The Banana Pi M2 Zero is an ultra compact single board computer which measures only 65mm*30mm. Its external interfaces are the same as the Raspberry Pi Zero W, and it will fit almost all cases and accessories for the Zero W. It uses the quad-core Cortex A7 Allwinner H3/H2+processor, with 512MB RAM. It’s ideal for light-weight systems and space-limited applications. Like other members of the Banana Pi family, it supports both Linux and Android operating systems.
As Allwinner H2+ chip is EOL, so BPI-M2 Zero will use H3 chip defaults. but image for H2+ also support H3, so all image is same. support H2+ and H3 chip.
Allwinner A733 design : Banana Pi BPI-M8 Same size as Raspberry Pi 5 Allwinner H618 design : Banana Pi BPI-M4 Berry Same size as Raspberry Pi 4B Allwinner H618 design : Banana Pi BPI-M4 Zero Same size as Raspberry Pi Zere W Allwinner A40i design Banana Pi BPI-M2 Berry SBC design Allwinner A40i design Banana Pi BPI-M2 Ultra SBC design Allwinner A40i design Banana Pi BPI-6202 Industrial control gateway Allwinner H3 design: Banana Pi BPI-M2+ SBC with eMMC onboard Allwinner H3 design: Banana Pi BPI-M2 Zero same size as Raspberry Pi Zero W Allwinner H3 design: Banana Pi BPI-P2 Zero for IoT design |
CPU: Allwinner H3/H2+, Quad-core Cortex-A7.
512MB DDR 3 SDRAM.
WiFi (AP6212/K016) & BT onboard.(The WiFi chip of K016 does not support 5G WiFi.)
Mini HDMI.
40 Pin Raspberry Pi-compatible GPIO, including UART, SPI, I2C, etc.
| HardWare Specification of Banana Pi M2 Zero | |
CPU |
Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P |
GPU |
Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 |
Memory \(SDRAM\) |
512M DDR3(shared with GPU) |
Onboard Storage |
TF card \(Max. 64GB\) |
Onboard Network |
NOPE (but can extension with PIN define) |
PoE power |
NOPE |
Onboard flash |
NOPE |
Onboard WIFI |
K016/SDIO AP6212(option AP6181、AP6335)(The WiFi chip of K016 does not support 5G WiFi.) |
Video decoding |
1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 |
Video input |
A CSI input connector Camera |
Video Outputs |
mini HDMI 1.4,1080P@30fps, DHCP |
Audio Output |
Mini HDMI |
Power Source |
Micro USB with 5V/2A |
USB 2.0 Ports |
one USB 2.0 OTG |
Buttons |
Power Button, Reset Button |
Low-level peripherals |
40 Pins Header,compatible with Raspberry Pi 3 |
uart GPIO\(1x3\) pin |
UART, ground |
LED |
Power led & Status led |
IR |
N/A |
Supported OS |
android linux |
Product size |
65mm × 30mm |
Weight |
15g |
| 40 PIN GPIO of Banana pi BPI-M2 Zero | |||
GPIO Pin Name |
Default Function |
Function2:GPIO |
Function3 |
CON2-P01 |
VCC-3V3 |
CON2-P02 |
VCC-5V |
CON2-P03 |
TWI0-SDA |
PA12-EINT12 |
CON2-P04 |
VCC-5V |
CON2-P05 |
TWI0-SCK |
PA11-EINT11 |
CON2-P06 |
GND |
CON2-P07 |
PWM1 |
PA6-EINT6 |
CON2-P08 |
