Banana Pi BPI-F3 is a industrial grade RISC-V development board, it design with SpacemiT K1 8 core RISC-V chip, CPU integrates 2.0 TOPs AI computing power. 2/4/8/16G DDR and 8/16/32/128G eMMC onboard.2x GbE Ethernet prot, 4x USB 3.0 and PCIe for M.2 interface, support HDMI and Dual MIPI-CSI Camera.
SpacemiT K1 RISC-V Banana Pi BPI-F3 AI SBC design SpacemiT K1 RISC-V Banana Pi BPI-CM6 AI Computer module design |
SpacemiT K1 is an octa-core 64-bit RISC-V AI CPU. Base on RISC-V open instruction set architecture,we are committed to create more energy efficient and more commonly used AI processor platform,promote global open source and open ecological computing power construction.
SpacemiT K1 is mainly used for single board computer,network storage,cloud computer,smart robort,industrial control,edge computer,etc.
Single-core general computing power equivalent to 1.3 times Cortex-A55
Supports 32-bit LPDDR4/4X, with a maximum of 16GB of memory
4K decoding and encoding
5-lane PCIE2.1 expansion capability
4x USB 3.0 + 1x USB 2.0 OTG interfaces
12x UART serial ports
Operating temperature range: -40°C to 85°C
NAS
Laptop
Intelligent robotics
Industrial control
AI edge computing
HardWare Specification of Banana Pi BPI-F3 RISC-V SBC | |
CPU |
SpacemiT K1 Otca-core X60(RV64GCVB),RVA22,RVV1.0 |
AI |
2.0Tops from RlSC-V Core |
GPU |
IMG BXE-2-32@819MHz,32KB SLCOpenGL ES1.1/3.2EGL1.50penCL 3.0Vulkan 1.3 |
Memory |
2/4/8/16 GB LPDDR4 (Supports up to 16G LPDDR4) |
Storage |
8/16/32/128 GB eMMC flash.(optional 4M SPI NOR,32M SPI NAND) |
SD card |
MicroSD card slot (Use SD card larger than 256M, no upper limit) |
Wireless |
2.4G/5G WiFi and Bluetooth 4.2 |
Ethernet |
2x GbE Ethernet port(supports PoE with add-on PoE HAT) |
HDMI |
1x full-size HDMI digital Audio output(HDMI1.4,up to 1080p@60fps ) |
Display |
MIPI DSI interface |
Audio |
Speaker,Mic, Earphone |
Camera |
MIPI-CSI, Dual-shot support |
USB |
4x USB 3.0 Type-A HOST, 1x USB 2.0 Type-C OTG |
PCIe |
PCIE2.1 2lane * 2. |
GPIO |
26-pin header |
Buttons |
Reset, Power and Burn |
LED |
Power Status |
Power |
DC in and TYPE-C in |
Size |
148x100 mm |
Weight |
200g |
PIN | Function | Function | PIN |
1 |
VCC3V3_SYS |
VCC5V0_OUT |
2 |
3 |
AP_I2C4_SDA_3V3 |
VCC5V0_OUT |
4 |
5 |
AP_I2C4_SCL_3V3 |
GND |
6 |
7 |
GPIO_70_3V3 |
R_UART0_TXD_3V3 |
8 |
9 |
GND |
R_UART0_RXD_3V3 |
10 |
11 |
GPIO_71_3V3 |
GPIO_74_3V3 |
12 |
13 |
GPIO_72_3V3 |
GND |
14 |
15 |
GPIO_73_3V3 |
GPIO_91_3V3 |
16 |
17 |
VCC3V3_SYS |
GPIO_92_3V3 |
18 |
19 |
SPI3_MOSI_3V3 |
GND |
20 |
21 |
SPI3_MISO_3V3 |
GPIO_49_3V3 |
22 |
23 |
SPI3_SCLK_3V3 |
SPI3_CS_3V3 |
24 |
25 |
GND |
GPIO_50_3V3 |
2 |
Holding a 1080P screen (JL-M101N013-P12WU-M402632), the screen socket model is FH35C-31S-0.3SHW (50)
1 |
MIPI_DSI1_LANE0_DN |
MIPI_DSI1_LANE0_DP |
2 |
3 |
GND |
MIPI_DSI1_LANE1_DN |
4 |
5 |
MIPI_DSI1_LANE1_DP |
GND |
6 |
7 |
MIPI_DSI1_CLK_N |
MIPI_DSI1_CLK_P |
8 |
9 |
GND |
MIPI_DSI1_LANE2_DN |
10 |
11 |
MIPI_DSI1_LANE2_DP |
GND |
12 |
13 |
MIPI_DSI1_LANE3_DN |
MIPI_DSI1_LANE3_DP |
14 |
15 |
GND |
MIPI_LCD_ADC_1V8 |
16 |
17 |
LCD_PWR_EN_1V8 |
LCD_RST_1V8 |
18 |
19 |
LCD_BL_EN_1V8 |
LCD_BL_PWM_1V8 |
20 |
21 |
GND |
TP_INT_1V8 |
22 |
23 |
TP_RST_1V8 |
AP_I2C6_SCL |
24 |
25 |
AP_I2C6_SDA |
LCD_VCC18 |
26 |
27 |
GND |
GND |
28 |
29 |
LCD_VCC5V0 |
LCD_VCC5V0 |
30 |
31 |
LCD_VCC5V0 |
By default, it supports a 16M camera module, which can be modified After blocking the configuration, hold the 8M camera module and adopt a uniform spacing 0.4mm 30 pin socket (model QG1330421Y-M08-7H).
