Banana Pi BPI-CM7 is an Allwinner H618 compute module with LPDDR4 memory, eMMC storage, a K019 Wi-Fi 5/Bluetooth 5.0 module, and two 100-pin board-to-board connectors.
Allwinner H618 design: Banana Pi BPI-M4 Berry single-board computer Allwinner H618 design: Banana Pi BPI-M4 Zero single-board computer Allwinner H618 design: Banana Pi BPI-CM7 compute module |
Allwinner H618 quad-core 64-bit Arm Cortex-A53 processor, up to 1.5 GHz
Arm Mali-G31 GPU
Onboard LPDDR4 memory
Onboard eMMC storage
K019 Wi-Fi 5 and Bluetooth 5.0 module
HDMI output
10/100M Ethernet
1x USB 2.0 OTG and 3x USB 2.0 Host interfaces
microSD interface
2x 100-pin board-to-board connectors
GPIO, UART, TWI/I2C, SPI, PWM, I2S/PCM, DMIC, SPDIF, and IR
5 V power input
| Item | Specification |
SoC |
Allwinner H618 |
CPU |
Quad-core 64-bit Arm Cortex-A53, up to 1.5 GHz |
GPU |
Arm Mali-G31 |
Memory |
Onboard LPDDR4; capacity depends on the product model |
Storage |
Onboard eMMC; capacity depends on the product model |
Wireless |
K019 Wi-Fi 5 and Bluetooth 5.0 module with a U.FL/IPEX antenna connector |
Display |
HDMI output |
Network |
10/100M Ethernet |
USB |
1x USB 2.0 OTG and 3x USB 2.0 Host interfaces |
Expansion |
2x 100-pin board-to-board connectors |
Power |
5 V input |
| 2026-10-19-bananapi-cm7-android12.img |
Baidu cloud: https://pan.baidu.com/s/10CyF5D5vNBJfR-KoXMyMHw?pwd=8888 (Access code: 8888)
| Bananapi-Armbian_24.11.1_Bpi-cm7_jammy_legacy_5.4.125_xfce_desktop.img.xz |
Baidu cloud: https://pan.baidu.com/s/1d7Ic8uTNZIDl26J2F4F-0Q?pwd=8888 (Access code: 8888)
| OEM&ODM, please contact: [email protected] |
