Banana Pi BPI-R4 Lite Router board with MediaTek MT7987A Quad-core Arm Cortex-A53 design ,2GB DDR4,8GB eMMC flash,256MB SPI-NAND Flash,32MB SPI-NOR Flash and Micro SD card slot onboard, also have 1x 2.5G SFP LAN, 1x 2.5G RJ45 WAN,4x 1G RJ45 LAN,with USB3.0 port,1x M.2 KEY-B slot with USB3.0 for 5G Module.1x miniPCIe slot with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Option: 2x miniPCIe slots with PCIe3.0 1lane),1x miniPCIe slot with USB2.0 interfaceIt and 1x USB TypeC Debug Console. It is a very high performance open source router development board.
Prepare 8G/above TF card, USB-Serial cable, Ubuntu System
12V/2A power adapter (without any peripherals, The power consumption of the BPI-R4_Lite mainboard is around 3W under normal conditions. you need to determine whether you need a higher power power adapter according to your own accessory usage)
Using your USB TypeC Debug Console
link: [Download the image] to be burned
Default IP address for LAN port: 192.168.1.1
User name/password: pi/bananapi ,root/bananapi.
WIFI: AP_MTK_MT7990_2G/AP_MTK_MT7990_5G/AP_MTK_MT7990_6G
SW3_A and SW3_B control the signal originating from the chip MT7987:
"00" indicates booting from SD.
"01" indicates booting from NOR.
"10" indicates booting from NAND.
"11" indicates booting from eMMC.
SW3_C, via U24, selects between NAND boot and NOR boot: When SW3_C is 1, the switch physically connects to NOR. When SW3_C is 0, the switch physically connects to NAND
SW3_D, selects between SD boot and EMMC boot: When SW3_D is 1, the switch physically connects to EMMC. When SW3_D is 0, the switch physically connects to SD Card.
F0: 102B 0000
F9: 1042 0000
F9: 1042 0000 [0200]
F8: 1041 0000
F8: 1041 0000 [0002]
F3: 1001 0000 [0200]
F3: 102C 0000
F5: 480A 0031
00: 1005 0000
F9: 1042 0000
F8: 1041 0000
F8: 1001 0000 [0200]
F3: 1001 0000
F3: 1001 0000
01: 102A 0001
02: 1005 0000
BP: 0280 00C0 [0001]
EC: 0000 0000 [0000]
MK: 0000 0000 [0000]
T0: 0000 00F7 [0101]
System halt!
The following figure is an example
As shown in the previous Boot Strapping picture:
For the image mtk-bpi-r4lite-EMMC-NAND-MP4_2-2PCIe-1L.img: Bootstrap loads from NAND, and this image is programmed into EMMC. The jumper settings should be 1001.Flashing to EMMC requires the bl2.emmc.img file.
For the image mtk-bpi-r4lite-EMMC-NOR-MP4_2-2PCIe-1L.img: Bootstrap loads from NOR, and this image is programmed into EMMC. The jumper settings should be 0111.Flashing to EMMC requires the bl2.emmc.img file.
For the image mtk-bpi-r4lite-NAND-MP4_2-2PCIe-1L.img: Bootstrap loads from SD Card, and this image is programmed into NAND. The jumper settings should be 0000.
For the image mtk-bpi-r4lite-NOR-MP4_2-2PCIe-1L.img: Bootstrap loads from SD Card, and this image is programmed into NOR. The jumper settings should be 0010.
For the image mtk-bpi-r4lite-SD-NOR-MP4_2-2PCIe-1L.img: This image on the SD card supports NOR flash but not NAND flash. Therefore, if you burn this image to an SD card and boot from it, and subsequently need to burn other images to NOR flash, you should burn this (particular) image
For the image mtk-bpi-r4lite-SD-NAND-MP4_2-2PCIe-1L.img: This image on the SD card supports NAND flash but not NOR flash. Therefore, if you burn this image to an SD card and boot from it, and subsequently need to burn other images to NAND flash, you should burn this (particular) image
Windows PC,Insert the SD card into a card reader, then plug the card reader into your computer. Format the SD card, making sure not to select the "Quick Format" option.
