Banana Pi BPI-Wifi6 Mini Open source Router design with Triductor TR6560 + TR5220 wifi SOC, it is a mini size wifi6 router solution. Built-in high-performance dual-core ARM Cortec A9 processor for WIFI message forwarding or intelligent business processing, built-in high-performance LSW and hardware NAT, supporting up to 5Gbps message forwarding,Integrated 5*GE PHY, provides 1000Mbps network access capability. Support hardware intelligent QoS. Support dual-band 2.4G 40M 2*2 +5G160M2.2 DBDC WIFI,Wifi protocol version support to IEEE 802.11ax, backward compatible 802.11a /b/g/n/ac, can support the highest rate of 3Gbps, 2G will reach 573.5Mbps, while 5G will reach 2401.9Mbp
Triductor TR6560 + TR5220 wifi design: Banana Pi BPI-Wifi6 Router low cost wifi6 Router board Triductor TR6560 + TR5220 wifi design: Banana Pi BPI-Wifi6 Mini Router low cost Mini wifi6 Router board same size as: Banana Pi BPI-R3 Mini Siflower SF19A2890S + AN8855R design Banana Pi BPI-Wifi5 Router low cost wifi5 Router board |
Dual core ARM Cortex-A9 1.2G Hz
Integrated 2*GE PHY
Support 1000M/100M/10M rate mode self-negotiation and standard MIB
Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
Support Wifi AP mode and STA mode
Support WPA,WPA2, WPA3 encryption and decryption, pay Chinese WAPI standard
M.2 Key B interfce (USB 3.0 4G LTE/5G NR)
Source code on github: Old source code: https://github.com/BPI-SINOVOIP/THG6500-TAX2-mini-OPENWRT-BSP New source code: https://github.com/BPI-SINOVOIP/THG6500-MINI-TAX2-OPENWRT-BSP_TGP3 |
Note: The old source code is incompatible with the new hardware and will cause WiFi malfunctions. The new source code is compatible with the old hardware, but its use is not recommended. The new source code requires a MAC address and corresponding key; otherwise, WiFi functionality will be limited, and the device will restart every hour. Based on the silkscreen markings on the main chip, the new WiFi chip is vertical, while the old WiFi chip is horizontal. |
| WiFi6mini V10 Schematic |
Baidu: https://pan.baidu.com/s/1wMiu6AV0YKWSLZibt9sKqw?pwd=8888 code: 8888
| WiFi6mini V10 ASSY |
Baidu: https://pan.baidu.com/s/1oMEKqqjDZQoQMYF5H959vg?pwd=8888 code: 8888
| 20251223-tgp3.3.4-WiFi6-mini-THG6500-TAX2-squashfs-sysupgrade.bin |
Baidu cloud: https://pan.baidu.com/s/1OGMMzjkx7GDrGKg9XWqnzA?pwd=8888 (pincode:8888)
| tgp3.1.0-THG6500-TAX2-squashfs-sysupgrade.bin |
Baidu cloud: https://pan.baidu.com/s/1ytTnbUGetBd6foVDBTwTWg?pwd=8888 (pincode: 8888)
Banana Pi BPI-wifi6 mini same size as Banana Pi BPI-R3 Mini , so can use same case as BPI-R3 mini
lowcost case :
Banana Pi BPI-wifi6 mini have test quectel EM05 4G module support
Test demo veide on youtube: https://www.youtube.com/watch?v=Q4nxK475KdM
Banana Pi BPI-wifi6 mini have test quectel RM500U 5G module support
BPI-Wifi6 mini is same size as BPI-R3 Mini,can use BPI-R3 Mini case
Answer: yes.
| BANANAPI Official shop: https://www.bpi-shop.com/products/banana-pi-bpi-wifi6-mini-open-source-router-design-with-triductor-tr6560-tr5220-wifi-soc.html |
| SinoVoip aliexpress shop: https://www.aliexpress.com/item/1005007316957256.html?spm=5261.promotion_single_products.table.1.3bfb15d1tQ4Prf&gatewayAdapt=4itemAdapt |
| Bipai aliexpress shop: https://www.aliexpress.com/item/1005007316915633.html?spm=5261.promotion_single_products.table.1.7faa4edfcV2VgX |
| BPI-Wifi6 Mini metal case Sinovoip Aliexpress Shop: https://www.aliexpress.com/item/1005009130658458.html |
| BPI-Wifi6 Mini metal case BIPAI Aliexress shop: https://www.aliexpress.com/item/1005009130634709.html |
| BPI-Wifi6 Mini metal case Taobao Shop: https://item.taobao.com/item.htm?id=930050010648&spm=a213gs.v2success.0.0.71504831rBdAfZ&skuId=5816304229437 |
| OEM&ODM, please contact: [email protected] |
