwd=8888 PIN code:8888
| UglyScale Press — Banana-Pi BPi-M4 Berry: https://www.youtube.com/watch?v=tnmaHl7v82Y |
| Bananapi BPI-M4 Berry support Waveshare 4inch 720x720 screen Test video: https://www.youtube.com/watch?v=CRcjx6_29rA&t=75s |
| 2024-08-19-bananapi-m4berry-android12 |
Baidu cloud: https://pan.baidu.com/s/1Dc6-tVgzE3k1W5sY2KDrmA?pwd=8888 (pincode: 8888)
| 20241011-Bananapi-Armbian_24.8.2-trunk_Bpi-m4berry_Ubuntu22.04 |
Baidu cloud: https://pan.baidu.com/s/16-kB50jYfEdmFpG1av0BJw?pwd=8888 (pincode: 8888)
| 20241011-Bananapi-Armbian_24.8.2-trunk_Bpi-m4berry_Debian12 |
Baidu cloud: https://pan.baidu.com/s/1B2tEtHEyom0pO5a5RSroaw?pwd=8888 (pincode: 8888)
NOTE:202608 image
Baidu cloud: https://pan.baidu.com/s/1zvaIDmNV3Q_2npxJqkXqXg?pwd=8888 code: 8888
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-m4-berry.html |
| SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006212355480.html?spm |
| Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006212128000.html?gatewayAdapt=glo2usa |
| Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.11.489155c8Addsck&id=747425760994 |
| OEM&ODM, please contact: [email protected] |
