Banana Pi BPI-R4 Mini Wifi7 smart router board design with MediaTek MT7987A Quad-core Arm Cortex-A53,it support 2GB DDR4 and 8G eMMC Flash on board. 2 x 2.5G RJ45, Wifi7 onboard,Mini Size .
USB Disk
USB TypeC cable
CAT6A/Cat5e Ethernet cable
12V/5A power adapter(without any peripherals and network cable inset, the power consumption of BPI-R4MINI Main Board is about 10W, so 12V/2A will work.
But you need to determine whether you need a higher power power adapter according to your own accessory usage,12V/5A is recommended)
Windows/unbuntu system
All Jumper is "1", BPI-R4Mini will boot from emmc card
SW3-B is "0" and SW3-A is "1" , BPI-R4Mini will boot from SPI NAND
SW3-B is "1" and SW3-A is "0" , BPI-R4Mini will boot from SPI NOR
If the console said "system halt!", it means that the bootup storage does not cotain any OS
| Factory image information:OpenWrt 24.10-SNAPSHOT Architecture:aarch64_cortex-a53 |
Before flashing image into Nand, please prepare a USB disk. Let’s take OpenWrt image (mtk-bpi-r4mini-NAND-20260721.img) for example, the steps are below:
Format the USB disk to FAT32.
Copy Nand boot OpenWrt image(mtk-bpi-r4mini-NAND-20260721.img) to USB disk.
Change the bootstrap to eMMC boot, then power up the board.
Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically)
mount -t vfat /dev/sda1 /mnt
cd /mnt
Execute following command to erase the whole Nand flash and copy image to nand device: Notice:The R4mini’s NAND image is flashed to MTD0
mtdinfo /dev/mtd0
mtd0
Type: nand
Eraseblock size: 131072 bytes, 128.0 KiB
Amount of eraseblocks: 2048 (268435456 bytes, 256.0 MiB)
Minimum input/output unit size: 2048 bytes
Sub-page size: 2048 bytes
OOB size: 128 bytes
Character device major/minor: 90:0
Bad blocks are allowed: true
Device is writable: true
cat /proc/mtd
dev: size erasesize name
mtd0: 10000000 00020000 "spi0.0"
mtd1: 0f000000 00020000 "nmbm_spim_nand"
mtd2: 00480000 00010000 "BL2"
mtd3: 00400000 00010000 "Factory"
mtd4: 00200000 00010000 "FIP"
mtd5: 02000000 00010000 "Kernel"
mtd6: 40000000 00010000 "rootfs"
mtd7: 3cb90000 00010000 "rootfs_data"
mtd8: 80000000 00010000 "usrdata"
mtd9: 10f580000 00010000 "bmtpool"
flash_erase /dev/mtd0 0 2048
Erasing 128 Kibyte @ ffe0000 -- 100 % complete
mtd erase /dev/mtd0
mtd write mtk-bpi-r4mini-NAND-20260721 /dev/mtd0
Power off BPI-R4Mini, remove usb disk , change bootstrap to nand boot and power up again.
| It is necessary to switch to NAND startup and then burn the EMMC image into the EMMC. Finally, you will change the bootstrap to boot from EMMC. |
Let’s take OpenWrt image (bl2_emmc-r4mini.img, mtk-bpi-r4mini-EMMC-20260721) for example, the steps are below:
Copy EMMC boot OpenWrt image(bl2_emmc-r4mini.img, mtk-bpi-r4mini-EMMC-20260721) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
Change the bootstrap to Nand boot and power up R4Mini.
cd /mnt
Execute command
dmesg | grep mmcblk0
[ 5.778706] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 5.783936] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 5.790558] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 5.796568] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (245:0)
[ 5.831079] mmcblk0: p1 p2 p3 p4 p5
echo 0 > /sys/block/mmcblk0boot0/force_ro
dd if=bl2_emmc-r4mini.img of=/dev/mmcblk0boot0
489+1 records in
489+1 records out
dd if=mtk-bpi-r4mini-EMMC-20260721.img of=/dev/mm
194335+1 records in
194335+1 records out
mmc bootpart enable 1 1 /dev/mmcblk0
sync
sync
Power off BPI-R4Mini, remove u-disk driver, change bootstrap to emmc boot and power up again.
Method:Recovery emmc system first,then see "How to flashing image to NAND Flash"
Make sure that the NOR flash is ready.
Install the NOR flash to the board(CN15).
