| SunPlus sp7021 design: Banana Pi BPI-F2S FPGA development board SunPlus sp7021 design: Banana Pi BPI-F2P SBC industrial control gateway board |
Easy-to-use LQFP package.
Quad-core 1GHz Cortex-A7 CPU, plus A926 and 8051 cores.
Single 3.3V power*.
Integrated 128MB or 512MB DDR3 DRAM.
Eight 8-bit 5V-tolerant IO ports, plus one high-current port.
Flexible Peripheral Multiplexing (PinMux).
Dual PinMuxable Ethernet MACs.
Four PinMuxable Enhanced UARTs, plus one console UART.
Industrial operating temperature range: -40C ~ +85C.
Low EMI simplifies certification.
Modern, Yocto-based Linux distribution.
10-year supply guarantee.
Robust ready-to-run modern Linux distribution available
And much more…
IoT/Industrial Internet control
Smart Audio
Smart Payment system
Vehicular networking technology and applications
The inner and outer diameter of the power plug adapter datasheet : https://drive.google.com/file/d/1k3AWmYOs2XE7lnRxCyytZu0Vpq_Bzcu_/view?usp=sharing
| HardWare Specification of Banana Pi F2P | |
| SoC | Sunplus SP7021 “Plus1” with a quad-core Cortex-A7 processor @ 1.0 GHz, one Arm A926 microprocessor, an 8051 core to handle I/Os, and 128MB or 512MB DDR3 DRAM. |
| Storage | 8GB eMMC flash, microSD card slot |
| Video Output | HDMI 1.4 output |
| Camera I/F | MIPI CSI connector |
| Connectivity | 2x 10/100M Ethernet |
| USB | 2x USB 2.0 host ports, 1x micro USB port |
| Expansion | 2 USB header interface 40-pin GPIO header compatible 7.4V Lithium battery power supply interface RTC battery interface PoE function support |
| Debugging | 3-pin header for UART console, SWD ICE port |
| Security | TPM 2.0 via ST33TPH2EI2C secure element |
| Misc | Power switch, reset button, boot selection dip switch |
| Power Supply | 12VDC via power barrel jack |
| Dimensions | 130x85mm |
| Temperature Range | -40C ~ +85°C |
WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluectooch 5.0, support BPI-M5 and BPI-F2P
Discuss on forum : http://forum.banana-pi.org/t/bpi-m5-wifi-bt-board-sdio-interface-802-11-a-b-g-n-ac-2t2r-wifi-and-bluectooch-5-0/11846
Banana Pi Wifi&BT 4.2 expansion Board, standard USB interface, so support all open source boards via USB port.IEEE 802.11b/g/n/ac(1T1R) USB WLANAnd BT Module
We also design a expansion board for BPI-F2P , it support 2 SATA interface and 4G module support interface
| Sunpuls github for Linux kernel 4.19 and 5.4 source code: https://github.com/sunplus-plus1 |
| BPI F2S/F2P BPS code with kernel 4.19 and 5.4 source code: https://github.com/BPI-SINOVOIP/BPI-F2S-bsp |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-F2P schematic diagram : https://drive.google.com/file/d/1_S0dL2J3N-xeq6FKy3aPP-3HNdCwqLWt/view?usp=sharing |
| BPI-F2P main board DXF file: https://drive.google.com/file/d/1fMyTq3Bp5AHhGHkwwn5JL_vy55Xxbmc9/view?usp=sharing |
| BPI-F2P SUB board DXF file: https://drive.google.com/file/d/1URef-K9OI_5OIFStrkbJvGah-3BykDEW/view?usp=sharing |
| Sunpulus wiki page documents(english): https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/overview |
| PLUS1 SP7021 Datasheet : https://drive.google.com/file/d/1MWFwgHMteMKVxgzyK5ClU9LOyh-M8xPA/view?usp=sharing |
| SP7021 Released Document : https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/overview |
| Banana Pi BPI-F2P Sunplus SP7021 industrial control board PoE function test: https://www.youtube.com/watch?v=YQ5rVYHLHQI |
| BPI-F2P new image 2021-06-06 update:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image,this image support boot from SD card and eMMC flash, this image boot fast than old image |
Baidu link: https://pan.baidu.com/s/14PXSw4z_UGYWpnxhGbZuFg pincode: s895
| 2021-06-06-ubuntu-server-20.04.1-armhf-ext4-v5.4.35-bpi-f2p.img.zip |
Baidu link: https://pan.baidu.com/s/1Uz8L12aS40WZyvmoP5wVhA pincode: nb98
| BPI-F2P new image 2021-01-29 update:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image,this image support boot from SD card and eMMC flash |
| 2021-01-29-ubuntu-server-20.04.1-armhf-ext4-v5.4.35-bpi-f2p.img.zip |
Baidu link: https://pan.baidu.com/s/1JD3Yn9TYRd_nR8A1AJpqdQ Pincode:fv8e
| BPI-F2P new image: Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image |
BPI-F2P Ubuntu server 20.04.1 image: https://drive.google.com/file/d/1nbHUcwl2Zh1ZKJlZ1223zM8YBr-onKEs/view?usp=drivesdk
BPI-F2P Ubutntu mate 20.04.1 image: https://drive.google.com/file/d/1HFkckuPsuBploMnntMqPQ3cwqnqY6Y_-/view?usp=drivesdk
Discuss on fourm: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-server-20-04-1-and-ubuntu-mate-20-04-1-image/11608
Support BPI-F2P-SUB baord . all function test fine
| BPI-F2P new image: Ubuntu mate 18.04.2 2020-08-16 |
Baidu link : https://pan.baidu.com/s/1vsdH_PDQ_oJdP3WBEG43Pg Pincode:3qgs
Discuss on forum: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-mate-18-04-2-linux-kernel-5-4-2020-08-16/11442
| 2019-12-25 update :ubuntu mate 18.04 desktop 2019-12-25 base on kernel 4.19.37 |
| debian-10-buste-bpi-f2s-sd-emmc 2019-11-26 kernel 4.19 |
Google download link: https://drive.google.com/file/d/1MpjDeUk4H-EXzaxpuywgbgRaM8YXoXjI/view
| CentOS userland armv7hl-RaspberryPi KDE 1908 sda 2019-12-25 base on kernel 4.19.37 |
Password: root/centos
| 2019-12-25 update: Kail Linux 2019.4 nexmon 2019-12-25 base on kernel 4.19.37 |
Password: root/toor
| This code is support by Tibbo/SunPlus |
Github link: https://github.com/tibbotech/yocto_layers
| Banana Pi BPI-F2S setup & run fedora 31 (u-boot-2019.04 + kernel 4.19.37) |
Google download : https://drive.google.com/open?id=1ATHmvKvYoBpM3uyQ2xK4pvKahlgCGHnq
| Mozilla IoT rpi gateway 0.10.0 2019-12-25 base on kernel 4.19.37 |
Mozilla gateway getting started guide: https://iot.mozilla.org/docs/gateway-getting-started-guide.html
| Aliexpress : https://www.aliexpress.com/item/4001268419883.html |
| OEM&ODM, please contact: [email protected] |