16M camera:
1 |
GND |
GND |
2 |
3 |
GND |
FS_DUALCAM |
4 |
5 |
CAM_MCLK0 |
GND |
6 |
7 |
GND |
CAMERA0_RST |
8 |
9 |
MIPI_CSI1_DN0 |
CAMERA0_PDN |
10 |
11 |
MIPI_CSI1_DP0 |
CAM_I2C0_SDA |
12 |
13 |
GND |
CAM_I2C0_SCL |
14 |
15 |
MIPI_CSI1_CLKN |
CSI_DVDD12 |
16 |
17 |
MIPI_CSI1_CLKP |
CSI_VCCIO18 |
18 |
19 |
GND |
GND |
20 |
21 |
MIPI_CSI1_DN1 |
CSI_AVDD28 |
22 |
23 |
MIPI_CSI1_DP1 |
CSI_AFVCC28 |
24 |
25 |
GND |
GND |
26 |
27 |
MIPI_CSI1_DN2 |
MIPI_CSI1_DP3 |
28 |
29 |
MIPI_CSI1_DP2 |
MIPI_CSI1_DN3 |
30 |
8M camera:
1 |
MIPI_CSI3_DP3 |
CAM_MCLK1 |
2 |
3 |
MIPI_CSI3_DN3 |
CAMERA1_RST |
4 |
5 |
GND |
CAMERA1_PDN |
6 |
7 |
MIPI_CSI3_DP2 |
GND |
8 |
9 |
MIPI_CSI3_DN2 |
CAM_I2C1_SDA |
10 |
11 |
GND |
CAM_I2C1_SCL |
12 |
13 |
MIPI_CSI3_DP1 |
GND |
14 |
15 |
MIPI_CSI3_DN1 |
CSI_VCCIO18 |
16 |
17 |
GND |
CSI_AVDD28 |
18 |
19 |
MIPI_CSI3_CLKP |
CSI_AFVCC28 |
20 |
21 |
MIPI_CSI3_CLKN |
CSI_DVDD12 |
22 |
23 |
GND |
FLASH_LED0+ |
24 |
25 |
MIPI_CSI3_DP0 |
FLASH_LED1+ |
26 |
27 |
MIPI_CSI3_DN0 |
GND |
28 |
29 |
GND |
GND |
30 |
Easy to buy case sample :
BIPAI Aliexpress shop: https://www.aliexpress.com/item/3256807424111807.html
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256807423878151.html?
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=828591909710
We design PoE function for BPI-F3 ,so easy to add PoE module to support PoE function.Weld the RT5400B POE module and power it through the RJ45-2 interface.
After connecting to the MINI PCIE interface and inserting the SIM card, it can be used.
Bianbu source code: https://gitee.com/bianbu-linux/linux-6.1 |
Bianbu uboot code: https://gitee.com/bianbu-linux/uboot-2022.10 |
Bianbu OpenSBI code: https://gitee.com/bianbu-linux/opensbi |
OpenWrt source code: https://archive.spacemit.com/openwrt/releases/23.05.2/ |
SpacemiT K1 8 core RISC-V chip (Banana Pi BPI-F3) RISC-V IME set Specification public on github
BPI-F3 schematic |
Baidu cloud: https://pan.baidu.com/s/1CMp7kVKa5aeSdgB3Ri1PJw?pwd=8888 (pincode:8888)
BPI-F3 DXF file |
Baidu cloud: https://pan.baidu.com/s/1igwBjsLC54KbGH_y54tZQA?pwd=8888 (pincode:8888)
BPI-F3 run Ubuntu Linux test 8 Core CPU performance and AI function: https://www.youtube.com/watch?v=Ym-VcJgaGIY |
BPI-F3 SpacemiT K1 run OpenWRT: https://www.youtube.com/watch?v=ejV5KFww8Xo |
BPI-F3 run visual AI+ large models simultaneously: https://www.youtube.com/watch?v=Kn7GYiOxato |
Bringing up BPI-F3 : https://dev.to/luzero/bringing-up-bpi-f3-part-1-3bm4 |
Banana Pi BPI-F3 Review : Octa Core RISC-V SBC Running Bianbu OS : https://www.youtube.com/watch?v=GZGryhBnkV0 |
BPI-F3 DEB1 scenario power consumption data |
Baidu cloud: https://pan.baidu.com/s/1DJyKp7GzJ-v-E-d1tGYTCQ?pwd=8888 (pincode: 8888)
Banana Pi BPI-F3 image download link: #Archlinux #Fedora #openSUSE #DietPi #gentoo
Images below v1.0.7 do not support 16G. |
SpacemiT official Bianbu image release link: http://archive.spacemit.com/image/k1/version/bianbu/ |
BPI-F3_Bianbu_23.10_v1.0.12_20240802 |
