Banana Pi BPI-P2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H3/H2+ processor(Option : H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It’s ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
Banana Pi BPI-P2 Maker, base on BPI-P2 ZERO, without 8GB eMMC/ Wifi & Bluetooth/40PIN GPIO, all other functions are same as BPI-P2 ZERO.
Allwinner A733 design : Banana Pi BPI-M8 Same size as Raspberry Pi 5 Allwinner H618 design : Banana Pi BPI-M4 Berry Same size as Raspberry Pi 4B Allwinner H618 design : Banana Pi BPI-M4 Zero Same size as Raspberry Pi Zere W Allwinner A40i design Banana Pi BPI-M2 Berry SBC design Allwinner A40i design Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design Banana Pi BPI-6202 Industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with eMMC onboard Allwinner H3 design: Banana Pi BPI-M2 Zero same size as Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero for IoT design |
CPU: Allwinner H3/H2+, Quad-core Cortex-A7.
512MB DDR 3 SDRAM.
WiFi (AP6212/K016) & BT onboard.
Mini HDMI.
40 PIN GPIO,includes UART, SPI, I2C, IO etc
100M LAN
IEEE 802.3af PoE standard PoE module support
8G eMMC flash onboard.
Add 8G eMMC flash support onboard, easy to do IoT gateway.
BPI-P2 Zero with 100M LAN interface ,BPI-M2 Zero with PIN define for 100M lan , use way is same.
PoE function support on board.
| HardWare Specification of Banana Pi P2 Zero | |
Module |
Banana Pi BPI-P2 Zero |
CPU |
Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC |
GPU |
Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 |
Memory \(SDRAM\) |
512M DDR3(shared with GPU) |
Onboard Storage |
TF card \(Max. 64GB\) |
Onboard Network |
100M LAN |
PoE power |
PoE function support |
Onboard flash |
8G eMMC |
Onboard WIFI |
K016/SDIO AP6212(option AP6181、AP6335) |
Video decoding |
1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 |
Video input |
A CSI input connector Camera |
Video Outputs |
mini HDMI 1.4,1080P@30fps, DHCP |
Audio Output |
Mini HDMI |
Power Source |
Micro USB with 5V/2A or PoE power |
USB 2.0 Ports |
one USB 2.0 OTG |
Buttons |
Power Button, Reset Button |
Low-level peripherals |
40 Pins Header,compatible with Raspberry Pi 3 |
uart GPIO\(1x3\) pin |
UART, ground |
LED |
Power led & Status led |
IR |
N/A |
Supported OS |
android linux |
