Banana Pi BPI-CM7IO board is designed for Banana Pi BPI-CM7.
Allwinner H618 design : Banana Pi BPI-M4 Zero single board computer Allwinner H618 design : Banana Pi BPI-CM7 computer module |
2 x 100-pin board-to-board connectors
USB Type-C power input and USB 2.0 OTG
2 x USB 2.0 Type-A
HDMI output
10/100M Ethernet RJ45
microSD card slot
40-pin GPIO header
mini-PCIe-style socket with USB 2.0 interface
SIM card slot
UART debug interface
Reset and FEL buttons
Composite video and stereo line output
| Interface | Specification |
Compute module |
2 x 100-pin board-to-board connectors for BPI-CM7 |
Power input |
5 V through USB Type-C |
USB OTG |
1 x USB 2.0 OTG through USB Type-C |
USB Host |
2 x USB 2.0 Type-A; 1 x USB 2.0 routed to the cellular-module socket |
Display |
1 x HDMI Type-A |
Ethernet |
1 x 10/100M Ethernet RJ45 |
Storage |
1 x microSD card slot |
GPIO |
1 x 40-pin GPIO header |
Cellular |
1 x mini-PCIe-style socket with USB 2.0 interface and 1 x SIM card slot |
Debug |
1 x 3-pin UART debug header |
Buttons |
Reset and FEL |
Analog A/V |
1 x 4-pin composite video and stereo line-output header |
🟥 Power · ⬛ Ground · 🟩 GPIO / Interface
| Pin | Signal | Function | Pin | Signal | Function |
1 |
🟥 3.3 V |
Power |
2 |
🟥 5 V |
Power |
3 |
🟩 PI6 |
TWI0_SDA / GMAC_INT |
4 |
🟥 5 V |
Power |
5 |
🟩 PI5 |
TWI0_SCL / RGMII_RXCTL |
6 |
⬛ GND |
Ground |
7 |
🟩 PI12 |
PWM2 / UART3_CTS / RGMII_TXCTL |
8 |
🟩 PI13 |
UART4_TX / RGMII_CLK125M |
9 |
⬛ GND |
Ground |
10 |
🟩 PI14 |
UART4_RX / RGMII_MDC |
11 |
🟩 PH2 |
TWI2_SCL / UART5_TX / PWM2 |
12 |
🟩 PI1 |
I2S0_BCLK / DMIC_D0 / RGMII_RXD2 |
13 |
🟩 PH3 |
TWI2_SDA / UART5_RX / PWM1 |
14 |
⬛ GND |
Ground |
15 |
🟩 PI11 |
UART3_RTS / PWM1 / RGMII_TXCLK |
16 |
🟩 PI15 |
UART4_RTS / RGMII_MDIO |
17 |
🟥 3.3 V |
Power |
18 |
🟩 PI16 |
UART4_CTS / GMAC reset |
19 |
🟩 PH7 |
SPI1_MOSI / TWI4_SDA |
20 |
⬛ GND |
Ground |
21 |
🟩 PH8 |
SPI1_MISO |
22 |
🟩 PC2 |
GPIO |
23 |
🟩 PH6 |
SPI1_CLK / TWI4_SCL |
24 |
🟩 PH5 |
SPI1_CS0 |
25 |
⬛ GND |
Ground |
26 |
🟩 PH9 |
SPI1_CS1 |
27 |
🟩 PI8 |
TWI1_SDA / RGMII_TXD2 |
28 |
🟩 PI7 |
TWI1_SCL / RGMII_TXD3 |
29 |
🟩 PI10 |
UART3_RX / RGMII_TXD0 |
30 |
⬛ GND |
Ground |
31 |
🟩 PI9 |
UART3_TX / RGMII_TXD1 |
32 |
🟩 PH4 |
SPDIF_OUT |
33 |
🟩 PH10 |
IR_RX |
34 |
⬛ GND |
Ground |
35 |
🟩 PI2 |
I2S0_LRCLK / DMIC_D1 / RGMII_RXD1 |
36 |
🟩 PC7 |
GPIO |
37 |
🟩 PI0 |
I2S0_MCLK / DMIC_CLK / RGMII_RXD3 |
38 |
🟩 PI4 |
I2S0_DIN / DMIC_D3 / RGMII_RXCLK |
39 |
⬛ GND |
Ground |
40 |
🟩 PI3 |
I2S0_DOUT / DMIC_D2 / RGMII_RXD0 |
CON1-P1 |
GND |
CON1-P2 |
UART0-RX |
CON1-P3 |
UART0-TX |