NOR Flash:
Before installation:
After installation:
Switch the bootstrap to NOR and boot up.
cd /mnt
Execute command
mtdinfo /dev/mtd0
dd if=mtk-bpi-r4mini-EMMC-20260721.img of=/dev/mmcblk0
sync
sync
Using your USB TypeC cable Connect to debug console(CN3) on BPI-R4Mini
Install Terminal Emulator or use a serial terminal that you are familiar with,
change the setting as follows: Baud=115200,Data bits: 8bit,Parity: none,Stop: 1bit, Flow control: none;
Set up the bootstrap before supplying power, (If you are using BPI-R4Mini for the first time, it is recommended to set it to NAND boot)
when Connect power adapter to DC-IN connector(CN6),Green LED “PWR” light up,And there will be characters similar to the following on the console. This means you have successfully started BPI-R4Mini.
F0: 102B 0000
F9: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0680 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [1000]
MK: 0000 0000 [0000]
T0: 0000 0364 [0101]
Jump to BL
NOTICE: BL2: v2.12.0(release):
NOTICE: BL2: Built : 13:41:03, Jul 14 2026
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7987A
NOTICE: EMI: Using DDR4 settings
NOTICE: DDR4 Speed: 3200 Mbps
NOTICE: DDR tREFI: 3.9 us
NOTICE: DDR power-down option: 2
NOTICE: EMI: Detected DRAM size: 2048 MB
NOTICE: EMI: complex R/W mem test passed
NOTICE: LVTS: Enable thermal HW reset
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.12.0(release):
NOTICE: BL31: Built : 13:41:05, Jul 14 2026
U-Boot 2025.07-rc3 (Jul 14 2026 - 20:49:48 +0800)
CPU: MediaTek MT7987
Model: mt7987
(mediatek,mt7987-spim-nor-rfb)
DRAM: 2 GiB
Core: 79 devices, 13 uclasses, devicetree: separate
Loading Environment from MTD... SF: Detected w25q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
Network-Configuration refer to: http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start
Network Interface: eth1,br-wan is for WAN; eth1, br-lan is for LAN, ra0 is for 2.4G wireless, rai0 is for 5G wireless.
root@OpenWrt:/# ifconfig
br-lan Link encap:Ethernet HWaddr DA:1F:26:22:7B:5E
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fd2b:6d4e:9e56::1/60 Scope:Global
inet6 addr: fe80::d81f:26ff:fe22:7b5e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:939 errors:0 dropped:0 overruns:0 frame:0
TX packets:537 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:77387 (75.5 KiB) TX bytes:55390 (54.0 KiB)
br-wan Link encap:Ethernet HWaddr 1A:DB:A6:84:0A:E0
inet6 addr: fe80::18db:a6ff:fe84:ae0/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1626 (1.5 KiB)
eth0 Link encap:Ethernet HWaddr DA:1F:26:22:7B:5E
RX packets:1121 errors:0 dropped:1 overruns:0 frame:0
TX packets:531 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:113218 (110.5 KiB) TX bytes:55674 (54.3 KiB)
Interrupt:73
eth1 Link encap:Ethernet HWaddr 1A:DB:A6:84:0A:E0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:73
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:330 errors:0 dropped:0 overruns:0 frame:0
TX packets:330 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:26614 (25.9 KiB) TX bytes:26614 (25.9 KiB)
rai0 Link encap:Ethernet HWaddr 00:0C:43:26:60:11
bridge name bridge id STP enabled interfaces
br-wan 7fff.1adba6840ae0 no eth1
br-lan 7fff.da1f26227b5e no eth0
apclii0
apcli0
rai0
ra0
root@OpenWrt:/#
| NOTE: The image files we release use a random MAC address on each boot and do not utilize EEPROM. If you wish to use EEPROM, you will need to write a script to read the data and update the port. |
hexdump -C /sys/bus/i2c/devices/0-0057/eeprom
printf '\x01\x02\x03\x04\x05\x06' | dd of=/sys/bus/i2c/devices/0-0057/eeprom bs=1 seek=32 conv=notrunc
"\x01\x02\x03\x04\x05\x06" is the content you want to write, which can be a MAC address, serial number, or other information.
"bs=1" means the block size is 1.
"seek=32" means the offset (how many blocks to skip).
"bs=1 seek=32" means to skip 32 bytes, which corresponds to skipping bytes from 0x00 to 0x1F, and start writing content from 0x20.
"conv=notrunc" do not truncate the EEPROM, preserve the original data.