Linux PC, you can use the "mksf" command for formatting, or use the "dd" command to write zeros.
Burn image to SD card on windows computer
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Burn image to SD card on linux computer
You could download latest image from our forum
Install bpi-tools on your Ubuntu. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
After you download the image, insert your TF card into your Ubuntu. Execute
bpi-copy xxx.img /dev/sdx
to install image on your TF card
After step 3, then you can insert your TF card into R4_Lite, and press power button to setup R4_Lite
Change Boot Jumper to boot from SD, Enable SD Card Device.
| When you want to Update Nor device, Firstly Change boot switch to boot from SD device and insert one SD with SD boot Image, then after boot up,you need flash one Nor image into Nor device. Finally you change bootstrap to boot from Nor device. |
Before burning image into Nand, please prepare a USB disk. Let’s take OpenWrt image (mtk-bpi-r4lite-NOR.img ) for example, the steps are below:
Copy Nand boot OpenWrt image(mtk-bpi-r4lite-NOR.img) to USB disk.
Change boot switch Jumper, the board boot from SD device, then power up the board.
Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically)
mount -t vfat /dev/sda1 /mnt
cd /mnt/sda1
Execute following command to erase the whole Nor flash and copy image to nor device:
mtd erase /dev/mtd0
dd if=mtk-bpi-r4lite-NOR.img of=/dev/mtdblock0
Power off BPI-R4_Lite board, unplug u-disk driver, change bootstrap to boot from Nor device.
NAND has an image burned at the factory. If you want to use it, simply switch to the corresponding boot and then power on to start.
| When you want to Update Nand device, Firstly Change boot switch to boot from SD device and insert one SD with SD boot Image, then after boot up,you need flash one Nand image into Nand device. Finally you change bootstrap to boot from Nand device. |
Before burning image into Nand, please prepare a USB disk. Let’s take OpenWrt image (mtk-bpi-r4lite-NAND-0611.img) for example, the steps are below:
Copy Nand boot OpenWrt image(mtk-bpi-r4lite-NAND-0611.img) to USB disk.
cd /mnt/sda1
Execute following command to erase the whole Nand flash and copy image to nand device:
mtd erase /dev/mtd0
mtd write mtk-bpi-r4lite-NAND-0611.img /dev/mtd0
Power off BPI-R4_Lite board, unplug u-disk driver, change bootstrap to boot from Nand device.
| Because SD card and EMMC device share one SOC’s controller, it is necessary to switch to NAND startup and then burn the EMMC image into the EMMC. Finally, you will change the boot to boot from EMMC. |
Before burning image to eMMC, please prepare a USB disk. Let’s take OpenWrt image (bl2_emmc.img, mtk-bpi-r4lite-EMMC-NAND.img) for example, the steps are below:
Copy EMMC boot OpenWrt image(bl2_emmc.img,mtk-bpi-r4lite-EMMC-NAND.img) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
Change the switch jumper to Nand and start the motherboard from Nand.
cd /mnt/sda1
Execute :
echo 0 > /sys/block/mmcblk0boot0/force_ro
dd if=bl2_emmc.img of=/dev/mmcblk0boot0
dd if=mtk-bpi-r4lite-EMMC-NAND.img of=/dev/mmcblk0
mmc bootpart enable 1 1 /dev/mmcblk0
sync
sync
Power off R4_Lite board, remove u-disk driver, change bootstrap to boot from emmc device.
Network-Configuration refer to: http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start
Network Interface: WAN port is for WAN;SFP LAN, lan0, lan1, lan2,lan3 is for LAN, ra0/ra1 is for 2.4G wireless, rai0 is for 5G wifi6 wireless, rax0 is for 6G wifi7 wireless.