Product size |
65mm X 52.5mm |
Weight |
30g |
| 40 PIN GPIO of Banana pi BPI-P2 Zero | |||
GPIO Pin Name |
Default Function |
Function2:GPIO |
Function3 |
CON2-P01 |
VCC-3V3 |
CON2-P02 |
VCC-5V |
CON2-P03 |
TWI0-SDA |
PA12-EINT12 |
CON2-P04 |
VCC-5V |
CON2-P05 |
TWI0-SCK |
PA11-EINT11 |
CON2-P06 |
GND |
CON2-P07 |
PWM1 |
PA6-EINT6 |
CON2-P08 |
UART3-TX |
PA13-EINT13 |
SPI1-CS |
CON2-P09 |
GND |
CON2-P10 |
UART3-RX |
PA14-EINT14 |
SPI1-CLK |
CON2-P11 |
UART2-RX |
PA1-EINT1 |
CON2-P12 |
UART3-CTS |
PA16-EINT16 |
SPI1-MISO |
CON2-P13 |
UART2-TX |
PA0-EINT0 |
CON2-P14 |
GND |
CON2-P15 |
UART2-CTS |
PA3-EINT3 |
CON2-P16 |
UART3-RTS |
PA15-EINT15 |
SPI1-MOSI |
CON2-P17 |
VCC-3V3 |
CON2-P18 |
PC4 |
PC4 |
CON2-P19 |
SPI0-MOSI |
PC0 |
CON2-P20 |
GND |
CON2-P21 |
SPI0-MISO |
PC1 |
CON2-P22 |
UART2-RTS |
PA2-EINT2 |
CON2-P23 |
SPI0-CLK |
PC2 |
CON2-P24 |
SPI0-CS |
PC3 |
CON2-P25 |
GND |
CON2-P26 |
PC7 |
PC7 |
CON2-P27 |
TWI1-SDA |
PA19-EINT19 |
CON2-P28 |
TWI1-SCK |
PA18-EINT18 |
CON2-P29 |
PA7-EINT7 |
PA7-EINT7 |
CON2-P30 |
GND |
CON2-P31 |
PA8-EINT8 |
PA8-EINT8 |
CON2-P32 |
PL2-S-EINT2 |
PL2-S-EINT2 |
CON2-P33 |
PA9-EINT9 |
PA9-EINT9 |
CON2-P34 |
GND |
CON2-P35 |
PA10-EINT10 |
PA10-EINT10 |
CON2-P36 |
PL4-S-EINT4 |
PL4-S-EINT4 |
CON2-P37 |
PA17-EINT17 |
PA17-EINT17 |
SPDIF-OUT |
CON2-P38 |
PA21-EINT21 |
PA21-EINT21 |
CON2-P39 |
GND |
CON2-P40 |
PA20-EINT20 |
PA20-EINT20 |
| 24 PIN CSI Camera connector of Banana pi BPI-P2 Zero | ||
CSI Pin Name |
Default Function |
Function2:GPIO |
CN3-P01 |
NC |
CN3-P02 |
GND |
CN3-P03 |
CSI0-SDA |
PE13 |
CN3-P04 |
CSI0-AVDD |
CN3-P05 |
CSI0-SCK |
PE12 |
CN3-P06 |
CSI0-Reset |
PE14 |
CN3-P07 |
CSI0-VSYNC |
PE3 |
CN3-P08 |
CSI0-PWDN |
PE15 |
CN3-P09 |
CSI0-HSYNC |
PE2 |
CN3-P10 |
CSI0-DVDD |
CN3-P11 |
CSI0-DOVDD |
CN3-P12 |
CSI0-D7 |
PE11 |
CN3-P13 |
CSI0-MCLK |
PE1 |
CN3-P14 |
CSI0-D6 |
PE10 |
CN3-P15 |
GND |
CN3-P16 |
CSI0-D5 |
PE9 |
CN3-P17 |
CSI0-PCLK |
PE0 |
CN3-P18 |
CSI0-D4 |
PE8 |
CN3-P19 |
CSI0-D0 |
PE4 |
CN3-P20 |
CSI0-D3 |
PE7 |
CN3-P21 |
CSI0-D1 |
PE5 |
CN3-P22 |
CSI0-D2 |
PE6 |
CN3-P23 |
GND |
CN3-P24 |
CSI0-DOVDD |
CON3 P03 |
UART0-TXD |
PA4 |
CON3 P02 |
UART0-RXD |
PA5 |
CON3 P01 |
GND |
We deign a IEEE 802.3af PoE module for BPI-P2 Zero ,easy to support PoE function,more spec ,please check BPI-9600 PoE module spec.