For example, I want to write two sets of MAC addresses to addresses 0x20 and 0x30 respectively:
printf '\x12\x41\x89\x7F\x64\xD3' | dd of=/sys/bus/i2c/devices/0-0057/eeprom bs=1 seek=32 conv=notrunc
printf '\x7E\xF5\x56\x36\x4C\xD1' | dd of=/sys/bus/i2c/devices/0-0057/eeprom bs=1 seek=48 conv=notrunc
| PS: Since subsequent batches of the V1.2 version are planned to write data to the EEPROM, addresses ranging from 0x00 to 0x1F must be avoided. |
BPI-R4Mini (2.5G WAN)→ BPI-R4Min (2.5G LAN)
root@OpenWrt:~# iperf3 -c 192.168.2.1
Connecting to host 192.168.2.1, port 5201
[ 5] local 192.168.2.219 port 41332 connected to 192.168.2.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 275 MBytes 2.31 Gbits/sec 0 991 KBytes
[ 5] 1.00-2.00 sec 275 MBytes 2.31 Gbits/sec 0 1.02 MBytes
[ 5] 2.00-3.00 sec 274 MBytes 2.30 Gbits/sec 0 1.02 MBytes
[ 5] 3.00-4.00 sec 275 MBytes 2.31 Gbits/sec 0 1.02 MBytes
[ 5] 4.00-5.00 sec 274 MBytes 2.30 Gbits/sec 0 1.08 MBytes
[ 5] 5.00-6.00 sec 274 MBytes 2.30 Gbits/sec 0 1.08 MBytes
[ 5] 6.00-7.00 sec 274 MBytes 2.30 Gbits/sec 0 1.14 MBytes
[ 5] 7.00-8.00 sec 275 MBytes 2.31 Gbits/sec 0 1.14 MBytes
[ 5] 8.00-9.00 sec 274 MBytes 2.30 Gbits/sec 0 1.14 MBytes
[ 5] 9.00-10.00 sec 275 MBytes 2.31 Gbits/sec 0 1.14 MBytes
[ 5] 0.00-10.00 sec 2.68 GBytes 2.30 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 2.68 GBytes 2.30 Gbits/sec receiver
iperf Done.
root@OpenWrt:~# iperf3 -c 192.168.2.1 -R
Reverse mode, remote host 192.168.2.1 is sending
[ 5] local 192.168.2.219 port 52400 connected to 192.168.2.1 port 5201
[ 5] 0.00-1.00 sec 272 MBytes 2.28 Gbits/sec
[ 5] 1.00-2.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 2.00-3.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 3.00-4.00 sec 272 MBytes 2.28 Gbits/sec
[ 5] 4.00-5.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 5.00-6.00 sec 271 MBytes 2.28 Gbits/sec
[ 5] 6.00-7.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 7.00-8.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 8.00-9.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 9.00-10.00 sec 273 MBytes 2.29 Gbits/sec
[ 5] 0.00-10.00 sec 2.66 GBytes 2.29 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 2.66 GBytes 2.29 Gbits/sec receiver
iperf Done.
root@OpenWrt:~# iperf3 -c 192.168.2.1 -bidir
[ 5] local 192.168.2.219 port 55952 connected to 192.168.2.1 port 5201
[ 5] 0.00-1.00 sec 271 MBytes 2.27 Gbits/sec 0 867 KBytes
[ 5] 1.00-2.00 sec 275 MBytes 2.31 Gbits/sec 0 909 KBytes
[ 5] 2.00-3.00 sec 274 MBytes 2.30 Gbits/sec 0 1.06 MBytes
[ 5] 3.00-4.00 sec 274 MBytes 2.30 Gbits/sec 0 1.11 MBytes
[ 5] 4.00-5.00 sec 275 MBytes 2.31 Gbits/sec 0 1.11 MBytes
[ 5] 5.00-6.00 sec 274 MBytes 2.30 Gbits/sec 0 1.16 MBytes
[ 5] 6.00-7.00 sec 274 MBytes 2.30 Gbits/sec 0 1.29 MBytes
[ 5] 7.00-8.00 sec 275 MBytes 2.31 Gbits/sec 0 1.29 MBytes
[ 5] 8.00-9.00 sec 274 MBytes 2.30 Gbits/sec 0 1.29 MBytes
[ 5] 9.00-10.00 sec 275 MBytes 2.31 Gbits/sec 0 1.29 MBytes
[ 5] 0.00-10.00 sec 2.67 GBytes 2.29 Gbits/sec receiver
iperf Done.
