Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design. this is a industrial-grade board. we also design a Xilinx Artix-7 FPGA extend board.
SunPlus sp7021 design: Banana Pi BPI-F2S FPGA development board SunPlus sp7021 design: Banana Pi BPI-F2P SBC industrial control gateway board |
Easy-to-use LQFP package.
Quad-core 1GHz Cortex-A7 CPU, plus A926 and 8051 cores.
Single 3.3V power*.
Integrated 128MB or 512MB DDR3 DRAM.
Eight 8-bit 5V-tolerant IO ports, plus one high-current port.
Flexible Peripheral Multiplexing (PinMux).
Dual PinMuxable Ethernet MACs.
Four PinMuxable Enhanced UARTs, plus one console UART.
Industrial operating temperature range: -40C ~ +85C.
Low EMI simplifies certification.
Modern, Yocto-based Linux distribution.
10-year supply guarantee.
Robust ready-to-run modern Linux distribution available
IoT/Industrial Internet control
Smart Audio
Smart Payment system
FPGA education and development
Vehicular networking technology and applications
| Note : 40 PIN GPIO compitable Raspberry Pi |
| HardWare Specification of Banana Pi F2S | |
SoC |
Sunplus SP7021 “Plus1” with a quad-core Cortex-A7 processor @ 1.0 GHz, one Arm A926 microprocessor, an 8051 core to handle I/Os, and 128MB or 512MB DDR3 DRAM. |
Storage |
8GB eMMC flash, microSD card slot |
Video Output |
HDMI 1.4 output |
Camera I/F |
MIPI CSI connector |
Connectivity |
2x 10/100M Ethernet |
USB |
2x USB 2.0 host ports, 1x micro USB port |
Expansion |
40-pin GPIO header compatible with Raspberry Pi header 2x 50-pin FPGA interface for Trenz Electronic TE0725LP-01-100-2D Artix 7 FPGA board Unpopulated, undocumented 50-pin header that’s appears to be routed to one of the headers for the optional FPGA board |
Debugging |
3-pin header for UART console, 10-pin JTAG header, SWD ICE port |
Security |
TPM 2.0 via ST33TPH2EI2C secure element |
Misc |
Power switch, reset button, boot selection dip switch |
Power Supply |
12VDC via power barrel jack |
Dimensions |
135x80mm |
Temperature Range |
-40C ~ +85°C |
BPI-F2S sunplus board
FPGA baord: Xilinx Artix-7 XC7A100T,32 MByte QSPI Flash memory,power by single 3.3v
Teaching sheet board : 4 digit 7 segment digital tube teaching,DIP8 socket for SPI flash IP authentication,8 LED lights are used for teaching
Debug tooling
12v/2A adapter
| Online development doc: https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/pages/470777857/SP7021+Plus+Xilinx+FPGA+SOC+Platform+UserGuide |
| Sunplus official website for BPI-F2S FPGA development Kit: http://www.cqplus1.com/zlxz |
| Function demo : https://www.youtube.com/watch?v=602gQo_Qcrs |
Xilinx Artix-7 XC7A100T-2CSG324C/XC7A100T-2CSG324I
Commercial temperature grade (industrial on request)
2 x 50 pin headers with 2.54 mm pitch, ideal for breadboard use
1.8 V single supply with on board voltage regulators
95 I/O’s (42 + 42 + 3 + 8)
25 MHz system clock (100 MHz can be customized on request)
I2C EEPROM
7.3 x 3.5 cm form factor
JTAG/UART connector
One user LED
Optional HyperRAM (8 bis 32 MByte) or HyperFlash
HyperRAM from Cypress : http://www.cypress.com/products/hyperram-memory
HyperFlash from Cypress: http://www.cypress.com/products/hyperflash-nor-flash-memory
| Sunpuls github for Linux kernel 4.19 and 5.4 source code: https://github.com/sunplus-plus1 |
| BPI-F2S BPS code with kernel 5.4.35 : https://github.com/BPI-SINOVOIP/BPI-F2S-bsp |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| Banana Pi BPI-F2S schematic diagram: google driver |
| BPI-F2S DXF file : https://drive.google.com/file/d/1HMPTBYWvK_kk6KkvVHY3KDnwYe_noMZW/view?usp=sharing |
| Sunpulus wiki page documents(english): https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/overview |
| PLUS1 SP7021 Datasheet : https://drive.google.com/file/d/1MWFwgHMteMKVxgzyK5ClU9LOyh-M8xPA/view?usp=sharing |
| SP7021 Released Document : https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/overview |
| Banana Pi BPI-F2P Sunplus SP7021 industrial control board PoE function test: https://www.youtube.com/watch?v=YQ5rVYHLHQI |
| FPGA TRM-TE0725LP-01_usermanual: https://drive.google.com/file/d/1yKsbKSc2VSZgkFH_Oezm_75lD5un8MMT/view?usp=sharing |
| Xilinx AI Platform tutorials: https://github.com/Xilinx/Edge-AI-Platform-Tutorials |
| Xilinx edge AI platform : https://www.xilinx.com/products/design-tools/ai-inference/edge-ai-platform.html |
| 2019-12-25 update :ubuntu mate 18.04 desktop 2019-12-25 base on kernel 4.19.37 |
| Debian-10-buste-bpi-f2s-sd-emmc 2019-11-26 kernel 4.19 |
Google download link: https://drive.google.com/file/d/1MpjDeUk4H-EXzaxpuywgbgRaM8YXoXjI/view
| CentOS userland armv7hl-RaspberryPi KDE 1908 sda 2019-12-25 base on kernel 4.19.37 |
Password: root/centos
| 2019-12-25 update: Kail Linux 2019.4 nexmon 2019-12-25 base on kernel 4.19.37 |
Password: root/toor
| This code is support by Tibbo/SunPlus |
Github link: https://github.com/tibbotech/yocto_layers
| Banana Pi BPI-F2S setup & run fedora 31 (u-boot-2019.04 + kernel 4.19.37) |
Google download : https://drive.google.com/open?id=1ATHmvKvYoBpM3uyQ2xK4pvKahlgCGHnq
| Mozilla IoT rpi gateway 0.10.0 2019-12-25 base on kernel 4.19.37 |
Mozilla gateway getting started guide: https://iot.mozilla.org/docs/gateway-getting-started-guide.html
| Aliexpress online shop: https://pt.aliexpress.com/store/group/Banana-PI-F2S-Board/302756_517091763.html?spm=a2g03.12010612.0.0.6124277eh17sp6 |
| Taobao shop : https://item.taobao.com/item.htm?ft=t&id=610642319814 |
| OEM&ODM, please contact: [email protected] |