Baidu cloud: https://pan.baidu.com/s/1fHNXbvplb8z9JtQsxxfHTg?pwd=8888 (pincode: 8888)
Account/Password: root/bianbu
Bianbu-23.10-k1-v1.0rc3-release-20240525131412.img |
Baidu cloud: https://pan.baidu.com/s/1H0ww8qVIgHRuuA43JszF6g?pwd=8888 (pincode: 8888)
Bianbu-23.10-nas-k1-v1.0rc1-release-20240429192450.img |
Baidu cloud: https://pan.baidu.com/s/15owwUEjIU_i26cI1iigAew?pwd=8888 (pincode: 8888)
Bianbu-23.10-desktop-k1-v1.0rc1-release-20240429194149.img |
Baidu cloud: https://pan.baidu.com/s/1zvFkX92f5gpZdKjP-vGJvA?pwd=8888 (pincode: 8888)
BSP based on native OpenWrt 23.05 integrated Spacemit Stone series chips, including supervisory program interface (OpenSBI), boot loader (U-Boot/UEFI), Linux kernel, root file system (including various middleware and libraries), and examples. Its goal is to provide customers with soft routing and NAS scheme support, and can develop drivers or applications.
openwrt-spacemit-k1-nas-MUSE-N1-ext4-pack |
Baidu cloud: https://pan.baidu.com/s/1HJT04OiSGKmMa4y4RvVv9g?pwd=8888 (pincode: 8888)
openwrt-spacemit-k1-sbc-debX-ext4-pack |
Baidu cloud: https://pan.baidu.com/s/1XOkGOen0fc3RBEH—Jb3_A?pwd=8888 (pincode: 8888)
Bananapi-bpif3-armbian-v2.0.4-20250113 |
Baidu cloud: https://pan.baidu.com/s/1T5WXQRdvDZQOeFJo-koX3Q?pwd=8888 (pincode: 8888)
Bananapi-bpif3-armbian-v1.0.15-20250113 |
Baidu cloud: https://pan.baidu.com/s/1PRDtf5y8LsJDuT6-A5YXWw?pwd=8888 (pincode: 8888)
Bananapi-bpif3-armbian-v1.0.12-20240812 |
Baidu cloud: https://pan.baidu.com/s/1bYh0zt3j5dN8L8hni_Mmlw?pwd=8888 (pincode: 8888)
Bananapi-bpif3-armbian-v2.0.4-20250113-Debian |
Baidu cloud: https://pan.baidu.com/s/1HUsp_ap3MGxgV2jyS3lNTw?pwd=8888 (pincode: 8888)
Bananapi-bpif3-armbian-v1.0.12-20240823 |
Baidu cloud: https://pan.baidu.com/s/1AMweOaE7B7l3REkk3vupCg?pwd=8888 (pincode: 8888)
2024-08-12-Armbian-bpi-SpacemiT_24.5.0-trunk_Bananapif3_mantic_legacy_6.1.15_gnome_desktop.img , support gpu hardware acceleration ,2/4/8/16G version, and burning to eMMC |
Baidu cloud: https://pan.baidu.com/s/1kJdiyjnoPoaV0iIm1fTH6Q?pwd=8888 (pincode: 8888)
2024-08-12-Armbian-bpi-SpacemiT_24.5.0-trunk_Bananapif3_mantic_legacy_6.1.15.img ,not support gpu hardware acceleration |
Baidu cloud: https://pan.baidu.com/s/1lrByBBgDuS_8cKAaz7BVfQ?pwd=8888 (pincode: 8888)
User/Password: Create it yourself when you start it for the first time. If you fail to create it successfully, you can also return to the creation page through root/1234.
Fedora.riscv64-40-20240429.n.0.raw.zst-bpi-f3-3356MB.img |
Baidu cloud: https://pan.baidu.com/s/1EFcLInWYxLi032gmhueiWw?pwd=8888 (pincode: 8888)
Account/Password: root/bananapi
BANANAPI Official Shop: https://www.bpi-shop.com/products/anana-pi-bpi-f3-design-with-spacemit-k1-8-core-risc-v-chip.html |
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256806735430070.html |
Bipai Aliexpress shop: https://www.aliexpress.com/item/3256806735645440.html |
Taobao Shop: https://item.taobao.com/item.htm?id=789483353026&spm=a213gs.v2success.0.0.220c4831vddhXz |
OEM&ODM,please contact : [email protected] |
