Banana Pi BPI-M8 is built on the high-performance octa-core AI platform chip A733, which combines a dual-core Arm® Cortex®-A76 and a hexa-core Arm Cortex-A55. It supports an Imagination PowerVR BXM-4-64 MC1 GPU, a 3 TOPS NPU, LPDDR4, LPDDR4x, and LPDDR5 DRAM, and UFS/eMMC storage.
The BPI-M8 provides a wide range of peripheral interfaces, including USB, DP, UFS, HDMI, MIPI CSI, MIPI DSI, FAN, RTC, and one Gigabit Ethernet port with PoE support. It supports booting from an SD card and features an onboard KEIIOT K038 Wi-Fi/Bluetooth chip. It is equipped with 4GB of LPDDR5 RAM, 32GB of eMMC storage, and two 12x12mm single-antenna modules.
Allwinner A733 design: Banana Pi BPI-M8 similar in size to Raspberry Pi 5 Allwinner H618 design: Banana Pi BPI-M4 Berry similar in size to Raspberry Pi 4B Allwinner H618 design: Banana Pi BPI-M4 Zero similar in size to Raspberry Pi Zero W Allwinner A40i design: Banana Pi BPI-M2 Berry SBC design Allwinner A40i design: Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design: Banana Pi BPI-6202 industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with onboard eMMC Allwinner H3 design: Banana Pi BPI-M2 Zero similar in size to Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero IoT design |
Dual-core Arm Cortex-A76 + hexa-core Arm Cortex-A55, up to 2.0GHz
4GB LPDDR5 memory
64GB eMMC flash (BPI-M8A)
16MB SPI NOR storage (BPI-M8B)
1x MIPI DSI display interface
2x MIPI CSI camera interfaces
1x PCIe/DP interface
1x HDMI 2.0b output interface
4x USB-A ports
1x Gigabit Ethernet (GbE) RJ45 port (PoE power supported through a PoE HAT)
1x Wi-Fi 6/Bluetooth 5 module
1x 40-pin GPIO header
1x UFS interface
| The BPI-M8A uses 64GB eMMC flash. The BPI-M8B uses 16MB SPI NOR flash. |
| Hardware Specifications of Banana Pi M8 | |
CPU |
Allwinner A733 dual-core Arm Cortex-A76 + hexa-core Arm Cortex-A55, up to 2.0 GHz |
GPU |
Imagination PowerVR BXM-4-64 MC1 |
PMIC |
AXP318 |
Memory |
4GB LPDDR5 RAM |
Storage |
MicroSD card slot |
Supports 8GB/16GB/32GB/64GB/128GB eMMC storage (64GB eMMC by default) |
Supports SPI NOR storage |
Supports UFS modules |
Network |
10/100/1000M Ethernet |
Wi-Fi 6/Bluetooth 5.0 chip |
Video Output |
1x HDMI 2.0b TX interface |
1x 4-lane MIPI DSI display interface |
Camera |
2x 4-lane MIPI CSI camera interfaces |
Audio Output |
3.5mm headphone jack output and HDMI audio output |
PCIe |
FPC PCIe socket (shared with the DP socket) |
USB Ports |
3x USB 2.0 ports + 1x USB 3.0 port |
GPIO |
40-pin expansion header supporting GPIO, UART, I²C, SPI, PWM, and other functions |
Switches |
PWR button and ADC button |
RTC |
Battery connector with 2 pins at 1mm pitch |
LED |
Power status and activity status |
Power |
5 V/4 A input through USB Type-C, or PoE power |
Size and Weight |
85x56 mm, 60g |
Operating System |
Android and Linux |
| BPI-A733-Android13-Code |
Baidu Cloud:
Google Drive:
Android source code https://github.com/BPI-SINOVOIP/BPI-A733-Android13
| Linux BSP source code |
u-boot for A733 : https://github.com/BPI-SINOVOIP/pi-u-boot/tree/sun60iw2p1-2018.07
kernel for A733 : https://github.com/BPI-SINOVOIP/pi-linux/tree/sun60iw2p1-5.15
Bananapi Armbian build source code https://github.com/BPI-SINOVOIP/armbian-build/tree/bpi-v26.05
WringPi source code
RPi.GPIO source code
WiringPi-Python source code
| BPI-M8 DXF Files |
Baidu: https://pan.baidu.com/s/1YewFVjmMhxQERNkgPD12Hw?pwd=8888 Access code: 8888
| BPI-M8 3D Files |
Baidu: https://pan.baidu.com/s/1Xx3KOsFM-V0S0J3TDrzDEQ?pwd=8888 Access code: 8888
| Camera 415 Files |
Baidu: https://pan.baidu.com/s/1mmDr8WOm2AvfnA45F9-WpQ?pwd=8888 Access code: 8888
| BPI-MIPI-HC070 |
Baidu: https://pan.baidu.com/s/1Bol_EVWRO2oMl6zTixQMXw?pwd=8888 Access code: 8888
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-m8-with-allwinner-a733-chip-design.html |
| Sinovoip AliExpress Shop: https://ko.aliexpress.com/item/1005013422098187.html?gatewayAdapt=glo2kor |
| BIPAI AliExpress Shop: https://ko.aliexpress.com/item/1005013422264089.html?gatewayAdapt=glo2kor |
| BPI OpenSource AliExpress Shop: https://fr.aliexpress.com/item/1005013422236363.html?gatewayAdapt=glo2fra |
| JOOM Platform: https://www.joom.com/en/products/6ad09988303ef201d39eefb2 |