UART3-TX |
PA13-EINT13 |
SPI1-CS |
CON2-P09 |
GND |
CON2-P10 |
UART3-RX |
PA14-EINT14 |
SPI1-CLK |
CON2-P11 |
UART2-RX |
PA1-EINT1 |
CON2-P12 |
UART3-CTS |
PA16-EINT16 |
SPI1-MISO |
CON2-P13 |
UART2-TX |
PA0-EINT0 |
CON2-P14 |
GND |
CON2-P15 |
UART2-CTS |
PA3-EINT3 |
CON2-P16 |
UART3-RTS |
PA15-EINT15 |
SPI1-MOSI |
CON2-P17 |
VCC-3V3 |
CON2-P18 |
PC4 |
PC4 |
CON2-P19 |
SPI0-MOSI |
PC0 |
CON2-P20 |
GND |
CON2-P21 |
SPI0-MISO |
PC1 |
CON2-P22 |
UART2-RTS |
PA2-EINT2 |
CON2-P23 |
SPI0-CLK |
PC2 |
CON2-P24 |
SPI0-CS |
PC3 |
CON2-P25 |
GND |
CON2-P26 |
PC7 |
PC7 |
CON2-P27 |
TWI1-SDA |
PA19-EINT19 |
CON2-P28 |
TWI1-SCK |
PA18-EINT18 |
CON2-P29 |
PA7-EINT7 |
PA7-EINT7 |
CON2-P30 |
GND |
CON2-P31 |
PA8-EINT8 |
PA8-EINT8 |
CON2-P32 |
PL2-S-EINT2 |
PL2-S-EINT2 |
CON2-P33 |
PA9-EINT9 |
PA9-EINT9 |
CON2-P34 |
GND |
CON2-P35 |
PA10-EINT10 |
PA10-EINT10 |
CON2-P36 |
PL4-S-EINT4 |
PL4-S-EINT4 |
CON2-P37 |
PA17-EINT17 |
PA17-EINT17 |
SPDIF-OUT |
CON2-P38 |
PA21-EINT21 |
PA21-EINT21 |
CON2-P39 |
GND |
CON2-P40 |
PA20-EINT20 |
PA20-EINT20 |
| 24 PIN CSI Camera connector of Banana pi BPI-M2 Zero | ||
CSI Pin Name |
Default Function |
Function2:GPIO |
CN3-P01 |
NC |
CN3-P02 |
GND |
CN3-P03 |
CSI0-SDA |
PE13 |
CN3-P04 |
CSI0-AVDD |
CN3-P05 |
CSI0-SCK |
PE12 |
CN3-P06 |
CSI0-Reset |
PE14 |
CN3-P07 |
CSI0-VSYNC |
PE3 |
CN3-P08 |
CSI0-PWDN |
PE15 |
CN3-P09 |
CSI0-HSYNC |
PE2 |
CN3-P10 |
CSI0-DVDD |
CN3-P11 |
CSI0-DOVDD |
CN3-P12 |
CSI0-D7 |
PE11 |
CN3-P13 |
CSI0-MCLK |
PE1 |
CN3-P14 |
CSI0-D6 |
PE10 |
CN3-P15 |
GND |
CN3-P16 |
CSI0-D5 |
PE9 |
CN3-P17 |
CSI0-PCLK |
PE0 |
CN3-P18 |
CSI0-D4 |
PE8 |
CN3-P19 |
CSI0-D0 |
PE4 |
CN3-P20 |
CSI0-D3 |
PE7 |
CN3-P21 |
CSI0-D1 |
PE5 |
CN3-P22 |
CSI0-D2 |
PE6 |
CN3-P23 |
GND |
CN3-P24 |
CSI0-DOVDD |
jumper CON3 of Banana pi BPI-M2 Zero |
CON3 Pin Name |
Default Function |
GPIO |
CON3 P03 |
UART0-TXD |
PA4 |
CON3 P02 |
UART0-RXD |
PA5 |
CON3 P01 |
GND |
| Kernel 4.4 source code : https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4 |
| Kernel 3.4 source code : https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp |
| BPI-M2 Zero Mainline linux kernel 4.19.0 (experimental) : https://github.com/avafinger/bananapi-zero-ubuntu-base-minimal#whats-new-with-this-image-v5-experimental |
| BPI-M2 zero Ubuntu 19.10 Eoan Ermine Mainline Kernel 5.3.5 : https://github.com/avafinger/bananapi-zero-ubuntu-base-minimal |
| Banana Pi M2 Zero GPIO with Python : https://github.com/rlatn1234/pyGPIO2 |
| Imagenes Ubuntu estables para Banana Pi M2 Zero: |
| Android 4.4 source code |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| Schematic diagram : https://drive.google.com/drive/folders/0B4PAo2nW2KfnflVqbjJGTFlFTTd1b1o1OUxDNk5ackVDM0RNUjBpZ0FQU19SbDk1MngzZWM?resourcekey=0-ZRCiv304nGzvq-w7lwnpjg&usp=sharing |
