| More Infomation:Banana Pi WiFi6 Mini |
Ethernet cable, BPI-WiFi6 Mini, 12V power supply
First, download the image you want to upgrade.
Power on the BPI-WiFi6 Mini and connect it to the computer using a network cable.
Enter the webpage (default IP is 192.168.1.1,the user is root and does not have a password.)
Select “System", then select "Backup/Flash Firmware".
Select "Flash image…".
Select the image you want to upgrade, and then click "Upload".
Uncheck "Keep settings and retain the current configuration".Select "Continue".
Wait a few minutes, after the upgrade is completed, it will automatically restart and the web page will automatically refresh.
You can check the WiFi startup status in the Network’s wireless section. Among them, Triductor_2GAp and Triductor_5GAp are the WiFi of BPI-WiFi6. You can also make the configuration in the "Edit" section.
You can view USB devices by executing the lsusb command.
root@OpenWrt:/# lsusb
Bus 001 Device 002: ID 05e3:0751 USB Storage USB Storage
Bus 002 Device 001: ID 1d6b:0003 Linux 5.10.138 xhci-hcd xHCI Host Controller
Bus 001 Device 001: ID 1d6b:0002 Linux 5.10.138 xhci-hcd xHCI Host Controller
Furthermore, the USB interface is already configured in the source code, so it can be used without any modifications.