The BPI-R4Pro has one M.2 B-KEY slots, all for 4G/5G Cellular Modules.
it supports a pair of USB2.0 and USB3.0 signals, both extended via a USB 3.0 hub.
In addition, the CN8h have an additional PCIe3.0 1lane signal.
The M.2 key Slot can only install one type of M.2 key module.
So the 4G/5G module and NvMe SSD can be installed only one.
SIM1 can use the onboard NANO SIM Slot
It’s a 16pin conncetor.
It is usually used to connect spi lcd or i2c capacitive touch screen.
The BPI-R4Mini has an onboard USB-to-UART chip(HT42B534-2), connected to the MT7988A’s Debug UART.
When connected USB Type-c connector(CN41) to PC, a USB-to-serial device will appear, which can be used for debugging.
Terminal setting : Baud=115200,Data bits: 8bit,Parity: none,Stop: 1bit, Flow control: none.
PIN42/44/46/48 of M.2 B-KEY Slot is the second set of SIM card signals.
NOTE : This requires your module to support it and this requires additional installtion of eSIM module.
Built-in one EEPROM chip (P24C02A), can be used to store small amounts of data.
BPI-R4Mini has LEDs to indicate various operating states, including power, WiFi, Ethernet, 4G/5G cellular, etc
1x Power Green LED, Silkscreen "PWR" on the PCB,lights up when powered on and cannot be controlled by the software.
1x Status Blue LED,Silkscreen "B" on the PCB,Controlled by GPIO "PCA_A_IO1_6/SYS_LEDB".
2x WiFi Status Blue LEDs,The silk screen printing"W2G","W5G".
1x 5G cellular Status Blue LEDs,The silk screen
Each 2.5G RJ45 has two LEDs, and each 1G RJ45 has one LED to indicate the network status.
BPI-R4Pro requires a single +12V supply,and has multiple power supply , including DC power adapter, USB PD, POE, etc.
The supply voltage range is 9~24V, 12V or 20V is recommended, and it will automatically shut down when it exceeds 25.3V.
You can use a 12V/5A power adapter and plug it into the CN44 to power it. However, if other power supply exist at the same time, it will be switched to other power supply.
The dimensions of the CN44 slot are as follows(Inner Positive, Outer Negative):
The USB Type-C PD connector is connected to a CH224Q chip, which is used to communicate with the USB adapter and allow the adapter to output 20V voltage.
It is recommended to use a PD power supply that can output 20V and 65W or more.
BPI-R4Mini has a USB2.0 Type-A connector that can be used to connect a USB flash drive or other USB devices.
The power output of the USB2.0 connector (CN12) is 5V/1300mA, which can be turned off via "PCA_A_IO1_3/VBUS_AB_PDN" output low.
Thare are 3 ANT for WIFI.
There are 3 ANTs for 4G.
There are 4 ANTs for 5G.
BPI-R4Mini supports M.2 USB Interface 4G LTE/5G Modules: Quectel EM05, RM500U-CN.
If you want to use M.2 Cellular Module on BPI-R4Mini:
Install 4G/5G Cellular Module into CN16 Slot(M.2 KEYB)
Inset NANOSIM Card into SIMSlot
Install antenna on the module
After powering on, it will automatically dial
| The availability of 4G/5G depends on the local carrier frequency band |
Quectel RM500U-CNV
Quectel RM520N-GL
root@OpenWrt:/# ifconfig usb0
usb0 Link encap:Ethernet HWaddr 66:95:BC:F5:84:B3
inet addr:10.1.58.8 Bcast:10.1.58.255 Mask:255.255.255.0
inet6 addr: fe80::6495:bcff:fef5:84b3/64 Scope:Link
inet6 addr: 2409:895a:30b6:738:6495:bcff:fef5:84b3/64 Scope:Global
RX packets:587 errors:0 dropped:0 overruns:0 frame:0
