Banana Pi BPI-Wifi6 Router design with Triductor TR6560 + TR5220 wifi SOC, it is a standard wifi6 router solution. Built-in high-performance dual-core ARM Cortex-A9 processor for WIFI message forwarding or intelligent business processing, built-in high-performance LSW and hardware NAT, supporting up to 5Gbps message forwarding,Integrated 5*GE PHY, provides 1000Mbps network access capability, and supports two WAN ports. Support hardware intelligent QoS. Support dual-band 2.4G 40M 2*2 +5G160M2.2 DBDC WIFI,Wifi protocol version support to IEEE 802.11ax, backward compatible 802.11a /b/g/n/ac, can support the highest rate of 3Gbps, 2G will reach 573.5Mbps, while 5G will reach 2401.9Mbps, support PoE interface ,add PoE module to support PoE function.
Triductor TR6560 + TR5220 wifi design: Banana Pi BPI-Wifi6 Router low cost wifi6 Router board Triductor TR6560 + TR5220 wifi design: Banana Pi BPI-Wifi6 Mini Router low cost Mini wifi6 Router board same size as: Banana Pi BPI-R3 mini Siflower SF19A2890S + AN8855R design Banana Pi BPI-Wifi5 Router low cost wifi5 Router board |
Dual core ARM Cortex-A9 1.2G Hz
Integrated 5*GE PHY
Support 1000M/100M/10M rate mode self-negotiation and standard MIB statistics
Support IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
Support Wi-Fi AP mode and STA mode
Support WPA,WPA2, WPA3 encryption and decryption, and supports Chinese WAPI standard
PoE function support
| BPI-Wifi6 Router Debug UART(J3)-TTL3.3V | |
Debug |
UART(J3)-TTL3.3V |
PIN1 |
RXD |
PIN2 |
NC |
PIN3 |
3.3V |
PIN4 |
GND |
PIN5 |
TXD |
Easy to add PoE function suppport on BPI-Wifi6 router,The PoE module port is reserved on the board. If the PoE module is welded to the board, the PoE network cable power supply function is supported.
| Use BPI-RT5400-12V PoE module. |
We have design a case for BPI-Wifi6 Router board ,so you can use this board directly as a standard wifi6 router
| The Router product just support 1Wan + 3 Lan port ,not 4 LAN port |
| OEM&ODM support : this board support customized service. You can quickly produce your own wifi6 router products. And develop your own software on it |
| Banana Pi BPI-WiFi6 Product introduction Video: https://www.youtube.com/watch?v=jTuLyygpkWA |
Source code on github: Old source code: https://github.com/BPI-SINOVOIP/THG6500-TAX2-OPENWRT-BSP New source code: https://github.com/BPI-SINOVOIP/THG6500-TAX2-OPENWRT-BSP_TGP3 |
Note: The old source code is incompatible with the new hardware and will cause WiFi malfunctions. The new source code is compatible with the old hardware, but its use is not recommended. The new source code requires a MAC address and corresponding key; otherwise, WiFi functionality will be limited, and the device will restart every hour. Based on the silkscreen markings on the main chip, the new WiFi chip is vertical, while the old WiFi chip is horizontal. |
| BPI-WiFi6 Schematic |
Baidu cloud: https://pan.baidu.com/s/16c8t09cWXovTMgPh2XYeKg?pwd=8888 (pincode: 8888)
| Banana Pi BPI wifi6 router with Triductor TR6560 + TR5220 wifi SOC test PoE and OpenWRT: https://www.youtube.com/watch?v=Nf03ssN8ez0 |
| 2025-10-28 OpenWRT-TGP3.3.4 |
Baidu Cloud: https://pan.baidu.com/s/1vFJER_fpwLw2e3bP0-Y-HA PIN code:8888
| 2024-01-05 OpenWRT-TGP3.1.0_rc8 |
Baidu Cloud: https://pan.baidu.com/s/16ZVe4cKMmQAGcg3KNcOq3w?pwd=8888 PIN code:8888
| BANANAPI Official shop: https://www.bpi-shop.com/products/banana-pi-bpi-wifi6-router-design-with-triductor-tr6560-tr5220-wifi-soc.html |
| BPI Aliexpress shop : https://www.aliexpress.com/store/group/BPI-Wifi-6/1101951077_40000004162529.html?spm=a2g0o.store_pc_saleItems.0.0.77487862alHitN |
| SinoVoip Aliexpress shop : https://www.aliexpress.com/store/group/BPI-WIfi-6/1100417230_40000004365851.html?spm=a2g0o.store_pc_saleItems.0.0.1b4430d9kDRD79 |
| Taobao shop : https://item.taobao.com/item.htm?ft=t&id=769972122493 |
| OEM&ODM please contact : [email protected] |
