CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308B-S
512 DDR3 SDRAM
8G eMMC flash onboard
WiFi (AP6256) & BT onboard
40 PIN GPIO, includes UART, SPI, I2C, IO etc
100M LAN
IEEE 802.3af PoE standard PoE module support
Audio: Supports rich audio interfaces, such as MIC/PDM/SPDIF/I2S
Maker DIY
IoT Smart Internet of Things
Intelligent speech recognition
Man-machine interface
Industrial control
Intelligent robot
| HardWare Specification of Banana Pi P2 Pro | |
SOC |
RockChip RK3308B-S |
CPU |
Quad-core ARM Cortex-A35 |
GPU |
none |
RAM |
512MB |
FLASH |
8GB eMMC |
TF Card |
TF card (Max 64GB) |
Network |
100M LAN |
PoE power |
PoE function support,Output Voltage 5V, Output |
WiFi |
AP6256 |
Audio Output |
With built-in audio CODEC, including ADC×8 and DAC×2 |
Power Source |
TYPE C 5V/2A or PoE power |
USB |
1xUSB 2.0 1xType-C |
Others |
Fan、RTC、LED、debug |
Button |
Power Button、Reset Button、 Recovery Button、Root Button |
Low-level peripherals |
40 Pin + 12 Pin |
uart GPIO\(1x3\) pin |
UART, ground |
LED |
Power led & Status led |
Product size |
65mm X 52.5mm |
Weight |
30g |
| 40 Pin GPIO define of Banana Pi BPI-P2 Pro | |||||||||
RK3308 Pin No |
Function3 |
Function2 |
Function1 |
Pin |
Pin |
Function1 |
Function2 |
Function3 |
RK3308 Pin No |
VCC_IO |
1 |
2 |
VCC5V0_SYS |
ADC_KEY_IN1 |
3 |
4 |
VCC5V0_SYS |
69 |
I2S0_SCLK_TX |
GPIO2_A5 |
5 |
6 |
GPIO0_C1 |
SPDIF_TX |
17 |
70 |
I2S0_SCLK_RX |
PDM_CLK |
GPIO2_A6 |
7 |
8 |
GPIO2_A7 |
I2S0_LRCK_TX |
71 |
68 |
I2S0_8CH_MCLK |
I2S0_MCLK |
GPIO2_A4 |
9 |
10 |
GPIO2_B0 |
I2S0_LRCK_RX |
72 |
73 |
I2S0_SDO0 |
GPIO2_B1 |
11 |
12 |
GPIO2_B5 |
PDM_SDI0 |
I2S0_SDI0 |
77 |
74 |
I2S0_SDO1 |
GPIO2_B2 |
13 |
14 |
GPIO2_B6 |
PDM_SDI1 |
I2S0_SDI1 |
78 |
75 |
I2S0_SDO2 |
GPIO2_B3 |
15 |
16 |
GPIO2_B7 |
PDM_SDI2 |
I2S0_SDI2 |
79 |
76 |
I2S0_SDO3 |
GPIO2_B4 |
17 |
18 |
GPIO2_C0 |
PDM_SDI3 |
I2S0_SDI3 |
80 |
GND |
19 |
20 |
GND |
LINEOUT_L |
21 |
22 |
LINEOUT_R |
MICBIAS1 |
23 |
24 |
MICBIAS2 |
MICP1 |
25 |
26 |
MICN1 |
MICP2 |
27 |
28 |
MICN2 |
MICP3 |
29 |
30 |
MICN3 |
MICP4 |
31 |
32 |
MICN4 |
MICP5 |
33 |
34 |
MICN5 |
MICP6 |
35 |
36 |
MICN6 |
MICP7 |
37 |
38 |
MICN7 |
MICP8 |
39 |
40 |
MICN8 |
| Pin# | Function1 | Function2 | Function3 | Function4 | RK3308B-S SOC Pin No. |
1 |
GPIO2_A1 |
SPI0_TX |
UART0_TX |
65 |
2 |
GPIO0_B3 |
I2C1_SDA |
11 |
3 |
GPIO2_A0 |
SPI0_RX |
UART0_RX |
64 |
4 |
GPIO0_B4 |
I2C1_SCL |
12 |
5 |
GPIO1_D1 |
UART1_TX |
I2C0_SCL |
SPI2_CS |
56 |
6 |
VCC_IO |
7 |
GPIO1_D0 |
UART1_TX |
I2C0_SDA |
SPI2_CLK |
57 |
8 |
GND |
9 |
GPIO1_C7 |
SPI2_TX |
UART2_TX_M0 |
JTAG_TMS |
57 |
10 |
GPIO0_B7 |
PWM2 |
I2C3_SDA |
15 |
11 |
GPIO1_C6 |
SPI2_RX |
UART2_RX_M0 |
JTAG_TCK |
54 |
12 |
GPIO0_C0 |
PWM3 |
IR_RX |
16 |
| We deign a IEEE 802.3at PoE module for BPI-P2 Zero ,easy to support PoE function,more spec ,please check BPI-9600 PoE module spec |
| linux-5.10.110 kernel BSP Source code on github : https://github.com/ArmSoM/armsom-p2pro-bsp |
| RK3308 datasheet: https://drive.google.com/file/d/1TsKFmItM1FJ-ziEvUkbcZxUsbaKYhsRq/view?usp=sharing |
| BPI-P2 PRO SCH, DXF,SMD file |
Baidu Cloud: https://pan.baidu.com/s/1AuWYgWQ8OBVPHfF-wdWaAA?pwd=8888 (pincode:8888)
| Banana-Pi BPi-P2 Pro RockChip RK3308 SBC Setup: https://uglyscale.press/2023/10/01/banana-pi-bpi-p2-pro-setup/ |
| BPI-P2 pro Tools |
Baidu cloud : https://pan.baidu.com/s/16JKFxeeKi6df_0ZjQI50oQ?pwd=8888 (pincode:8888)
| Banana Pi BPI-P2 pro buildroot image update |
Baidu cloud: https://pan.baidu.com/s/1V8ixOF8vdtuPvzjMGwOcjA?pwd=8888 (pincode:8888)
| Banana Pi BPI-P2 pro debian11 image update 2024-5-24 |
Baidu cloud: https://pan.baidu.com/s/13InKyRDCeB3SGUCvakmV4Q?pwd=8888 (pincode:8888)
| Banana Pi BPI-P2 pro debian11 image update 2023-9-13 |
Baidu Cloud: https://pan.baidu.com/s/15VnIC70ijKvKCjlS4pe4RQ?pwd=8888 (pincode:8888)
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-p2-pro-is-a-development-board-based-on-rk3308b-s-chip.html |
| BPI Aliexpress shop: https://www.aliexpress.com/item/1005005928295640.html |
| SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005005928204793.html |
| Taobao shop : https://item.taobao.com/item.htm?spm=a2126o.success.0.0.264d4831aZTy3l&id=732760740787 |
| OEM&ODM Customized product: [email protected] |