| CE FCC RoHS : BPI-M2 zero CE,FCC,RoHS |
| Allwinner documents : |
Allwinner H3 chip doc baidu link : https://pan.baidu.com/s/1qTULll2CR02d0Hw9itq1rw
Allwinner H2+ chip doc baidu link : https://pan.baidu.com/s/1TGMYr3rhizfhlg5hl6hLyg
| Banana Pi M2 Zero - Review and compare to RPI Zero : https://www.youtube.com/watch?v=CaXi1qbOvYk |
| Banana Pi M2 Zero - Unboxing, Caratteristiche e Test (CPU, Gimp, WiFi, USB, Burntest) : https://www.youtube.com/watch?v=rioWNzPXBnM |
| A Review of the Banana Pi M2 Zero Running openHAB : https://community.openhab.org/t/a-review-of-the-banana-pi-m2-zero-running-openhab/37652 |
| Banana Pi BPI-M2 Zero with OpenCV : https://bluexmas.tistory.com/category/OS/Banana%20Pi%20%EF%BC%8FBPI-Bit?page=2 |
| Banana Pi M2 Zero: Low-Cost, Quad Core SBC : https://www.youtube.com/watch?v=51OMXTElStM&feature=youtu.be |
| NO COMPRES RASPBERRY PI ZERO - BANANA PI M2 ZERO LA DESTRUYE! RETRORANGE PI : https://www.youtube.com/watch?v=2N2QwWeuehM |
| Banana Pi M2 Zero Armbian O.S. Install and Setup Tutorial : https://www.youtube.com/watch?v=A4PflbMusSQ&t=8s |
| BANANA PI BPI-M2-ZERO BENCHMARKS & REVIEW : https://bret.dk/banana-pi-bpi-m2-zero-benchmarks-review/ |
| Configuracion y uso de GPIO BPI-M2 Zero 1.5.2 : https://forum.banana-pi.org/t/configuracion-y-uso-de-gpio-bpi-m2-zero-1-5-2/15113 |
| Note: all image support H2+ and H3 chip on board for BPI-M2 Zero |
| 2018-07-09 update Android 4.4, kernel 3.4 |
Baidu Drive : https://pan.baidu.com/s/1zaUoVBK39AxZw6ou5bDv2g
Release ntoes: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-android4-4-release-2018-07-09/6223
| 2017-11-12 update Android 4.4, kernel 3.4 |
Baidu Drive : https://pan.baidu.com/s/1c2pTXUo
Md5: 67a5953dac47f3ca7a2628e1422a36e2
| 2022-09-27-Armbian_22.11.0-trunk_jammy_edge_lubuntu_5.19.6-qt5-swap-bpi-P2z-M2Z-10804MB |
Baidu Cloud: https://pan.baidu.com/s/1RKJzzpMOHnFW0nj8I-NJIA?pwd=rk22 PIN code: rk22
Md5: f4dfbe234c21a6038f50f699780d4e03
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim2zero_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/14YXrCPnsqwF41-8kInAyrA?pwd=md7e PIN code: md7e
| 2020-04-28 update, Ubuntu 16.04 Mate Desktop, Ubuntu 16.04 Server, kernel 4.4 |
Baidu Cloud : https://pan.baidu.com/s/1pJfJbhIcU52uaR4mkWc-4A PIN code: 5e3E
Discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m2-zero-new-image-2020-04-28-debian-rasbian-ubuntu/11068
| Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 |
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-new-image-ubuntu-16-04-with-allwinner-bsp-use-mpv-play-1080p-video/13272
| BPI-M2 Zero Ubuntu 19.10 Eoan Ermine Mainline Kernel 5.3.5 |
| 2019-4-30 update BPI-M2 Zero & BPI-P2 Zero Ubuntu Server 16.04 |
Baidu Drive : https://pan.baidu.com/s/100LiQcD7V2_AJ3EmYN8p0g PIN code: q379