TX packets:867 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:262208 (256.0 KiB) TX bytes:200656 (195.9 KiB
root@OpenWrt:/# lsusb
Bus 001 Device 002: ID 1a86:8091 USB HUB
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.300 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2c7c:0900 Quectel RM500U-CNV
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.300 xhci-hcd xHCI Host Controller
root@OpenWrt:/#
root@OpenWrt:/# ping www.baidu.com
PING www.baidu.com (2409:8c54:870:310:0:ff:b0ed:40ac): 56 data bytes
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=0 ttl=51 time=64.183 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=1 ttl=52 time=26.048 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=2 ttl=52 time=25.857 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=3 ttl=52 time=26.411 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=4 ttl=52 time=61.369 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=5 ttl=52 time=165.066 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=6 ttl=52 time=60.570 ms
64 bytes from 2409:8c54:870:310:0:ff:b0ed:40ac: seq=7 ttl=52 time=35.351 ms
^C
8 packets transmitted, 8 packets received, 0% packet loss
round-trip min/avg/max = 25.857/58.106/165.066 ms
root@OpenWrt:/#
EM05-CE
wwan0 Link encap:Ethernet HWaddr 02:45:EC:8E:AD:80
inet addr:10.7.83.4 Bcast:0.0.0.0 Mask:255.255.255.248
inet6 addr: fe80::45:ecff:fe8e:ad80/64 Scope:Link
UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:236 (236.0 B) TX bytes:3626 (3.5 KiB)
Bus 001 Device 013: ID 2c7c:0125 Quectel Incorporated LTE Module
PING www.baidu.com (111.45.11.5): 56 data bytes
64 bytes from 111.45.11.5: seq=0 ttl=52 time=80.437 ms
64 bytes from 111.45.11.5: seq=1 ttl=52 time=36.296 ms
64 bytes from 111.45.11.5: seq=2 ttl=53 time=41.240 ms
64 bytes from 111.45.11.5: seq=3 ttl=53 time=36.076 ms
64 bytes from 111.45.11.5: seq=4 ttl=53 time=41.002 ms
^C
round-trip min/avg/max = 36.076/47.010/80.437 ms
root@OpenWrt:/#
Please insert one M.2 NVMe SSD(PCI interface) into KeyB slot(CN8).
| No compatibility testing has been done and there is no guarantee that all SSDs can be used. |
root@OpenWrt:/# lspci
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7987 (rev 01)
0000:01:00.0 Non-Volatile memory controller: Intel Corporation NVMe Optane Memory Series
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7987 (rev 01)
0001:01:00.0 Network controller: MEDIATEK Corp. Device 7993
root@OpenWrt:/# cat /proc/partitions
major minor #blocks name
259 0 14065664 nvme0n1
259 1 14063616 nvme0n1p1
179 0 7634944 mmcblk0
179 1 512 mmcblk0p1
179 2 4096 mmcblk0p2
179 3 2048 mmcblk0p3
179 4 32768 mmcblk0p4
179 5 262144 mmcblk0p5
31 0 4608 mtdblock0
31 1 4096 mtdblock1
31 2 2048 mtdblock2
31 3 32768 mtdblock3
31 4 1048576 mtdblock4
31 5 994880 mtdblock5
31 6 2097152 mtdblock6
31 7 4445696 mtdblock7
root@OpenWrt:/# ls /dev/nvm*
/dev/nvme0 /dev/nvme0n1 /dev/nvme0n1p1
root@OpenWrt:/# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 52.5M 52.5M 0 100% /rom
tmpfs 997.4M 164.0K 997.2M 0% /tmp
/dev/mtdblock5 971.6M 5.6M 965.9M 1% /overlay
overlayfs:/overlay 971.6M 5.6M 965.9M 1% /
tmpfs 512.0K 0 512.0K 0% /dev
root@OpenWrt:/mnt/nvme# mount /dev/nvme0n1p1 /mnt/nvme
root@OpenWrt:/mnt/nvme# df -h
/dev/nvme0n1p1 13.4G 80.2M 13.3G 1% /mnt/nvme
MTK OpwnWRT MP4.0 fan with PWM control reference.