root@OpenWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
inet addr:10.0.6.1 Bcast:10.0.6.255 Mask:255.255.255.0
inet6 addr: fd7f:7a27:1d87::1/60 Scope:Global
inet6 addr: fe80::b8f0:a3ff:fe27:b253/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:99527801 errors:0 dropped:0 overruns:0 frame:0
TX packets:37709738 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:149207799463 (138.9 GiB) TX bytes:2498673864 (2.3 GiB)
br-wan Link encap:Ethernet HWaddr AA:0E:53:9B:EB:46
inet addr:10.168.1.125 Bcast:10.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::a80e:53ff:fe9b:eb46/64 Scope:Link
inet6 addr: fd3f:1b63:79e:0:a80e:53ff:fe9b:eb46/64 Scope:Global
RX packets:34911 errors:0 dropped:0 overruns:0 frame:0
TX packets:26689 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16527400 (15.7 MiB) TX bytes:10371963 (9.8 MiB)
eth0 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
UP BROADCAST RUNNING MULTICAST MTU:1504 Metric:1
RX packets:1866 errors:0 dropped:1 overruns:0 frame:0
TX packets:6100 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:483284 (471.9 KiB) TX bytes:4001138 (3.8 MiB)
Interrupt:73
eth1 Link encap:Ethernet HWaddr AA:0E:53:9B:EB:46
RX packets:3251292 errors:0 dropped:0 overruns:0 frame:1
TX packets:19493357 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:219561937 (209.3 MiB) TX bytes:29475758425 (27.4 GiB)
Interrupt:73
lan0 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:1615 errors:0 dropped:0 overruns:0 frame:0
TX packets:1583 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:417484 (407.6 KiB) TX bytes:710675 (694.0 KiB)
lan1 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lan2 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
lan3 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
lan5 Link encap:Ethernet HWaddr BA:F0:A3:27:B2:53
TX packets:2336 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:273011 (266.6 KiB)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:331 errors:0 dropped:0 overruns:0 frame:0
TX packets:331 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:89520 (87.4 KiB) TX bytes:89520 (87.4 KiB)
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:88
RX packets:19506966 errors:570 dropped:570 overruns:0 frame:0
TX packets:3871107 errors:57295 dropped:57295 overruns:0 carrier:0
RX bytes:29798518080 (27.7 GiB) TX bytes:253500928 (241.7 MiB)
ra1 Link encap:Ethernet HWaddr 02:0C:43:36:60:88
rai0 Link encap:Ethernet HWaddr 00:0C:43:26:60:C0
RX packets:99966624 errors:1084 dropped:1084 overruns:0 frame:0
TX packets:47357921 errors:278811 dropped:278811 overruns:0 carrier:0
RX bytes:152961245728 (142.4 GiB) TX bytes:3031675968 (2.8 GiB)
rax0 Link encap:Ethernet HWaddr 00:0C:43:26:60:78
root@OpenWrt:~# brctl show br-wan
bridge name bridge id STP enabled interfaces
br-wan 7fff.aa0e539beb46 no eth1
root@OpenWrt:~# brctl show br-lan
br-lan 7fff.baf0a327b253 no apclii0
apclix0
apcli0
ra1
rai0
rax0
lan2
lan0
lan5
ra0
lan3
lan1
root@OpenWrt:~#
| SFP-2.5G-T electrical modules supporting R3 |
BPI-R4_Lite supports M.2 USB Interface 4G LTE/5G Modules: Quectel EM05, RM500U-CN ,RM500Q-GL& RM520N-GL
If you want to use M.2 Cellular Module on BPI-R4_Lite:
Install 4G/5G Cellular Module into CN9 Slot(M.2 KEYB)
Inset NANOSIM Card into SIMSlot(SIM1) (pay attention to the direction)
Install antenna on the module
After powering on, it will automatically dial
| The availability of 4G/5G depends on the local carrier frequency band. |
Quectel RM520N-GL
Quectel RM520N-GL