| Kernel 4.4 source code : https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4 |
| Kernel 3.4 source code : https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp |
| Android 4.4 source code |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| Allwinner documents : |
Allwinner H3 chip doc baidu link: https://pan.baidu.com/s/1qTULll2CR02d0Hw9itq1rw
Allwinner H2+ chip doc baidu link: https://pan.baidu.com/s/1TGMYr3rhizfhlg5hl6hLyg
| BPI-P2 Zero schematic diagram : https://drive.google.com/drive/folders/0B4PAo2nW2KfnflVqbjJGTFlFTTd1b1o1OUxDNk5ackVDM0RNUjBpZ0FQU19SbDk1MngzZWM?resourcekey=0-ZRCiv304nGzvq-w7lwnpjg&usp=sharing |
| BPI-P2 zero CE,FCC,RoHS Certification : http://forum.banana-pi.org/t/banana-pi-bpi-p2-zero-ce-fcc-rohs-certification/9788 |
| BPI-P2 Zero IEEE 802.3af PoE function test: https://www.youtube.com/watch?v=RCrDmhjxfCU&feature=youtu.be |
| BPI-P2 Zero DXF file: https://drive.google.com/file/d/1NBenPRf6Pngsio930PKuzj6IqyUK5qyr/view?usp=sharing |
| Magazinmehatronika BPI-P2 zero and maker review: https://www.magazinmehatronika.com/banana-pi-bpi-p2-recenzija/ |
| 2020-04-28 update, Ubuntu 16.04 Mate Desktop ,Ubuntu 16.04 Server ,kernel 4.4 |
Baidu cloud : https://pan.baidu.com/s/1pJfJbhIcU52uaR4mkWc-4A PinCode:5e3E
Discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m2-zero-new-image-2020-04-28-debian-rasbian-ubuntu/11068
| 2019-4-30 update BPI-M2 Zero & BPI-P2 Zero Ubuntu Server 16.04 |
Baidu Drive : https://pan.baidu.com/s/100LiQcD7V2_AJ3EmYN8p0g PinCode: q379
Md5 : f8aa74511677a0543d2af65115d7d0d0
| 2018-4-30 update BPI-M2 Zero & P2Zero Ubuntu Desktop 16.04 |
Baidu Drive : https://pan.baidu.com/s/1LZmkxRnszlhfdLD0Ngg18g PinCode: dqe1
Md5 : 25daaac1e678a5cc98259a82ea5ce53c
| 2018-08-17 update Ubuntu image V1.0 release This release is for BPI-P2 Zero board which is based on Allwinner H2+, We have one demo image release,Ubuntu 16.04 is based on kernel 3.4. |
Features Map : http://docs.banana-pi.org/en/BPI-P2_Zero/P2Z_Image_Map
Baidu Drive : https://pan.baidu.com/s/1-pAplB8_j_W5mUsYsinavg
| 2020-04-28 update, Debian 9, kernel 4.4 |
| 2020-04-28 update,Rasbian Stretch, kernel 4.4 |
Baidu cloud : https://pan.baidu.com/s/1pJfJbhIcU52uaR4mkWc-4A Pincode:5e3E
| 2023-07-06 Armbian_kernel6.1.24, support emmc, usb wifi, emac |
Google Drive: https://drive.google.com/drive/folders/1Y2RUA11B8zANc7aozdXcAJ782F5c4Pdv?usp=drive_link
Baidu Cloud: https://pan.baidu.com/s/1il64jearOr7xh25YcqOkxw?pwd=8888 PinCode: 8888
| 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1uhbUMYeplPybxTn_Cybpvw?pwd=8888 PinCode: 8888
Discuss on Forum: https://forum.banana-pi.org/t/bananapi-bpi-p2-zero-new-image-release-armbian-jammy/14026
| 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_bullseye_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1CrZQhN3BR6bx7uMTZYVeMQ?pwd=8888 PinCode: 8888
Discuss on Forum: https://forum.banana-pi.org/t/bananapi-bpi-p2-zero-new-image-release-armbian-bullseye/14025
| 2022-09-27-Armbian_22.11.0-trunk_jammy_edge_lubuntu_5.19.6-qt5-swap-bpi-P2z-M2Z-10804MB |
Baidu Cloud: https://pan.baidu.com/s/1RKJzzpMOHnFW0nj8I-NJIA?pwd=rk22 PinCode: rk22
MD5: f4dfbe234c21a6038f50f699780d4e03
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-p2-zero-with-allwinner-h3-soc.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-P2-Zero/1100417230_40000003593412.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-P2-Zero/1101951077_40000003551096.html |
| OEM&ODM, please contact: [email protected] |