root@OpenWrt:~# cat /sbin/fan-speed
#!/bin/sh /etc/rc.common
if [ ! -f /sys/class/pwm/pwmchip0/export ]; then
exit 0
fi
### enable fan ###
echo 2 > /sys/class/pwm/pwmchip0/export
echo 10000 > /sys/class/pwm/pwmchip0/pwm2/period
echo 7000 > /sys/class/pwm/pwmchip0/pwm2/duty_cycle
echo normal > /sys/class/pwm/pwmchip0/pwm2/polarity
echo 1 > /sys/class/pwm/pwmchip0/pwm2/enable
while :
do
sleep 20
result=`cat /sys/class/thermal/thermal_zone0/temp`
temperature=$((result))
#echo $temperature
if [ ${temperature} -ge 53000 ]; then
fi
if [ ${temperature} -ge 62000 ]; then
echo 10000 > /sys/class/pwm/pwmchip0/pwm2/duty_cycle
fi
if [ ${temperature} -le 4800 ]; then
echo 5000 > /sys/class/pwm/pwmchip0/pwm2/duty_cycle
fi
if [ ${temperature} -le 4000 ]; then
echo 3000 > /sys/class/pwm/pwmchip0/pwm2/duty_cycle
fi
done
root@OpenWrt:~#
| BPI-R4Mini FAN Connector PIN define | |
PIN No. |
Connection Destination |
1 |
5V |
2 |
GND |
3 |
PWM |
| BPI-R4Mini M.2 B-KEY Slot1(CN8) PIN define | |||
PIN No. |
PIN NO. |
NI |
1 |
2 |
VDD_BKEY_A |
GND |
3 |
4 |
VDD_BKEY_A |
GND |
5 |
6 |
NI(10K PullUp to 3.3V) |
USBHUB_USB1_Dp |
7 |
8 |
NI |
USBHUB_USB1_Dn |
9 |
10 |
BKEY-A-NET-STUn LED |
GND |
11 |
12 |
NOTCH |
NOTCH |
13 |
14 |
NOTCH |
NOTCH |
15 |
16 |
NOTCH |
NOTCH |
17 |
18 |
NOTCH |
NOTCH |
19 |
20 |
NI |
NI |
21 |
22 |
NI |
NI |
23 |
24 |
NI |
NI |
25 |
26 |
NI |
GND |
27 |
28 |
NI |
USBHUB_USB1_RXn |
29 |
30 |
USIM_RST-1A |
USBHUB_USB1_RXp |
31 |
32 |
USIM_CLK-1A |
GND |
33 |
34 |
USIM_DATA-1A |
USBHUB_USB1_TXn |
35 |
36 |
USIM_VDD-1A |
USBHUB_USB1_TXp |
37 |
38 |
NI |
GND |
39 |
40 |
NI |
PCIE_SW_A_C_RXn |
41 |
42 |
USIM_DATA-1B |
PCIE_SW_A_C_RXp |
43 |
44 |
USIM_CLK-1B |
GND |
45 |
46 |
USIM_RST-1B |
PCIE_SW_A_C_TXn |
47 |
48 |
USIM_VDD-1B |
PCIE_SW_A_C_TXp |
49 |
50 |
BKEY-A-PRESET_3P3V |
GND |
51 |
52 |
BKEY-A-CLKREQ_3P3V |
PCIE_SW_A_C_CKn |
53 |
54 |
BKEY-A-WAKE_3P3V |
PCIE_SW_A_C_CKp |
55 |
56 |
NI |
GND |
57 |
58 |
NI |
NI |
59 |
60 |
NI |
NI |
61 |
62 |
NI |
NI |
63 |
64 |
NI |
NI |
65 |
66 |
USIM_DET-1A |
BKEY-A-RST |
67 |
68 |
NI |
NI |
69 |
70 |
VDD_BKEY_A |
GND |
71 |
72 |
VDD_BKEY_A |
GND |
73 |
74 |
VDD_BKEY_A |
NI |
75 |
| BPI-R4Mini FPC Connector(CN13) PIN define | |||
PIN No. |
PIN NO. |
SPI_MOSI |
1 |
2 |
SPI_MISO |
SPI_CLK |
3 |
4 |
SPI_CS |
SPI_IO1 |
5 |
6 |
SPI_IO2 |
GND |
7 |
8 |
CTP_SCL |
CTP_SDA |
9 |
10 |
CTP_INT |
CTP_RST |
11 |
12 |
GND |
D1M |
13 |
14 |
D1P |
5V0 |
15 |
16 |
3V3 |
| BPI-R4mINI DCIN Connector(CN7) PIN define | |
PIN No. |
1 |
DCIN_12_24V |
2 |
GND |
| BPI-R4Mini SPI NOR(CN15) PIN define | |||
PIN No. |
PIN NO. |
SPI_MOSI |
1 |
2 |
BOOT_SEL2 |
SPI_MISO |
3 |
4 |
NOTCH |
SPI_CLK |
5 |
6 |
NOTCH |
SPI_CS |
7 |
8 |
NOTCH |
SPI_WP |
9 |
10 |
NOTCH |
SPI_HOLD |
11 |
12 |
NOTCH |
VCC33 |
13 |
14 |
DNU |
GND |
15 |
16 |
DNU |
NOR/NAND_CS_SEL |
17 |
18 |
DNU |
BOOT_SEL1 |
19 |
20 |
DNU |