wwan0 Link encap:Ethernet HWaddr 1A:F1:B9:87:ED:15
inet6 addr: fe80::18f1:b9ff:fe87:ed15/64 Scope:Link
UP RUNNING NOARP MTU:1500 Metric:1
RX packets:16 errors:0 dropped:0 overruns:0 frame:0
TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5476 (5.3 KiB) TX bytes:3668 (3.5 KiB)
wwan0_1 Link encap:Ethernet HWaddr 1A:F1:B9:87:ED:15
inet addr:10.6.0.91 Mask:255.255.255.248
RX packets:21 errors:0 dropped:0 overruns:0 frame:0
TX packets:29 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5570 (5.4 KiB) TX bytes:3668 (3.5 KiB)
root@OpenWrt:/#
root@OpenWrt:/# lsusb
Bus 001 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.281 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.281 xhci-hcd xHCI Host Controller
root@OpenWrt:/#
root@OpenWrt:/# ping www.baidu.com
PING www.baidu.com (183.2.172.177): 56 data bytes
64 bytes from 183.2.172.177: seq=0 ttl=53 time=19.850 ms
64 bytes from 183.2.172.177: seq=1 ttl=53 time=104.403 ms
64 bytes from 183.2.172.177: seq=2 ttl=53 time=63.774 ms
64 bytes from 183.2.172.177: seq=3 ttl=53 time=105.180 ms
64 bytes from 183.2.172.177: seq=4 ttl=53 time=65.546 ms
64 bytes from 183.2.172.177: seq=5 ttl=53 time=105.946 ms
^C
6 packets transmitted, 6 packets received, 0% packet loss
round-trip min/avg/max = 19.850/77.449/105.946 ms
root@OpenWrt:/#
BPI-R4_Lite supports MiniPCIe USB Interface 4G LTE Module :Quectel EC25
If you want to use MiniPCIe Cellular Module on BPI-R4_Lite:
Install 4G Cellular Module into CN11 Slot
Inset NANOSIM Card into SIMSlot(SIM2) with card tray(pay attention to the direction)
CN13 (SIM3) is also available
| The availability of 4G depends on the local carrier frequency band. |
Due to the compatibility of the BPI-R4_Lite with Qualcomm/Unisoc modules, the EC25 module cannot directly access the DNS server and connect to the internet. Therefore, manual configuration is required to modify the default.script file via console port.
vim /usr/share/udhcpc/default.script
Add: echo "nameserver 202.96.128.86" >> /etc/resolv.conf
Press the i key to enter edit mode, After completing the modifications, press the Esc key to exit edit mode. Then press Shift + :, type wq!, and press Enter to save and exit.
| Modify the IP address according to your local DNS server. |
EC25-E
wwan0 Link encap:Ethernet HWaddr 12:19:B1:54:2E:04
inet addr:10.41.254.97 Mask:255.255.255.252
inet6 addr: fe80::1019:b1ff:fe54:2e04/64 Scope:Link
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1623 (1.5 KiB) TX bytes:2222 (2.1 KiB)
root@Simon-R4:/#
root@Simon-R4:/# lsusb
Bus 001 Device 004: ID 2c7c:0125 Android Android
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.260 xhci-hcd xHCI Host Controller
Bus 001 Device 003: ID 2109:8822 VIA Labs, Inc. USB Billboard Device
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.260 xhci-hcd xHCI Host Controller
root@Simon-R4:/#
root@Simon-R4:/# ping www.baidu.com
PING www.baidu.com (183.2.172.42): 56 data bytes
64 bytes from 183.2.172.42: seq=0 ttl=52 time=24.309 ms
64 bytes from 183.2.172.42: seq=1 ttl=52 time=55.576 ms
64 bytes from 183.2.172.42: seq=2 ttl=52 time=55.507 ms
64 bytes from 183.2.172.42: seq=3 ttl=52 time=39.399 ms
64 bytes from 183.2.172.42: seq=4 ttl=52 time=31.386 ms
^C
round-trip min/avg/max = 24.309/41.235/55.576 ms
root@Simon-R4:/#
When using the PCIe to SATA or PCIe to USB, you must flash the 2PCIe-1Lane firmware image, since mPCIe A/B lanes have two configuration options: a single 2-lane interface(mPCIe A) or two separate 1-lane interfaces(mPCIe A+mPCIe B).