Md5 : f8aa74511677a0543d2af65115d7d0d0
Release ntoes: http://forum.banana-pi.org/t/bananapi-bpi-m2z-bpi-p2-zero-h2-new-images-reapbian9-4-ubuntu16-04-release-2019-04-30/9166
| 2018-4-30 update BPI-M2 Zero & P2Zero Ubuntu Desktop 16.04 |
Baidu Drive : https://pan.baidu.com/s/1LZmkxRnszlhfdLD0Ngg18g PIN code: dqe1
Md5 : 25daaac1e678a5cc98259a82ea5ce53c
| 2018-07-09 update |
Baidu Drive: https://pan.baidu.com/s/1dg7okBYBkt_1U3saVqOMUw
Release ntoes: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-raspbian-ubuntu-release-2018-07-09/6221
| 2017-11-13 update |
Baidu Drive: http://pan.baidu.com/s/1gfvRUk7
| 2020-04-28 update, Debian 9, kernel 4.4 |
| Banana Pi BPI-M2 Zero Instalacion y Configuracion de Arch Linux |
| 2020-04-28 update, Rasbian Stretch, kernel 4.4 |
| 2020-04-10 update Raspbian Stretch, kernel 4.4 |
Baidu cloud: https://pan.baidu.com/s/1eKs85jMW3PS8pdX4jukLUQ PIN code: 6W2M
| 2019-04-30 update Raspbian Stretch, kernel 3.4 |
Baidu Drive : https://pan.baidu.com/s/1gmg-qX235t5kpL1N9uHy5A PIN code: 146j
| 2018-07-09 update Raspbian Stretch, kernel 3.4 |
Baidu Drive: https://pan.baidu.com/s/1ahXv3Hl7Dst7uBwz60pcrg
| Armbian_23.05.0-trunk_Bananapim2zero_bullseye_current_6.1.24_mate_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/16vL43zl8zINraHLtnbzlhg?pwd=8888 PIN code: 8888
| 2023-07-06 Armbian_kernel6.1.24, support emmc, usb wifi, emac |
Google Drive: https://drive.google.com/drive/folders/1Y2RUA11B8zANc7aozdXcAJ782F5c4Pdv?usp=drive_link
Baidu Cloud: https://pan.baidu.com/s/1il64jearOr7xh25YcqOkxw?pwd=8888 PIN code: 8888
| 2022-12-06 Armbian_22.11.0-trunk_Bananapim2zero_bullseye_edge_6.0.9.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1YLuBICd4mVOoTZzoWaEjCw?pwd=8888 PIN code: 8888
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-zero-new-image-release-armbian-bullseye/14448
| Image Link from Armbian official website: https://www.armbian.com/bananapi-m2-zero/ |
| RetroPie for Banana Pi M2 Zero v.1.2.1 beta |
| Retrorangepi support BPI-M2+ BPI-M2 Zero : http://retrorangepi.download/download/index2.html |
| Nuevas imagenes BPI-M2 Zero : https://forum.banana-pi.org/t/nuevas-imagenes-bpi-m2-zero/13414 |
| LibreElec 10 (Kodi Matrix) at BPI-M2 Zero with Youtube, HBO Max and (probably) Netflix: http://forum.banana-pi.org/t/libreelec-10-kodi-matrix-at-bpi-m2-zero-with-youtube-hbo-max-and-probably-netflix/12474 |
| Banana PI official shop: https://www.bpi-shop.com/products/banana-pi-m2-zero-is-an-ultra-compact-single-board-computer.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Zero/1100417230_40000003593410.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Zero/1101951077_40000003414813.html |
| OEM&ODM, please contact: [email protected] |