BPI-R4_Lite supports PCIe to SATA
root@OpenWrt:/# lspci
00:00.0 PCI bridge: MEDIATEK Corp. Device 7987 (rev 01)
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# cat /proc/partitions
major minor #blocks name
31 0 262144 mtdblock0
31 1 1024 mtdblock1
31 2 512 mtdblock2
31 3 4096 mtdblock3
31 4 2048 mtdblock4
31 5 115200 mtdblock5
253 0 60140 ubiblock0_1
root@OpenWrt:/#
BPI-R4_Lite Also supports PCIe to USB
01:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03)
Bus 001 Device 002: ID 0bda:c820 Realtek 802.11ac NIC
Bus 003 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 004 Device 002: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 004 Device 001: ID 1d6b:0003 Linux 5.4.281 xhci-hcd xHCI Host Controller
Bus 003 Device 001: ID 1d6b:0002 Linux 5.4.281 xhci-hcd xHCI Host Controller
root@R4CN:/#
You can insert the BPI-R4-NIC into CN11 and CN13 at the bottom of BPI-R4_Lite-Main, and then fix it with two M2 screws.
When using the BPI-R4-NIC module, you must flash the 2-lane firmware image, since mPCIe A/B lanes have two configuration options: a single 2-lane interface(mPCIe A) or two separate 1-lane interfaces(mPCIe A+mPCIe B).The BPI-R4-NIC module requires 12V power supply, so the power supply on the BPI-R4_Lite-Main must be turned on before powering on (SW4 is turned to the "ON" position, and the 12V LED will lights up when power on)
| The 12V power supply will be supplied to the BPI-R4-NIC through PIN6 / 28 / 48 of the miniPCI socket. When plugging in other modules, be sure to turn off SW4 if you cannot confirm whether the module can withstand 12v. |
BPI-R4-NIC-BE14 : MT7995AV+MT7976CN+MT7977IAN
root@R4RN:/# lspci
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0000:01:00.0 Network controller: MEDIATEK Corp. Device 7990
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0001:01:00.0 Network controller: MEDIATEK Corp. Device 7991
0004:00:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7981
root@R4RN:/# ifconfig
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:A8
RX packets:10 errors:10 dropped:0 overruns:0 frame:0
TX packets:46 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:320 (320.0 B) TX bytes:1184 (1.1 KiB)
rai0 Link encap:Ethernet HWaddr 00:0C:43:26:60:B8
RX packets:1290969 errors:51890 dropped:0 overruns:0 frame:0
TX packets:17549107 errors:254037 dropped:0 overruns:0 carrier:0
RX bytes:363742528 (346.8 MiB) TX bytes:25491834560 (23.7 GiB)
rax0 Link encap:Ethernet HWaddr 00:0C:43:26:60:28
RX packets:563140 errors:187 dropped:0 overruns:0 frame:0
TX packets:1683329 errors:11607 dropped:0 overruns:0 carrier:0
RX bytes:785902144 (749.4 MiB) TX bytes:2175529280 (2.0 GiB)
OpenWRT MTK MP4.0 WiFi Setting:
When all functions are OK, we can detect Three SSIDs and the three blue LEDs on BE14 will also light up.
You can click Config to modify the SSID and password.Then, locate the Wi-Fi with the corresponding name in the system tray (WLAN icon) at the bottom-right corner of your computer screen, enter the password, and ethernet be connected.
MTK OpwnWRT fan with PWM control reference.
View fan script settings
root@OpenWrt:/# cat /sbin/fan-speed
#!/bin/sh /etc/rc.common
if [ ! -f /sys/class/pwm/pwmchip0/export ]; then
exit 0
fi
### enable fan ###
echo 0 > /sys/class/pwm/pwmchip0/export
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
echo 7000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
while :
do
sleep 20
result=`cat /sys/class/thermal/thermal_zone0/temp`
temperature=$((result))
#echo $temperature
if [ ${temperature} -ge 53000 ]; then
echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
fi
if [ ${temperature} -ge 62000 ]; then
echo 1000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
fi
if [ ${temperature} -le 4800 ]; then
fi
if [ ${temperature} -le 4000 ]; then
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
fi
done
Disable the background running script (it auto-starts on boot; first stop the fan-speed process)
root@OpenWrt:/# ps w | grep fan
7167 root 1324 S /bin/sh /etc/rc.common /sbin/fan-speed
7435 root 1244 R grep fan
root@OpenWrt:/# kill -9 7167
7503 root 1244 S grep fan
Manually set PWM2 output ,duty_cycle controls fan speed; higher values increase rotation speed
root@OpenWrt:/# echo 2 > /sys/class/pwm/pwmchip0/export
root@OpenWrt:/# echo 10000 > /sys/class/pwm/pwmchip0/pwm2/period
root@OpenWrt:/# echo 5000 > /sys/class/pwm/pwmchip0/pwm2/duty_cycle
root@OpenWrt:/# echo normal > /sys/class/pwm/pwmchip0/pwm2/polarity
root@OpenWrt:/# echo 1 > /sys/class/pwm/pwmchip0/pwm2/enable
root@OpenWrt:/#
| DO not pull down UART1_TXD when power on. |
| BPI-R4_Lite 2x8 PIN MikroBUS Header(CN1) GPIO define of BPI-R4_Lite | |||
BPI-R4_Lite-CON2 |
PIN |
PIN |
BPI-R4_Lite-CON2 |
GND |
1 |
2 |
5V |
SDA |
3 |
4 |
SCL |
UART-TX |
5 |
6 |
UART-RX |
INT |
7 |
8 |
PWM |
AN |
9 |
10 |
RST |
SPI-CS |
11 |
12 |
SPI-CLK |
SPI-MISO |
13 |
14 |
SPI-MOSI |
3.3V |
15 |
16 |
GND |
| BPI-R4_Lite M.2 B-KEY(CN19) GPIO define of BPI-R4_Lite | |||
BPI-R4_Lite M.2 B-KEY(CN16) |
PIN |
PIN |
BPI-R4_Lite M.2 B-KEY(CN9) |
NI |
1 |
2 |
VCC_KEYB |
GND |
3 |
4 |
VCC_KEYB |
GND |
5 |
6 |
NGFF_KEYB_Card_PWRON(10K PullUp to 3.3V) |
KEYB_USB_Dp |
7 |
8 |
NGFF_KEYB_WWAN_DISABLE1n |
KEYB_USB_Dn |
9 |
10 |
NGFF_KEYB_NET_STUN |
GND |
11 |
12 |
NOTCH |
NOTCH |
13 |
14 |
15 |
16 |
17 |
18 |
19 |
20 |
NI |
NI |
21 |
22 |
NI |
KEYB-WAKEn |
23 |
24 |
NI |
NI |
25 |
26 |
NGFF_KEYB_GNSS_DISABLE2n |
GND |
27 |
28 |
NI |
KEYB-HSln |
29 |
30 |
USIM_RST-1A |
KEYB-HSLP |
31 |
32 |
USIM_CLK-1A |
GND |
33 |
34 |
USIM_DATA-1A |
KEYB-HSOn |
35 |
36 |
USIM_VDD-1A |
KEYB-HSOp |
37 |
38 |
NI |
GND |
39 |
40 |
NI |
NI |
41 |
42 |
USIM_DATA-1B |
NI |
43 |
44 |
USIM_CLK-1B |
GND |
45 |
46 |
USIM_RST-1B |
NI |
47 |
48 |
USIM_VDD-1B |
NI |
49 |
50 |
NI |
GND |
51 |
52 |
NI |
NI |
53 |
54 |
NI |
NI |
55 |
56 |
NI |
GND |
57 |
58 |
NI |
NI |
59 |
60 |
NI |
NI |
61 |
62 |
NI |
NI |
63 |
64 |
NI |
NI |
65 |
66 |
USIM_DET-1A |
NGFF_KEYB_RSTn_1P8V |
67 |
68 |
NI |
NI |
69 |
70 |
VCC_KEYB |
GND |
71 |
72 |
VCC_KEYB |
GND |
73 |
74 |
VCC_KEYB |
NI |
75 |
76 |
GND |
GND |
77 |
78 |
GND |
GND |
79 |
| BPI-R4_Lite miniPCIe(CN11) GPIO define of BPI-R4_Lite | |||
BPI-R4_Lite miniPCIe(CN11) |
PIN |
PIN |
PCIE_B_WAKEn_3P3V |
1 |
2 |
PCIe_3V3#B |
NI |
3 |
4 |
GND |
NI |
5 |
6 |
PCIe_12V#B |
PCIE_B_CLKREQn_3P3V |
7 |
8 |
USIM_VDD-3 |
GND |
9 |
10 |
USIM_DATA-3 |
mPCIe_B_CKn |
11 |
12 |
USIM_CLK-3 |
mPCIe_B_CKp |
13 |
14 |
USIM_RST-3 |
GND |
15 |
16 |
NI |
NI |
17 |
18 |
GND |
NI |
19 |
20 |
W_DISABLE_3 |
GND |
21 |
22 |
PCIE_B_PERSTn_3P3V |
mPCIe_B_RXn |
23 |
24 |
PCIe_3V3#B |
mPCIe_B_RXP |
25 |
26 |
GND |
GND |
27 |
28 |
PCIe_12V#B |
GND |
29 |
30 |
mPCIe_B_SCL |
mPCIe_B_TXn |
31 |
32 |
mPCIe_B_SDA |
mPCIe_B_TXp |
33 |
34 |
GND |
GND |
35 |
36 |
LTE-USBDM_3 |
GND |
37 |
38 |
LTE-USBDP_3 |
PCIe_3V3#B |
39 |
40 |
GND |
PCIe_3V3#B |
41 |
42 |
SIM3-WIFI-LED-6G |
GND |
43 |
44 |
USIM_DET-3 |
NI |
45 |
46 |
mPCIe_B_LED_WPAN-3 |
NI |
47 |
48 |
PCIe_12V#B |
NI |
49 |
50 |
GND |
NI |
51 |
52 |
PCIe_3V3#B |
GND |
55 |
56 |
GND |
| BPI-R4_Lite miniPCIe(CN13) GPIO define of BPI-R4_Lite | |||
BPI-R4_Lite miniPCIe(CN13) |
PIN |
PIN |
PCIE_A_WAKEn_3P3V |
1 |
2 |
PCIe_3V3#A |
NI |
3 |
4 |
GND |
NI |
5 |
6 |
PCIe_12V#A |
PCIE_A_CLKREQn_3P3V |
7 |
8 |
USIM_VDD-2 |
GND |
9 |
10 |
USIM_DATA-2 |
mPCIe_A_CKn |
11 |
12 |
USIM_CLK-2 |
mPCIe_A_CKp |
13 |
14 |
USIM_RST-2 |
GND |
15 |
16 |
NI |
mPCIe_AB_RXn |
17 |
18 |
GND |
mPCIe_AB_RXn |
19 |
20 |
W_DISABLE_2 |
GND |
21 |
22 |
PCIE_A_PERSTn_3P3V |
mPCIe_A_RXn |
23 |
24 |
PCIe_3V3#A |
mPCIe_A_RXP |
25 |
26 |
GND |
GND |
27 |
28 |
PCIe_12V#A |
GND |
29 |
30 |
mPCIe_A_SCL |
mPCIe_A_TXn |
31 |
32 |
mPCIe_A_SDA |
mPCIe_A_TXp |
33 |
34 |
GND |
GND |
35 |
36 |
LTE-USBDM_2 |
GND |
37 |
38 |
LTE-USBDP_2 |
PCIe_3V3#A |
39 |
40 |
GND |
PCIe_3V3#A |
41 |
42 |
SIM2-WIFI-LED-5G |
GND |
43 |
44 |
USIM_DET-2 |
mPCIe_AB_TXn |
45 |
46 |
SIM2-WIFI-LED-2G |
mPCIe_AB_RXn |
47 |
48 |
PCIe_12V#A |
49 |
50 |
GND |
GND |
51 |
52 |
PCIe_3V3#A |
GND |
55 |
56 |
GND |
57 |
58 |
GND |
| BPI-R4_Lite FAN(CN1,PH3A-2.54mm) of BPI-R4_Lite | |
+5V |
1 |
GND |
2 |
PWM2 |
3 |
| BPI-R4_Lite FAN(CN1,PH3A-2.00mm) of BPI-R4_Lite | |
GND |
1 |
+12V |
2 |
NC |
3 |
PWM2 |
4 |
